<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[UIFLOW does not save python code]]></title><description><![CDATA[<p dir="auto">UIFLOW does not save edited python code (only Blockly).<br />
If you enter any python code directly in UIFlow and save it then you will be surprised if you load the code later - it is empty!<br />
Why?<br />
Just save the code as .py-file would be great.</p>
]]></description><link>https://community.m5stack.com/topic/1702/uiflow-does-not-save-python-code</link><generator>RSS for Node</generator><lastBuildDate>Tue, 28 Apr 2026 23:04:41 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/1702.rss" rel="self" type="application/rss+xml"/><pubDate>Sun, 16 Feb 2020 10:04:35 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to UIFLOW does not save python code on Mon, 17 Feb 2020 01:02:39 GMT]]></title><description><![CDATA[<p dir="auto">Import large MicroPython scripts with UIFlow<br />
<a href="https://qiita.com/ciniml/items/68bc7f362d6985efc640" target="_blank" rel="noopener noreferrer nofollow ugc">https://qiita.com/ciniml/items/68bc7f362d6985efc640</a></p>
]]></description><link>https://community.m5stack.com/post/7443</link><guid isPermaLink="true">https://community.m5stack.com/post/7443</guid><dc:creator><![CDATA[flypeek]]></dc:creator><pubDate>Mon, 17 Feb 2020 01:02:39 GMT</pubDate></item><item><title><![CDATA[Reply to UIFLOW does not save python code on Sun, 16 Feb 2020 19:37:00 GMT]]></title><description><![CDATA[<p dir="auto">Just use vs code lol<br />
You can run uiflow dual-box to check for m5 libraries code and simply copy strings to vs code</p>
]]></description><link>https://community.m5stack.com/post/7438</link><guid isPermaLink="true">https://community.m5stack.com/post/7438</guid><dc:creator><![CDATA[Thrasher]]></dc:creator><pubDate>Sun, 16 Feb 2020 19:37:00 GMT</pubDate></item><item><title><![CDATA[Reply to UIFLOW does not save python code on Sun, 16 Feb 2020 15:45:45 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/ajb2k3" aria-label="Profile: ajb2k3">@<bdi>ajb2k3</bdi></a> said in <a href="/post/7434">UIFLOW does not save python code</a>:</p>
<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/m5stickfreakler" aria-label="Profile: m5stickfreakler">@<bdi>m5stickfreakler</bdi></a> only the blocks are saved not micropython code. This has been the same since the beginning.</p>
<p dir="auto">What will you say with that? I know it is not saving micropython code - that's the point!<br />
Again: If I have the python code in front of you and then save it, then it is not saved and you don't see that.<br />
A good UI does not allow such things.<br />
So in my opinion there are two solutions:</p>
<li>It is not possible to use the save function if switched to python code</li>
<li>or it saves a py-file if switched to python code</li>
]]></description><link>https://community.m5stack.com/post/7435</link><guid isPermaLink="true">https://community.m5stack.com/post/7435</guid><dc:creator><![CDATA[M5StickFreakler]]></dc:creator><pubDate>Sun, 16 Feb 2020 15:45:45 GMT</pubDate></item><item><title><![CDATA[Reply to UIFLOW does not save python code on Sun, 16 Feb 2020 15:33:58 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/m5stickfreakler" aria-label="Profile: m5stickfreakler">@<bdi>m5stickfreakler</bdi></a> only the blocks are saved not micropython code. This has been the same since the beginning.</p>
]]></description><link>https://community.m5stack.com/post/7434</link><guid isPermaLink="true">https://community.m5stack.com/post/7434</guid><dc:creator><![CDATA[ajb2k3]]></dc:creator><pubDate>Sun, 16 Feb 2020 15:33:58 GMT</pubDate></item><item><title><![CDATA[Reply to UIFLOW does not save python code on Sun, 16 Feb 2020 15:07:45 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sysdl132" aria-label="Profile: sysdl132">@<bdi>sysdl132</bdi></a> said in <a href="/post/7420">UIFLOW does not save python code</a>:</p>
<p dir="auto">If you want to download visual studio,<a href="https://visualstudio.microsoft.com/en/thank-you-downloading-visual-studio/?sku=Professional&amp;rel=16#" target="_blank" rel="noopener noreferrer nofollow ugc">click me</a></p>
<p dir="auto">No problem, already installed (I'm a developer). Its just dangerous if someone save a file in UiFlow and then nothing is in it. So maybe m5stack should disable the save button if you are in py-code. :-)</p>
]]></description><link>https://community.m5stack.com/post/7421</link><guid isPermaLink="true">https://community.m5stack.com/post/7421</guid><dc:creator><![CDATA[M5StickFreakler]]></dc:creator><pubDate>Sun, 16 Feb 2020 15:07:45 GMT</pubDate></item><item><title><![CDATA[Reply to UIFLOW does not save python code on Sun, 16 Feb 2020 12:57:10 GMT]]></title><description><![CDATA[<p dir="auto">If you want to download visual studio,<a href="https://visualstudio.microsoft.com/en/thank-you-downloading-visual-studio/?sku=Professional&amp;rel=16#" target="_blank" rel="noopener noreferrer nofollow ugc">click me</a></p>
]]></description><link>https://community.m5stack.com/post/7420</link><guid isPermaLink="true">https://community.m5stack.com/post/7420</guid><dc:creator><![CDATA[sysdl132]]></dc:creator><pubDate>Sun, 16 Feb 2020 12:57:10 GMT</pubDate></item><item><title><![CDATA[Reply to UIFLOW does not save python code on Sun, 16 Feb 2020 12:48:21 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sysdl132" aria-label="Profile: sysdl132">@<bdi>sysdl132</bdi></a> Yes, but it is confusing because I can save it, but nothing is saved :-)</p>
]]></description><link>https://community.m5stack.com/post/7419</link><guid isPermaLink="true">https://community.m5stack.com/post/7419</guid><dc:creator><![CDATA[M5StickFreakler]]></dc:creator><pubDate>Sun, 16 Feb 2020 12:48:21 GMT</pubDate></item><item><title><![CDATA[Reply to UIFLOW does not save python code on Sun, 16 Feb 2020 12:36:05 GMT]]></title><description><![CDATA[<p dir="auto">The only way to get custom code to save within UIFlow is to...</p>
<li>add it to the Execute block (under Advanced)</li>
<li>Create your own custom blocks with <a href="http://block-maker.m5stack.com/" target="_blank" rel="noopener noreferrer nofollow ugc">http://block-maker.m5stack.com/</a></li>
]]></description><link>https://community.m5stack.com/post/7418</link><guid isPermaLink="true">https://community.m5stack.com/post/7418</guid><dc:creator><![CDATA[world101]]></dc:creator><pubDate>Sun, 16 Feb 2020 12:36:05 GMT</pubDate></item><item><title><![CDATA[Reply to UIFLOW does not save python code on Sun, 16 Feb 2020 11:51:56 GMT]]></title><description><![CDATA[<p dir="auto">UIFlow cannot save python code.You can save .py file in visual studio.</p>
]]></description><link>https://community.m5stack.com/post/7417</link><guid isPermaLink="true">https://community.m5stack.com/post/7417</guid><dc:creator><![CDATA[sysdl132]]></dc:creator><pubDate>Sun, 16 Feb 2020 11:51:56 GMT</pubDate></item><item><title><![CDATA[Reply to UIFLOW does not save python code on Sun, 16 Feb 2020 11:37:16 GMT]]></title><description><![CDATA[<p dir="auto">Yes, its been so since beginning. We hope it will be implented soon</p>
]]></description><link>https://community.m5stack.com/post/7416</link><guid isPermaLink="true">https://community.m5stack.com/post/7416</guid><dc:creator><![CDATA[Thrasher]]></dc:creator><pubDate>Sun, 16 Feb 2020 11:37:16 GMT</pubDate></item></channel></rss>
