<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[How to drive APA102 FastLED through Pa.HUB port extender?]]></title><description><![CDATA[<p dir="auto">Hello all together,<br />
I’m new with the M5 ecosystem and very inspired from this devices.</p>
<p dir="auto">Now I’m working on a project to control an APA102 digital LED stripe by two TOF distance sensors by Arduino. The APA102 and the two TOF sensors are connected by a PaHUB to a M5stickC Grove port. I’s no problem to read the distances from this sensors through the port extender.</p>
<p dir="auto">But how I can tell to the FastLED library to use the two I/O pins of the PaHUB Ch.0 to drive the LED stripe?</p>
<p dir="auto">Thank you very much for any hints.</p>
<p dir="auto">Greetings from Berlin in Germany<br />
Vaiolux</p>
<p dir="auto">My code:</p>
<pre><code>// the setup routine runs once when M5Stack starts up
#include &lt;M5StickC.h&gt;
#include &lt;Wire.h&gt;
#include &lt;FastLED.h&gt;
// Defines for VL53L0X TOF sensor
#define VL53L0X_REG_IDENTIFICATION_MODEL_ID         0xc0
#define VL53L0X_REG_IDENTIFICATION_REVISION_ID      0xc2
#define VL53L0X_REG_PRE_RANGE_CONFIG_VCSEL_PERIOD   0x50
#define VL53L0X_REG_FINAL_RANGE_CONFIG_VCSEL_PERIOD 0x70
#define VL53L0X_REG_SYSRANGE_START                  0x00
#define VL53L0X_REG_RESULT_INTERRUPT_STATUS         0x13
#define VL53L0X_REG_RESULT_RANGE_STATUS             0x14
#define address 0x29                                         //the iic address of tof
byte gbuf[16];
uint16_t distance1 = 0;
uint16_t distance2 = 0;
// Defines for Pa.HUB
#define PaHub_I2C_ADDRESS 0X77
// Defines for FastLED
// Use if you want to force the software SPI subsystem to be used for some reason (generally, you don't)
#define FASTLED_FORCE_SOFTWARE_SPI
// Use if you want to force non-accelerated pin access (hint: you really don't, it breaks lots of things)
// #define FASTLED_FORCE_SOFTWARE_SPI
// #define FASTLED_FORCE_SOFTWARE_PINS
// Defines for APA102 LED strip
#define NUM_LEDS 10    // How many leds are in the strip?
#define DATA_PIN 32    // Data pin that led data will be written out over
#define CLOCK_PIN 33   // Clock pin only needed for SPI based chipsets when not using hardware SPI
CRGB leds[NUM_LEDS];   // This is an array of leds.  One item for each led in your strip.
 M5.begin();          // Initialize the M5Stack object
 Wire.begin();        // join i2c bus (address optional for master)
 // Uncomment one of the following lines for your leds arrangement.
 FastLED.addLeds&lt;APA102, DATA_PIN, CLOCK_PIN, BGR&gt;(leds, NUM_LEDS);
 //FastLED.addLeds&lt;APA102, DATA_PIN, CLOCK_PIN, BGR, DATA_RATE_MHZ(12)&gt;(leds, NUM_LEDS);
 // LCD display
 M5.Lcd.setRotation(1);
 M5.Lcd.setTextSize(2);
 M5.Lcd.setTextColor(BLACK);
void portselectall(uint8_t ports) {
 Wire.beginTransmission(PaHub_I2C_ADDRESS);
 Wire.write(ports&amp;0x3f);
 Wire.endTransmission();
void portselect(uint8_t i) {
 if (i &gt; 7) return;
 Wire.write(1 &lt;&lt; i);
void led_strip() {
  // Move a single  led
  for(int LedPix = 0; LedPix &lt; NUM_LEDS; LedPix = LedPix + 1) {
     leds[LedPix] = CRGB::HotPink;
     FastLED.setBrightness(50);
     // Show the leds (only one)
     FastLED.show();
     // Wait a little bit
     delay(50);
     // Turn our current led back to black for the next loop around
     leds[LedPix] = CRGB::Black;
 portselect(1);        //Hub range is 0 to 5
 delay(10);
 distance1 = tof_reed();
 portselect(2);        //Hub range is 0 to 5
 delay(10);
 distance2 = tof_reed();
 M5.Lcd.fillScreen(0xFF8000);
 M5.Lcd.setCursor(0, 0, 1);
 M5.Lcd.printf("D1:%d ",distance1);
 M5.Lcd.setCursor(0, 15, 1);
 M5.Lcd.printf("D2:%d ",distance2);
 portselect(0);        //Hub range is 0 to 5
 delay(10);
 led_strip();
]]></description><link>https://community.m5stack.com/topic/1678/how-to-drive-apa102-fastled-through-pa-hub-port-extender</link><generator>RSS for Node</generator><lastBuildDate>Sun, 03 May 2026 18:43:15 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/1678.rss" rel="self" type="application/rss+xml"/><pubDate>Tue, 04 Feb 2020 22:48:16 GMT</pubDate><ttl>60</ttl></channel></rss>
