<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[M5stack connect HC-SR04 with I&#x2F;O port (not grove connector) coding by UI Flow]]></title><description><![CDATA[<p dir="auto">Hello i'm trying M5stack Basic Development conect ultrasonic sensor model HC-SR04 with GPIO2 (trig) &amp; GPIO5 (echo) for read parameter shown on the screen.<br />
So coding on UI Flow  but in platform don't have digital pwm read input function (in Arduino IDE is "pluseIn")<br />
Could there be any object or commands or functions that can be used instead, or how can the program read pulse input ?</p>
<p dir="auto">thank you so much.</p>
]]></description><link>https://community.m5stack.com/topic/1636/m5stack-connect-hc-sr04-with-i-o-port-not-grove-connector-coding-by-ui-flow</link><generator>RSS for Node</generator><lastBuildDate>Wed, 29 Apr 2026 08:43:55 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/1636.rss" rel="self" type="application/rss+xml"/><pubDate>Mon, 20 Jan 2020 10:19:45 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to M5stack connect HC-SR04 with I&#x2F;O port (not grove connector) coding by UI Flow on Tue, 28 Apr 2020 10:18:20 GMT]]></title><description><![CDATA[<p dir="auto">This worked well for me with pin 21 (trigger) and pin 22 (echo)</p>
<p dir="auto"><a href="https://github.com/rsc1975/micropython-hcsr04" target="_blank" rel="noopener noreferrer nofollow ugc">https://github.com/rsc1975/micropython-hcsr04</a></p>
]]></description><link>https://community.m5stack.com/post/8402</link><guid isPermaLink="true">https://community.m5stack.com/post/8402</guid><dc:creator><![CDATA[Serge]]></dc:creator><pubDate>Tue, 28 Apr 2020 10:18:20 GMT</pubDate></item><item><title><![CDATA[Reply to M5stack connect HC-SR04 with I&#x2F;O port (not grove connector) coding by UI Flow on Wed, 22 Jan 2020 04:31:14 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/doctan" aria-label="Profile: doctan">@<bdi>doctan</bdi></a> I used an ultrasonic sensor with m5stack in arduino before but it is a simple one<br />
<a href="https://www.hackster.io/lukasmaximus89/grove-ultrasonic-sensor-with-m5stack-710d15" target="_blank" rel="noopener noreferrer nofollow ugc">https://www.hackster.io/lukasmaximus89/grove-ultrasonic-sensor-with-m5stack-710d15</a> and made a guide, but it is arduino. For uiflow since m5stack did not create any ultrasonic unit you would have to create your own code in micropython to control it and then create custom blocks. I think I read that hc-sr04 has 5 pins, is it true? and is it using i2c protocol or just analogue out?</p>
]]></description><link>https://community.m5stack.com/post/7154</link><guid isPermaLink="true">https://community.m5stack.com/post/7154</guid><dc:creator><![CDATA[lukasmaximus]]></dc:creator><pubDate>Wed, 22 Jan 2020 04:31:14 GMT</pubDate></item></channel></rss>
