<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[M5stick GREY upload&#x2F;flash problem]]></title><description><![CDATA[<p dir="auto">Hi everyone,<br />
I've recently bought an m5stick GREY in particular for it's 9-axis sensor.<br />
I've uploaded the stickwatch.ino with arduinoIDE (following step by step both the arduino IDE and the stickwatch guides).<br />
Willing to try out the uiflow ide i tried to connect it and to burn the UIFlowv1.2.3, therefore using the button Erase, before trying to Burn it.<br />
The result is the known problem:<br />
<img src="/assets/uploads/files/1579738235583-b244ad9a-81b8-48f2-93a3-bca22eb0294c-immagine-resized.png" alt="0_1579738233463_b244ad9a-81b8-48f2-93a3-bca22eb0294c-immagine.png" class=" img-fluid img-markdown" /><br />
Since then i'm stuck with the Stickwatch sketch installed, and i can't upload anything else.<br />
I even tried "EasyLoader_M5Stick_FactoryTest" with no results.</p>
<p dir="auto">Please Community-Senpai you are my only hope.</p>
<p dir="auto">BaDjinn</p>
]]></description><link>https://community.m5stack.com/topic/1644/m5stick-grey-upload-flash-problem</link><generator>RSS for Node</generator><lastBuildDate>Tue, 05 May 2026 11:03:00 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/1644.rss" rel="self" type="application/rss+xml"/><pubDate>Thu, 23 Jan 2020 00:13:58 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to M5stick GREY upload&#x2F;flash problem on Fri, 24 Jan 2020 11:59:58 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/badjinn" aria-label="Profile: badjinn">@<bdi>badjinn</bdi></a> said in <a href="/post/7177">M5stick GREY upload/flash problem</a>:</p>
<p dir="auto">Solved, it was a problem with the Silicon bridge drivers.  I uninstalled it and it worked like a charm.  😁</p>
<p dir="auto">Glad to hear it, they can be an issue on their own</p>
]]></description><link>https://community.m5stack.com/post/7178</link><guid isPermaLink="true">https://community.m5stack.com/post/7178</guid><dc:creator><![CDATA[ajb2k3]]></dc:creator><pubDate>Fri, 24 Jan 2020 11:59:58 GMT</pubDate></item><item><title><![CDATA[Reply to M5stick GREY upload&#x2F;flash problem on Thu, 23 Jan 2020 23:26:02 GMT]]></title><description><![CDATA[<p dir="auto">Solved, it was a problem with the Silicon bridge drivers.  I uninstalled it and it worked like a charm.  😁</p>
]]></description><link>https://community.m5stack.com/post/7177</link><guid isPermaLink="true">https://community.m5stack.com/post/7177</guid><dc:creator><![CDATA[BaDjinn]]></dc:creator><pubDate>Thu, 23 Jan 2020 23:26:02 GMT</pubDate></item><item><title><![CDATA[Reply to M5stick GREY upload&#x2F;flash problem on Thu, 23 Jan 2020 13:20:40 GMT]]></title><description><![CDATA[<p dir="auto">I've solved the problem by tempering with the "reset" button, erased, used EasyLoader_M5Stick_FactoryTest and after that tried a few exemples in the arduino IDE.<br />
Sadly now i'm again in the same problem as before: I've successfully uploaded the example "helloServer" to tryout the server capability/interface/library...and all works well...but now i am in no way able to flash anyting new on it.<br />
I tried as you (aib2k3) said to switch cables and USB port, tried my trick on catching the right timing with the reset button, but to no avail.</p>
<p dir="auto">Can you help me?</p>
]]></description><link>https://community.m5stack.com/post/7171</link><guid isPermaLink="true">https://community.m5stack.com/post/7171</guid><dc:creator><![CDATA[BaDjinn]]></dc:creator><pubDate>Thu, 23 Jan 2020 13:20:40 GMT</pubDate></item><item><title><![CDATA[Reply to M5stick GREY upload&#x2F;flash problem on Thu, 23 Jan 2020 05:45:59 GMT]]></title><description><![CDATA[<p dir="auto">Check your cable, it may have chosen this moment to fail,<br />
You need to click ERASE first before burning.<br />
Try changing the Baudrate,<br />
Try a different cable.</p>
]]></description><link>https://community.m5stack.com/post/7165</link><guid isPermaLink="true">https://community.m5stack.com/post/7165</guid><dc:creator><![CDATA[ajb2k3]]></dc:creator><pubDate>Thu, 23 Jan 2020 05:45:59 GMT</pubDate></item></channel></rss>
