<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[RA08 loRa module with GPS module?]]></title><description><![CDATA[<p dir="auto">I'd like to use this RA08 LoRa module</p>
<p dir="auto"><a href="https://www.banggood.com/M5Stack-Wireless-LoRa-Module-868MHz-Communicate-Module-Ra-01H-with-Prototyping-Area-SPI-Communication-Protoco-p-1600755.html" target="_blank" rel="noopener noreferrer nofollow ugc">https://www.banggood.com/M5Stack-Wireless-LoRa-Module-868MHz-Communicate-Module-Ra-01H-with-Prototyping-Area-SPI-Communication-Protoco-p-1600755.html</a>?</p>
<p dir="auto">I can't find a pinout for it, is it developed by a third party?</p>
<p dir="auto">I'd like to use it with this GPS module <a href="https://m5stack.com/collections/m5-module/products/gps-module" target="_blank" rel="noopener noreferrer nofollow ugc">https://m5stack.com/collections/m5-module/products/gps-module</a></p>
<p dir="auto">Is that possible without soldering?</p>
]]></description><link>https://community.m5stack.com/topic/1655/ra08-lora-module-with-gps-module</link><generator>RSS for Node</generator><lastBuildDate>Thu, 30 Apr 2026 11:56:19 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/1655.rss" rel="self" type="application/rss+xml"/><pubDate>Sun, 26 Jan 2020 16:22:33 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to RA08 loRa module with GPS module? on Fri, 31 Jan 2020 17:31:09 GMT]]></title><description><![CDATA[<p dir="auto">Hello Sam,</p>
<p dir="auto">I have the Lora868 module;<br />
Just a quick word of advice, if you want to use the module with the LMIC library then you <em>-as mentioned in the article you pointed out to-</em> have to solder the DI0 1 pad of the RA-01 to pin 34 of the M5stack connector.</p>
<p dir="auto">The pin-out for the Lora868 module:</p>
<p dir="auto">MISO - 19<br />
MOSI - 23<br />
SCK - 18<br />
NSS - 05<br />
RESET - 26<br />
DIO 0 - 36<br />
DIO 1 - 34   &lt;-- this one is NOT connected when you get your Lora868 module, soldering needed!</p>
<p dir="auto">If you want to know the physical pinout of the RA-01 (<a href="https://docs.ai-thinker.com/_detail/lora/spec/ra-01_picture.png?id=lora" target="_blank" rel="noopener noreferrer nofollow ugc">https://docs.ai-thinker.com/_detail/lora/spec/ra-01_picture.png?id=lora</a>)</p>
<p dir="auto">Greetings!</p>
]]></description><link>https://community.m5stack.com/post/7265</link><guid isPermaLink="true">https://community.m5stack.com/post/7265</guid><dc:creator><![CDATA[Seccie]]></dc:creator><pubDate>Fri, 31 Jan 2020 17:31:09 GMT</pubDate></item><item><title><![CDATA[Reply to RA08 loRa module with GPS module? on Mon, 27 Jan 2020 16:58:21 GMT]]></title><description><![CDATA[<p dir="auto">We found the pinout<br />
<a href="https://github.com/cyberman54/ESP32-Paxcounter/issues/537#issuecomment-578529871" target="_blank" rel="noopener noreferrer nofollow ugc">https://github.com/cyberman54/ESP32-Paxcounter/issues/537#issuecomment-578529871</a></p>
<p dir="auto">If anyone has this LoRa module and could test it that would be great. I'm waiting for mine to arrive.</p>
]]></description><link>https://community.m5stack.com/post/7210</link><guid isPermaLink="true">https://community.m5stack.com/post/7210</guid><dc:creator><![CDATA[sam_uk]]></dc:creator><pubDate>Mon, 27 Jan 2020 16:58:21 GMT</pubDate></item><item><title><![CDATA[Reply to RA08 loRa module with GPS module? on Sun, 26 Jan 2020 16:25:29 GMT]]></title><description><![CDATA[<p dir="auto">Part number is actually Ra-01H</p>
]]></description><link>https://community.m5stack.com/post/7203</link><guid isPermaLink="true">https://community.m5stack.com/post/7203</guid><dc:creator><![CDATA[sam_uk]]></dc:creator><pubDate>Sun, 26 Jan 2020 16:25:29 GMT</pubDate></item></channel></rss>
