<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[M5Stack does not connect WiFi with Node attached]]></title><description><![CDATA[<p dir="auto">My M5Stack does not connect to WiFi when the Node shield is attached. When I remove the Node and connect the battery or USB shield, the WiFi connection is perfect.<br />
I have two M5Stack's and two Node's both same issue.</p>
<p dir="auto">Does anyone knows how to solve this?</p>
]]></description><link>https://community.m5stack.com/topic/1640/m5stack-does-not-connect-wifi-with-node-attached</link><generator>RSS for Node</generator><lastBuildDate>Wed, 29 Apr 2026 14:12:34 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/1640.rss" rel="self" type="application/rss+xml"/><pubDate>Tue, 21 Jan 2020 16:58:45 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to M5Stack does not connect WiFi with Node attached on Wed, 22 Jul 2020 13:37:01 GMT]]></title><description><![CDATA[<p dir="auto">Installing the silabs Silicon Labs VCP Driver.pkg worked for me also. 👍<br />
(on OS X 10.11.6)</p>
<p dir="auto">Seems obvious that we need the drivers, but I thought I already had them after going thru the espressif/arduino-esp32 install steps.<br />
e.g. My "System Report / Hardware / USB" showed<br />
CP2102 USB to UART Bridge Controller driver</p>
<p dir="auto">For others' future reference, you should see something like:<br />
n8s-iMac:nleon$ ls -al /dev/tty.*<br />
crw-rw-rw- 1 root wheel 18, 2 Jul 4 11:14 /dev/tty.SLAB_USBtoUART</p>
<p dir="auto">Regardless, thanks for the pointer!</p>
<p dir="auto">Admin<br />
<a href="https://www.apps4rent.com" target="_blank" rel="noopener noreferrer nofollow ugc">Apps4Rent</a></p>
]]></description><link>https://community.m5stack.com/post/9407</link><guid isPermaLink="true">https://community.m5stack.com/post/9407</guid><dc:creator><![CDATA[Lewis-H]]></dc:creator><pubDate>Wed, 22 Jul 2020 13:37:01 GMT</pubDate></item><item><title><![CDATA[Reply to M5Stack does not connect WiFi with Node attached on Wed, 18 Mar 2020 14:20:26 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/m5stack" aria-label="Profile: m5stack">@<bdi>m5stack</bdi></a> said in <a href="/post/7797">M5Stack does not connect WiFi with Node attached</a>:</p>
<p dir="auto">maybe is the  router signal quality problem. you could try put the device closer the router</p>
<p dir="auto">No, i experience significative degradation with node base attached, while using face base i can connect from long distance. As i mentioned, putting proto board in between mitigate partially, i can gain some meter but not as using face base</p>
]]></description><link>https://community.m5stack.com/post/7812</link><guid isPermaLink="true">https://community.m5stack.com/post/7812</guid><dc:creator><![CDATA[ecasti]]></dc:creator><pubDate>Wed, 18 Mar 2020 14:20:26 GMT</pubDate></item><item><title><![CDATA[Reply to M5Stack does not connect WiFi with Node attached on Wed, 18 Mar 2020 02:52:04 GMT]]></title><description><![CDATA[<p dir="auto">maybe is the  router signal quality problem. you could try put the device closer the router</p>
]]></description><link>https://community.m5stack.com/post/7797</link><guid isPermaLink="true">https://community.m5stack.com/post/7797</guid><dc:creator><![CDATA[m5stack]]></dc:creator><pubDate>Wed, 18 Mar 2020 02:52:04 GMT</pubDate></item><item><title><![CDATA[Reply to M5Stack does not connect WiFi with Node attached on Wed, 18 Mar 2020 00:08:38 GMT]]></title><description><![CDATA[<p dir="auto">btw if i put in between a proto-modul ( still empty ) work perfectly fine, and maybe should help also getting better measure on DHT12, will try</p>
]]></description><link>https://community.m5stack.com/post/7791</link><guid isPermaLink="true">https://community.m5stack.com/post/7791</guid><dc:creator><![CDATA[ecasti]]></dc:creator><pubDate>Wed, 18 Mar 2020 00:08:38 GMT</pubDate></item><item><title><![CDATA[Reply to M5Stack does not connect WiFi with Node attached on Tue, 17 Mar 2020 22:55:13 GMT]]></title><description><![CDATA[<p dir="auto">Just received and similar issue here,  from my desk there is no way to connect to WiFi, it work only closer to the router, it seem the node board interfere with antenna.</p>
]]></description><link>https://community.m5stack.com/post/7788</link><guid isPermaLink="true">https://community.m5stack.com/post/7788</guid><dc:creator><![CDATA[ecasti]]></dc:creator><pubDate>Tue, 17 Mar 2020 22:55:13 GMT</pubDate></item></channel></rss>
