<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Upload error w Arduino IDE - A fatal error... Timed out waiting for packet header]]></title><description><![CDATA[<p dir="auto">Hi M5Stack C sitting on win 10 (Dell XPS 15), COM5. EasyLoader looks to connect and work fine. But, Arduino IDE runs into this problem when trying to upload a sketch("Hello World").</p>
<p dir="auto">I have tried different things, like connecting GND-G0 and 3V3-G0. No success.</p>
<p dir="auto">Messages:<br />
Sketch uses 254233 bytes (19%) of program storage space. Maximum is 1310720 bytes.<br />
Global variables use 16676 bytes (5%) of dynamic memory, leaving 311004 bytes for local variables. Maximum is 327680 bytes.<br />
<a href="http://esptool.py" target="_blank" rel="noopener noreferrer nofollow ugc">esptool.py</a> v2.6<br />
Serial port COM5<br />
Connecting.....<br />
Chip is ESP32-PICO-D4 (revision 1)<br />
Features: WiFi, BT, Dual Core, 240MHz, Embedded Flash, VRef calibration in efuse, Coding Scheme None<br />
MAC: d8:a0:1d:56:47:60<br />
Uploading stub...<br />
Running stub...<br />
Stub running...<br />
Changing baud rate to 921600<br />
Changed.<br />
Configuring flash size...</p>
<p dir="auto">A fatal error occurred: Timed out waiting for packet header<br />
A fatal error occurred: Timed out waiting for packet header</p>
]]></description><link>https://community.m5stack.com/topic/1689/upload-error-w-arduino-ide-a-fatal-error-timed-out-waiting-for-packet-header</link><generator>RSS for Node</generator><lastBuildDate>Thu, 14 May 2026 04:16:26 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/1689.rss" rel="self" type="application/rss+xml"/><pubDate>Sun, 09 Feb 2020 20:00:43 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Upload error w Arduino IDE - A fatal error... Timed out waiting for packet header on Wed, 12 Feb 2020 06:45:05 GMT]]></title><description><![CDATA[<p dir="auto">Hi， you should selcet M5StickC board in ther board manager.   or seting the baud rate to 115200</p>
]]></description><link>https://community.m5stack.com/post/7360</link><guid isPermaLink="true">https://community.m5stack.com/post/7360</guid><dc:creator><![CDATA[m5stack]]></dc:creator><pubDate>Wed, 12 Feb 2020 06:45:05 GMT</pubDate></item><item><title><![CDATA[Reply to Upload error w Arduino IDE - A fatal error... Timed out waiting for packet header on Wed, 12 Feb 2020 05:50:10 GMT]]></title><description><![CDATA[<p dir="auto">Have you tried changing the baud rates?<br />
There are many reasons for the timeout.</p>
]]></description><link>https://community.m5stack.com/post/7359</link><guid isPermaLink="true">https://community.m5stack.com/post/7359</guid><dc:creator><![CDATA[ajb2k3]]></dc:creator><pubDate>Wed, 12 Feb 2020 05:50:10 GMT</pubDate></item><item><title><![CDATA[Reply to Upload error w Arduino IDE - A fatal error... Timed out waiting for packet header on Tue, 11 Feb 2020 04:10:18 GMT]]></title><description><![CDATA[<p dir="auto">That isnt a big trouble.A photo about it is helpful...<br />
you can try to dissconnect from your USB port and then reconnect and <a href="http://upload.Do" target="_blank" rel="noopener noreferrer nofollow ugc">upload.Do</a> not touch the line while you are uploading.<br />
I think you touched the USB line while uploading.</p>
]]></description><link>https://community.m5stack.com/post/7346</link><guid isPermaLink="true">https://community.m5stack.com/post/7346</guid><dc:creator><![CDATA[sysdl132]]></dc:creator><pubDate>Tue, 11 Feb 2020 04:10:18 GMT</pubDate></item></channel></rss>
