<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[M5StickC HAT PIN control in UIFlow]]></title><description><![CDATA[<p dir="auto">M5StickC has these 8 PIN<br />
<strong>GND</strong>, <strong>5V OUT</strong>, <strong>G26</strong>, <strong>G36</strong>, <strong>G0</strong>, <strong>BAT</strong> (what is?), <strong>3V3</strong>, <strong>5V IN</strong></p>
<p dir="auto">I cannot find a match in Uiflow. Uiflow pin block allows me to select pin0, pin1, pin2 ,pin3 , pin4.</p>
<p dir="auto"><img src="https://i.imgur.com/mJy58tm.png" alt="alt text" class=" img-fluid img-markdown" /></p>
<p dir="auto">Other doubt<br />
With just Uiflow firmware flashed and no other task running checking the pin with a multimeter. I have noticed that  <strong>G26</strong>, <strong>G36</strong>, <strong>G0</strong> haven't same voltage (G36 seems having a lower voltage). Why?</p>
]]></description><link>https://community.m5stack.com/topic/1648/m5stickc-hat-pin-control-in-uiflow</link><generator>RSS for Node</generator><lastBuildDate>Wed, 29 Apr 2026 17:15:32 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/1648.rss" rel="self" type="application/rss+xml"/><pubDate>Sat, 25 Jan 2020 00:50:43 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to M5StickC HAT PIN control in UIFlow on Fri, 17 Apr 2020 02:54:12 GMT]]></title><description><![CDATA[<p dir="auto">Unless I’m not understanding it correctly, according to the <a href="https://docs.m5stack.com/#/en/uiflow/advanced" target="_blank" rel="noopener noreferrer nofollow ugc">docs</a>, you would select a pinX from the drop down list and type the pin number (ex: 26) into the Init pin block. Then you can get or set the pin via the other blocks. As far as pin0 through pin5, those seems to be a designator for the pin you are controlling.</p>
<p dir="auto">BAT = battery</p>
]]></description><link>https://community.m5stack.com/post/8183</link><guid isPermaLink="true">https://community.m5stack.com/post/8183</guid><dc:creator><![CDATA[world101]]></dc:creator><pubDate>Fri, 17 Apr 2020 02:54:12 GMT</pubDate></item><item><title><![CDATA[Reply to M5StickC HAT PIN control in UIFlow on Thu, 16 Apr 2020 23:07:47 GMT]]></title><description><![CDATA[<p dir="auto">Hi,</p>
<p dir="auto">I want to utilize the HAT pin in UIFlow to add a digital sensor. Are there any plans to support the HAT pin in UIFlow? Though I can code in the Arduino environment, I want to go with UIFlow if possible. Because UIFlow is easy to deploy and let non-experts tinker.</p>
<p dir="auto">Thanks.</p>
]]></description><link>https://community.m5stack.com/post/8180</link><guid isPermaLink="true">https://community.m5stack.com/post/8180</guid><dc:creator><![CDATA[kotobuki]]></dc:creator><pubDate>Thu, 16 Apr 2020 23:07:47 GMT</pubDate></item><item><title><![CDATA[Reply to M5StickC HAT PIN control in UIFlow on Sun, 26 Jan 2020 09:25:13 GMT]]></title><description><![CDATA[<p dir="auto">I would hazard a guess, that one gpio is receiveing comands from the host, while the other is waiting for the user to send a command, therefore one pin will have a higher voltage when sending data, and the other will have a lower voltage or 0 while not receiving any data</p>
]]></description><link>https://community.m5stack.com/post/7196</link><guid isPermaLink="true">https://community.m5stack.com/post/7196</guid><dc:creator><![CDATA[lukasmaximus]]></dc:creator><pubDate>Sun, 26 Jan 2020 09:25:13 GMT</pubDate></item><item><title><![CDATA[Reply to M5StickC HAT PIN control in UIFlow on Sat, 25 Jan 2020 14:02:14 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/ajb2k3" aria-label="Profile: ajb2k3">@<bdi>ajb2k3</bdi></a> Bummer. I hope this feature will be introduced soon. What about the different voltage on G26, G36, G0. Is that normal? If yes why one of the pin has much lower voltage?</p>
]]></description><link>https://community.m5stack.com/post/7187</link><guid isPermaLink="true">https://community.m5stack.com/post/7187</guid><dc:creator><![CDATA[AndreaF]]></dc:creator><pubDate>Sat, 25 Jan 2020 14:02:14 GMT</pubDate></item><item><title><![CDATA[Reply to M5StickC HAT PIN control in UIFlow on Sat, 25 Jan 2020 10:22:45 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/andreaf" aria-label="Profile: andreaf">@<bdi>andreaf</bdi></a> individual pin control has not been yet provided for the hat connector</p>
]]></description><link>https://community.m5stack.com/post/7185</link><guid isPermaLink="true">https://community.m5stack.com/post/7185</guid><dc:creator><![CDATA[ajb2k3]]></dc:creator><pubDate>Sat, 25 Jan 2020 10:22:45 GMT</pubDate></item></channel></rss>
