<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[ESP-Now Project: Sender reporting temperature to Receiver]]></title><description><![CDATA[<p dir="auto">Here is an example of a project that utilizes ESP-Now for point-to-point communication between two M5Stack products. The M5StickC with ENV Unit is the Sender (transmitter) sending temperature and battery information to the M5Stack core (Receiver).</p>
<p dir="auto"><strong>Features:</strong></p>
<li>Temperature reporting from the Sender with high temperature alarm beeps and visuals on the Receiver</li>
<li>Battery voltage reporting on the Sender (voltage value and icon) with low battery alert on the Receiver</li>
<li>Visual indicator on the Sender when data is being sent: The LED is on when sending data. Toggle button B on the M5StickC to turn the LED indicator on/off. When off, the temperature is displayed in red text to still give a visual indicator when the device is sending data.</li>
<li>Audible indicator on the Receiver when the data is received: Volume +/- and Mute controls are available. Single beep tells the user the temperature is below the threshold (default is 160 degrees F). Triple beep tells the user the temperature is above the threshold.</li>
<li>Visual indicator on the Receiver when the temperature is above the threshold: The temperature text is displayed red when the temperature is too high.</li>
<li>Non-blocking code with the use of timers and callbacks instead of loops and waits</li>
<p dir="auto">Sender uiFlow (<a href="https://www.dropbox.com/s/yl3bnxs9beod6a4/espnow_sender.m5f?dl=0" target="_blank" rel="noopener noreferrer nofollow ugc">file</a>):<br />
<img src="/assets/uploads/files/1580479915558-sender-resized.png" alt="0_1580479911682_sender.png" class=" img-fluid img-markdown" /></p>
<p dir="auto">Receiver uiFlow (<a href="https://www.dropbox.com/s/gugfkm4ubf768oc/espnow_receiver.m5f?dl=0" target="_blank" rel="noopener noreferrer nofollow ugc">file</a>):<br />
<img src="/assets/uploads/files/1580479932240-receiver-resized.png" alt="0_1580479928690_receiver.png" class=" img-fluid img-markdown" /></p>
<p dir="auto">Sender Python code:</p>
from m5ui import *
from uiflow import *
import espnow
import wifiCfg
import unit
setScreenColor(0x000000)
env0 = unit.get(unit.ENV, unit.PORTA)
wifiCfg.wlan_ap.active(True)
espnow.init()
title0 = M5Title(title="Sender", x=3 , fgcolor=0xFFFFFF, bgcolor=0x0000FF)
label0 = M5TextBox(5, 40, "--", lcd.FONT_DejaVu24,0xFFFFFF, rotate=0)
rectangle4 = M5Rect(1, 117, 79, 25, 0x9d9d9d, 0x9d9d9d)
label1 = M5TextBox(5, 83, "Battery (V):", lcd.FONT_DefaultSmall,0xFFFFFF, rotate=0)
rectangle0 = M5Rect(3, 120, 15, 20, 0x33ff33, 0x33ff33)
rectangle1 = M5Rect(23, 120, 15, 20, 0x33ff33, 0x33ff33)
rectangle2 = M5Rect(43, 120, 15, 20, 0x33ff33, 0x33ff33)
rectangle3 = M5Rect(63, 120, 15, 20, 0x33ff33, 0x33ff33)
label2 = M5TextBox(5, 100, "--", lcd.FONT_DefaultSmall,0xFFFFFF, rotate=0)
label3 = M5TextBox(38, 40, "O", lcd.FONT_DefaultSmall,0xFFFFFF, rotate=0)
label4 = M5TextBox(47, 40, "F", lcd.FONT_DejaVu24,0xFFFFFF, rotate=0)
import math
senderFlag = None
temperature = None
batteryVoltage = None
ledStatus = None
highTempAlarm = None
lowBatteryAlarm = None
dataPayload = None
def batteryIcon():
  global senderFlag, temperature, batteryVoltage, ledStatus, highTempAlarm, lowBatteryAlarm, dataPayload
  if batteryVoltage &gt;= 4.1:
    rectangle0.hide()
    rectangle0.setBgColor(0x33ff33)
    rectangle0.setBorderColor(0x33ff33)
    rectangle0.show()
    rectangle1.show()
    rectangle2.show()
    rectangle3.show()
  elif batteryVoltage &lt; 4.1 and batteryVoltage &gt;= 3.9:
    rectangle0.hide()
    rectangle0.show()
    rectangle1.show()
    rectangle2.show()
    rectangle3.hide()
  elif batteryVoltage &lt; 3.9 and batteryVoltage &gt;= 3.7:
    rectangle0.hide()
    rectangle0.show()
    rectangle1.show()
    rectangle2.hide()
    rectangle3.hide()
  elif batteryVoltage &lt; 3.7 and batteryVoltage &gt;= 3.5:
    rectangle0.hide()
    rectangle0.show()
    rectangle1.hide()
    rectangle2.hide()
    rectangle3.hide()
  elif batteryVoltage &lt; 3.5 and batteryVoltage &gt;= 3.3:
    rectangle0.hide()
    rectangle0.show()
    rectangle1.hide()
    rectangle2.hide()
    rectangle3.hide()
  else:
    rectangle0.hide()
    rectangle0.setBgColor(0xff0000)
    rectangle0.setBorderColor(0xff0000)
    rectangle0.show()
    rectangle1.hide()
    rectangle2.hide()
    rectangle3.hide()
def highTempFunction():
  if temperature &gt; 160:
    highTempAlarm = 1
    label0.setColor(0xff0000)
  else:
    highTempAlarm = 0
    label0.setColor(0xffffff)
def lowBatteryFunction():
  if batteryVoltage &lt; 3.3:
    lowBatteryAlarm = 1
    label2.setColor(0xff0000)
  else:
    lowBatteryAlarm = 0
    label2.setColor(0xffffff)
def send_cb(flag):
  global senderFlag,temperature,batteryVoltage,ledStatus,highTempAlarm,lowBatteryAlarm,dataPayload
  senderFlag = flag
  if ledStatus == 1:
    M5Led.on()
    timerSch.run('ledOffTimer', 872, 0x01)
  else:
  pass
espnow.send_cb(send_cb)
def buttonB_wasPressed():
  if ledStatus == 1:
    ledStatus = 0
  else:
    ledStatus = 1
  pass
btnB.wasPressed(buttonB_wasPressed)
@timerSch.event('ledOffTimer')
def tledOffTimer():
  M5Led.off()
  pass
@timerSch.event('sendData')
def tsendData():
  temperature = round((env0.temperature) * 1.8 + 32)
  label0.setText(str(temperature))
  highTempFunction()
  dataPayload = [temperature, highTempAlarm, lowBatteryAlarm]
  espnow.send(id=1, data=str(dataPayload))
  pass
@timerSch.event('checkBatteryTimer')
def tcheckBatteryTimer():
  batteryVoltage = axp.getBatVoltage()
  label2.setText(str(batteryVoltage))
  batteryIcon()
  pass
batteryIcon()
espnow.add_peer('30:ae:a4:49:cd:9d', id=1)
ledStatus = 1
timerSch.run('checkBatteryTimer', 15000, 0x00)
timerSch.run('sendData', 9999, 0x00)
<p dir="auto">Receiver Python code:</p>
from m5ui import *
import espnow
import wifiCfg
espnow.init()
title0 = M5Title(title="Receiver", x=3 , fgcolor=0xFFFFFF, bgcolor=0x0000ff)
label0 = M5TextBox(110, 85, "---", lcd.FONT_DejaVu56,0xFFFFFF, rotate=0)
label6 = M5TextBox(85, 150, "HIGH TEMPERATURE!", lcd.FONT_Default,0xff0000, rotate=0)
label7 = M5TextBox(90, 30, "Low battery on sender!", lcd.FONT_Default,0xff0000, rotate=0)
rectangle0 = M5Rect(40, 194, 233, 18, 0x7e7c7c, 0x7e7c7c)
label1 = M5TextBox(183, 85, "O", lcd.FONT_Default,0xFFFFFF, rotate=0)
label10 = M5TextBox(7, 196, "Vol", lcd.FONT_Default,0xffffff, rotate=0)
label2 = M5TextBox(194, 85, "F", lcd.FONT_DejaVu56,0xFFFFFF, rotate=0)
rectangle1 = M5Rect(45, 198, 220, 10, 0xFFFFFF, 0xFFFFFF)
label3 = M5TextBox(55, 220, "Vol-", lcd.FONT_Default,0xFFFFFF, rotate=0)
label4 = M5TextBox(235, 220, "Vol+", lcd.FONT_Default,0xFFFFFF, rotate=0)
label5 = M5TextBox(145, 220, "Mute", lcd.FONT_Default,0xFFFFFF, rotate=0)
senderMacAddr = None
messagePayload = None
list2 = None
volume = None
temperature = None
highTemperatureAlarm = None
rectWidth = None
def displayVolume():
  global senderMacAddr, messagePayload, list2, volume, temperature, highTemperatureAlarm, rectWidth, lowBatteryAlarm
  if rectWidth &gt; 220:
    rectangle1.setSize(width=220)
  elif rectWidth &lt; 0:
    rectangle1.setSize(width=0)
  else:
    rectangle1.setSize(width=rectWidth)
def displayTemperature():
  if len(temperature) == 3:
    label0.setPosition(x=75)
  else:
    label0.setPosition(x=110)
def highTemperatureCheck():
  if highTemperatureAlarm == '1':
    label6.show()
    speaker.tone(1200, 100)
    speaker.tone(1300, 200)
  else:
    label6.hide()
    speaker.tone(1000, 100)
def lowBatteryCheck():
  if lowBatteryAlarm == '1':
    label7.show()
  else:
    label7.hide()
def recv_cb(_):
  global senderMacAddr,messagePayload,list,volume,temperature,highTemperatureAlarm,rectWidth,lowBatteryAlarm
  senderMacAddr, _, messagePayload = espnow.recv_data(encoder='str')
  list2 = messagePayload.split(',')
  temperature = list2[0].replace('[', '').strip()
  highTemperatureAlarm = list2[1].strip()
  lowBatteryAlarm = list2[2].replace(']', '').strip()
  lowBatteryCheck()
  pass
espnow.recv_cb(recv_cb)
def buttonA_wasPressed():
  global senderMacAddr, messagePayload, list, volume, temperature, highTemperatureAlarm, rectWidth, lowBatteryAlarm
  if volume &lt; 0:
    label5.setColor(0xff0000)
    volume = 0
    speaker.setVolume(volume)
  else:
    label5.setColor(0xffffff)
    volume = volume - 0.1
    rectWidth = rectWidth - 22
  displayVolume()
  pass
btnA.wasPressed(buttonA_wasPressed)
  if volume &gt; 0:
    volume = 0
  else:
    volume = 0.5
    rectangle1.setSize(width=110)
  pass
def buttonC_wasPressed():
  if volume &gt; 1:
    volume = 1
  else:
    volume = volume + 0.1
    rectWidth = rectWidth + 22
  displayVolume()
  pass
btnC.wasPressed(buttonC_wasPressed)
volume = 0.5
label6.hide()
label7.hide()
rectWidth = 110
while True:
  wait_ms(2)
]]></description><link>https://community.m5stack.com/topic/1666/esp-now-project-sender-reporting-temperature-to-receiver</link><generator>RSS for Node</generator><lastBuildDate>Thu, 07 May 2026 18:03:46 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/1666.rss" rel="self" type="application/rss+xml"/><pubDate>Fri, 31 Jan 2020 14:28:03 GMT</pubDate><ttl>60</ttl></channel></rss>
