<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Max voltage of 5V Input]]></title><description><![CDATA[<p dir="auto">Hello,</p>
<p dir="auto">unfortunately I cannot find Specifications of the maximum possible voltage of the 5V IN port.<br />
From the block diagram (<a href="https://docs.m5stack.com/#/en/core/m5stickc" target="_blank" rel="noopener noreferrer nofollow ugc">https://docs.m5stack.com/#/en/core/m5stickc</a>) it looks like that 5V IN is ACIN, is this right?<br />
Refering to the AXP192 data sheet (<a href="https://github.com/m5stack/M5-Schematic/blob/master/Core/AXP192%20Datasheet_v1.1_en_draft_2211.pdf" target="_blank" rel="noopener noreferrer nofollow ugc">https://github.com/m5stack/M5-Schematic/blob/master/Core/AXP192 Datasheet_v1.1_en_draft_2211.pdf</a>) , up to 6.3V should be within the spec.<br />
Is this right?</p>
]]></description><link>https://community.m5stack.com/topic/1603/max-voltage-of-5v-input</link><generator>RSS for Node</generator><lastBuildDate>Thu, 14 May 2026 10:45:20 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/1603.rss" rel="self" type="application/rss+xml"/><pubDate>Sat, 11 Jan 2020 21:23:56 GMT</pubDate><ttl>60</ttl></channel></rss>
