<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[How to recharge the battery]]></title><description><![CDATA[<p dir="auto">I just get my first M5StickC and I am wondering how to recharge the internal battery?</p>
<p dir="auto">I try to connect to a USB IPhone 5v plug for 3 hours but I just get 5 minutes run time.</p>
<p dir="auto">What do you recommend and how do you know when the battery is full?</p>
]]></description><link>https://community.m5stack.com/topic/1667/how-to-recharge-the-battery</link><generator>RSS for Node</generator><lastBuildDate>Wed, 29 Apr 2026 18:40:21 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/1667.rss" rel="self" type="application/rss+xml"/><pubDate>Fri, 31 Jan 2020 18:29:23 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to How to recharge the battery on Sun, 02 Feb 2020 21:26:43 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/skink" aria-label="Profile: skink">@<bdi>skink</bdi></a><br />
Can you test with <a href="https://github.com/mdevel1/M5StickC_Battery_Monitor" target="_blank" rel="noopener noreferrer nofollow ugc">https://github.com/mdevel1/M5StickC_Battery_Monitor</a>? The best would be logging the data via a serial port and uploading it to a file sharing site (with a complete charge/discharge cycle). I plan on adding some graphing (first on desktop, then on device) to the project in my (not enough) free time.</p>
]]></description><link>https://community.m5stack.com/post/7291</link><guid isPermaLink="true">https://community.m5stack.com/post/7291</guid><dc:creator><![CDATA[mdevel1]]></dc:creator><pubDate>Sun, 02 Feb 2020 21:26:43 GMT</pubDate></item><item><title><![CDATA[Reply to How to recharge the battery on Sat, 01 Feb 2020 19:05:58 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/world101" aria-label="Profile: world101">@<bdi>world101</bdi></a></p>
<p dir="auto">No WiFi connected</p>
]]></description><link>https://community.m5stack.com/post/7278</link><guid isPermaLink="true">https://community.m5stack.com/post/7278</guid><dc:creator><![CDATA[Skink]]></dc:creator><pubDate>Sat, 01 Feb 2020 19:05:58 GMT</pubDate></item><item><title><![CDATA[Reply to How to recharge the battery on Sat, 01 Feb 2020 11:56:20 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/skink" aria-label="Profile: skink">@<bdi>skink</bdi></a><br />
Was WiFi connected during your test?</p>
]]></description><link>https://community.m5stack.com/post/7272</link><guid isPermaLink="true">https://community.m5stack.com/post/7272</guid><dc:creator><![CDATA[world101]]></dc:creator><pubDate>Sat, 01 Feb 2020 11:56:20 GMT</pubDate></item><item><title><![CDATA[Reply to How to recharge the battery on Sat, 01 Feb 2020 11:52:52 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/jean-claude" aria-label="Profile: Jean-Claude">@<bdi>Jean-Claude</bdi></a><br />
So the M5Stick C has just switched off, I measured a runtime of 51 minutes. Only the M5Stick C was running without additional hardware with the display turned on but with fixed text displayed. Charge current is now 0.17A again after reconnecting it.</p>
]]></description><link>https://community.m5stack.com/post/7271</link><guid isPermaLink="true">https://community.m5stack.com/post/7271</guid><dc:creator><![CDATA[Skink]]></dc:creator><pubDate>Sat, 01 Feb 2020 11:52:52 GMT</pubDate></item><item><title><![CDATA[Reply to How to recharge the battery on Sat, 01 Feb 2020 10:47:05 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/jean-claude" aria-label="Profile: Jean-Claude">@<bdi>Jean-Claude</bdi></a><br />
I'm currently testing the runtime of the M5Stick C and as I said, I loaded it via this adapter.<br />
At the beginning of the charge the M5Stick C had a charge current of 0.17A.<br />
At the end of the charge the M5Stick C had 0.07A charge current.<br />
Now I let it run with the display switched on.<br />
At the moment I'm at 22 minutes running time with the built-in battery !!<br />
But I will report later when it has switched off.</p>
]]></description><link>https://community.m5stack.com/post/7270</link><guid isPermaLink="true">https://community.m5stack.com/post/7270</guid><dc:creator><![CDATA[Skink]]></dc:creator><pubDate>Sat, 01 Feb 2020 10:47:05 GMT</pubDate></item><item><title><![CDATA[Reply to How to recharge the battery on Sat, 01 Feb 2020 09:38:18 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/skink" aria-label="Profile: skink">@<bdi>skink</bdi></a> Thanks for your answer</p>
]]></description><link>https://community.m5stack.com/post/7269</link><guid isPermaLink="true">https://community.m5stack.com/post/7269</guid><dc:creator><![CDATA[Jean-Claude]]></dc:creator><pubDate>Sat, 01 Feb 2020 09:38:18 GMT</pubDate></item><item><title><![CDATA[Reply to How to recharge the battery on Fri, 31 Jan 2020 19:07:29 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/jean-claude" aria-label="Profile: Jean-Claude">@<bdi>Jean-Claude</bdi></a></p>
<p dir="auto">Hello, I always use something like this (<a href="https://www.amazon.de/RAVPower-Ladeger%C3%A4t-Ladestation-Schnellladen-Powerbank/dp/B01N4D1MZL/ref=sr_1_55?__mk_de_DE=%C3%85M%C3%85%C5%BD%C3%95%C3%91&amp;keywords=USb+Lader&amp;qid=1580497238&amp;sr=8-55" target="_blank" rel="noopener noreferrer nofollow ugc">https://www.amazon.de/RAVPower-Ladegerät-Ladestation-Schnellladen-Powerbank/dp/B01N4D1MZL/ref=sr_1_55?__mk_de_DE=ÅMÅŽÕÑ&amp;keywords=USb+Lader&amp;qid=1580497238&amp;sr=8-55</a>) but your IPhone charger is sufficient.<br />
But I still connect this part between the charger and the M5Stick C (<a href="https://www.amazon.de/s?k=usb+charging" target="_blank" rel="noopener noreferrer nofollow ugc">https://www.amazon.de/s?k=usb+charging</a> current+display&amp;__mk_en_DE=%C3%85M%C3%85%C5%BD%C3%95%C3%91&amp;crid=31WZ0F6G6OJ1T&amp;sprefix=USb+charging current%2Caps%2C163&amp;ref=nb_sb_ss_i_2_13) so you can see how much charging current is flowing. And you can see when no or very little current is flowing that the M5Stick C is fully charged. But it could still be that the charging current of your IPhone 5V plug charger is too low !?</p>
<p dir="auto">And please remember that if you have the display on all the time, it is a real power guzzler.<br />
After all, the M5Stick C has only an 80mAh battery installed !</p>
]]></description><link>https://community.m5stack.com/post/7267</link><guid isPermaLink="true">https://community.m5stack.com/post/7267</guid><dc:creator><![CDATA[Skink]]></dc:creator><pubDate>Fri, 31 Jan 2020 19:07:29 GMT</pubDate></item></channel></rss>
