<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[M5 Stickc Arduino samples - Temperature reading issue]]></title><description><![CDATA[<p dir="auto">Hi,</p>
<p dir="auto">At room temperature when I run the samples(Factory Test ) for the M5Stickc, the temperature is being displayed as 57/58+ etc., This is certainly incorrect.</p>
<p dir="auto">anyone facing similar issue.?</p>
]]></description><link>https://community.m5stack.com/topic/1684/m5-stickc-arduino-samples-temperature-reading-issue</link><generator>RSS for Node</generator><lastBuildDate>Wed, 29 Apr 2026 06:47:46 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/1684.rss" rel="self" type="application/rss+xml"/><pubDate>Sun, 09 Feb 2020 09:43:03 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to M5 Stickc Arduino samples - Temperature reading issue on Tue, 07 Apr 2020 13:46:56 GMT]]></title><description><![CDATA[<p dir="auto">It will be best if the sensor is connected 5-10cm away from the device.  The sensor connected directly to the connector will be heated by the device through paths and goldpins and you can not help it.</p>
<p dir="auto">As far as dht11 / 12 is concerned, I already subtract these 2-3 degrees in the program from the read temperature, which are overstated.  But you have to check it yourself experimentally if the result is overstated with any other sensor in the temperature range you want to measure.</p>
<p dir="auto">Unfortunately, I don't have dht22, so I won't tell you anything specific about its accuracy or results.</p>
]]></description><link>https://community.m5stack.com/post/8051</link><guid isPermaLink="true">https://community.m5stack.com/post/8051</guid><dc:creator><![CDATA[robalstona]]></dc:creator><pubDate>Tue, 07 Apr 2020 13:46:56 GMT</pubDate></item><item><title><![CDATA[Reply to M5 Stickc Arduino samples - Temperature reading issue on Tue, 07 Apr 2020 09:48:14 GMT]]></title><description><![CDATA[<p dir="auto">Hi all,<br />
<a class="plugin-mentions-user plugin-mentions-a" href="/user/robalstona" aria-label="Profile: robalstona">@<bdi>robalstona</bdi></a> have you found a fix ? also i have the <a href="http://community.m5stack.com/topic/1816/measurements-temp-humi-by-dht12-on-env-hat" target="_blank" rel="noopener noreferrer nofollow ugc">same problem</a> and i would like to know if i need to use ENV Hat / ENV Unit / DHT22 Grove to have a good measurement</p>
]]></description><link>https://community.m5stack.com/post/8049</link><guid isPermaLink="true">https://community.m5stack.com/post/8049</guid><dc:creator><![CDATA[armbas]]></dc:creator><pubDate>Tue, 07 Apr 2020 09:48:14 GMT</pubDate></item><item><title><![CDATA[Reply to M5 Stickc Arduino samples - Temperature reading issue on Mon, 24 Feb 2020 10:23:56 GMT]]></title><description><![CDATA[<p dir="auto">If the sensor is connected directly to the connector, the heat "passes" over the connector and additionally heats the sensor. The stick during normal operation heats up quite strongly which can be felt with a bare hand. The second thing is that the DHT11 / 12 sensors still increase the temperature reading by 2/3 degrees at least compared to the ds18b20 sensor.</p>
]]></description><link>https://community.m5stack.com/post/7561</link><guid isPermaLink="true">https://community.m5stack.com/post/7561</guid><dc:creator><![CDATA[robalstona]]></dc:creator><pubDate>Mon, 24 Feb 2020 10:23:56 GMT</pubDate></item><item><title><![CDATA[Reply to M5 Stickc Arduino samples - Temperature reading issue on Mon, 24 Feb 2020 05:45:42 GMT]]></title><description><![CDATA[<p dir="auto">Nice work proving the issue.</p>
]]></description><link>https://community.m5stack.com/post/7557</link><guid isPermaLink="true">https://community.m5stack.com/post/7557</guid><dc:creator><![CDATA[ajb2k3]]></dc:creator><pubDate>Mon, 24 Feb 2020 05:45:42 GMT</pubDate></item><item><title><![CDATA[Reply to M5 Stickc Arduino samples - Temperature reading issue on Sun, 23 Feb 2020 21:05:20 GMT]]></title><description><![CDATA[<p dir="auto">I can confirm that it is related to the radiation from the M5StickC. When I connect the ENV-HAT with cables away from the stick, the sensor measures reasonable values.</p>
<p dir="auto">Incorrect values if the ENV-HAT is directly connected:<br />
<img src="https://i.imgur.com/2SBCbiU.jpg" alt="Wrong values" class=" img-fluid img-markdown" /></p>
<p dir="auto">Correct values if the ENV-HAT is connected via a cable extension:<br />
<img src="https://i.imgur.com/6Ryt311.jpg" alt="Correct values" class=" img-fluid img-markdown" /></p>
<p dir="auto"><img src="https://i.imgur.com/mk6jdAF.jpg" alt="Correct values" class=" img-fluid img-markdown" /></p>
]]></description><link>https://community.m5stack.com/post/7555</link><guid isPermaLink="true">https://community.m5stack.com/post/7555</guid><dc:creator><![CDATA[hague]]></dc:creator><pubDate>Sun, 23 Feb 2020 21:05:20 GMT</pubDate></item><item><title><![CDATA[Reply to M5 Stickc Arduino samples - Temperature reading issue on Wed, 12 Feb 2020 07:12:36 GMT]]></title><description><![CDATA[<p dir="auto">Hi ,  what sensor are you used?  ENV Unit? ENV HAT?</p>
]]></description><link>https://community.m5stack.com/post/7361</link><guid isPermaLink="true">https://community.m5stack.com/post/7361</guid><dc:creator><![CDATA[m5stack]]></dc:creator><pubDate>Wed, 12 Feb 2020 07:12:36 GMT</pubDate></item><item><title><![CDATA[Reply to M5 Stickc Arduino samples - Temperature reading issue on Tue, 11 Feb 2020 05:43:38 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/m5stickuser" aria-label="Profile: m5stickuser">@<bdi>m5stickuser</bdi></a> said in <a href="/post/7327">M5 Stickc Arduino samples - Temperature reading issue</a>:</p>
<p dir="auto">Yes.<br />
we are not sure where the issue is but it could be heat generated by the stick causing the inaccuracies.</p>
]]></description><link>https://community.m5stack.com/post/7349</link><guid isPermaLink="true">https://community.m5stack.com/post/7349</guid><dc:creator><![CDATA[ajb2k3]]></dc:creator><pubDate>Tue, 11 Feb 2020 05:43:38 GMT</pubDate></item></channel></rss>
