<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[M5 camera board and TTGO camera?]]></title><description><![CDATA[<p dir="auto">Anyone know it they can be used together?<br />
Either directly or by remapping pins?<br />
I need a longer flat cable.<br />
Thanks.</p>
]]></description><link>https://community.m5stack.com/topic/1717/m5-camera-board-and-ttgo-camera</link><generator>RSS for Node</generator><lastBuildDate>Fri, 01 May 2026 11:27:28 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/1717.rss" rel="self" type="application/rss+xml"/><pubDate>Fri, 21 Feb 2020 07:07:16 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to M5 camera board and TTGO camera? on Thu, 27 Feb 2020 02:41:22 GMT]]></title><description><![CDATA[<p dir="auto">Maybe TTGO can work with m5stack.I only used TTGO T-Watch.</p>
]]></description><link>https://community.m5stack.com/post/7585</link><guid isPermaLink="true">https://community.m5stack.com/post/7585</guid><dc:creator><![CDATA[sysdl132]]></dc:creator><pubDate>Thu, 27 Feb 2020 02:41:22 GMT</pubDate></item><item><title><![CDATA[Reply to M5 camera board and TTGO camera? on Wed, 26 Feb 2020 06:43:51 GMT]]></title><description><![CDATA[<p dir="auto">Thank you, thats it :)<br />
Had a quick look and seems it might be possible, the TTGO camera is 26-pin but that seems to be the only major difference and since it's just a pair of extra GND it should be possible to just cut them. The power connections seem to be in the same places.<br />
To twist this  post in another direction, Does M5Stack have any plans for a camera with longer ribbon?<br />
I know there are extensions too but they are bulky.<br />
Thanks</p>
]]></description><link>https://community.m5stack.com/post/7574</link><guid isPermaLink="true">https://community.m5stack.com/post/7574</guid><dc:creator><![CDATA[Net-time]]></dc:creator><pubDate>Wed, 26 Feb 2020 06:43:51 GMT</pubDate></item><item><title><![CDATA[Reply to M5 camera board and TTGO camera? on Wed, 26 Feb 2020 01:53:33 GMT]]></title><description><![CDATA[<p dir="auto">There is a schematic for the esp32 cam in the schematics repo on our github <a href="https://github.com/m5stack/M5-Schematic/blob/master/Units/esp32-cam/M5CAM-ESP32-A1-POWER.pdf" target="_blank" rel="noopener noreferrer nofollow ugc">https://github.com/m5stack/M5-Schematic/blob/master/Units/esp32-cam/M5CAM-ESP32-A1-POWER.pdf</a></p>
]]></description><link>https://community.m5stack.com/post/7572</link><guid isPermaLink="true">https://community.m5stack.com/post/7572</guid><dc:creator><![CDATA[lukasmaximus]]></dc:creator><pubDate>Wed, 26 Feb 2020 01:53:33 GMT</pubDate></item><item><title><![CDATA[Reply to M5 camera board and TTGO camera? on Tue, 25 Feb 2020 12:33:00 GMT]]></title><description><![CDATA[<p dir="auto">As I said above I need a longer ribbon cable, The M5stack camera is perfect otherwise as it is the slimmest product available,<br />
has a build in charger and programming interface.<br />
But the ribbon cable is to short for me to place where I want. ( Inside a HO scale locomotive)<br />
So yes I'm Talking about the connector for the ribbon cable, and I know I'ts the same camera module.<br />
What I do not know is if the M5Stack ribbon cable are connected in the same order on the ov2640 as TTGO's,<br />
as the ribbon cable possibly is custom made to either's specification?<br />
<a href="https://docs.m5stack.com/#/en/unit/esp32cam" target="_blank" rel="noopener noreferrer nofollow ugc">https://docs.m5stack.com/#/en/unit/esp32cam</a> does not include a connector pinout( by numbers).</p>
<p dir="auto">/Net-Time</p>
]]></description><link>https://community.m5stack.com/post/7566</link><guid isPermaLink="true">https://community.m5stack.com/post/7566</guid><dc:creator><![CDATA[Net-time]]></dc:creator><pubDate>Tue, 25 Feb 2020 12:33:00 GMT</pubDate></item><item><title><![CDATA[Reply to M5 camera board and TTGO camera? on Mon, 24 Feb 2020 12:06:45 GMT]]></title><description><![CDATA[<p dir="auto">Are you talking about the ribbon cable connecting the camera component to the circuit board? Not quite sure why you would want to swap the camera unless its broken as the esp32 camera board <a href="https://docs.m5stack.com/#/en/unit/esp32cam" target="_blank" rel="noopener noreferrer nofollow ugc">https://docs.m5stack.com/#/en/unit/esp32cam</a> m5camera <a href="https://docs.m5stack.com/#/en/unit/m5camera" target="_blank" rel="noopener noreferrer nofollow ugc">https://docs.m5stack.com/#/en/unit/m5camera</a> and ttgo all use ov2640 the exact same camera module</p>
]]></description><link>https://community.m5stack.com/post/7562</link><guid isPermaLink="true">https://community.m5stack.com/post/7562</guid><dc:creator><![CDATA[lukasmaximus]]></dc:creator><pubDate>Mon, 24 Feb 2020 12:06:45 GMT</pubDate></item><item><title><![CDATA[Reply to M5 camera board and TTGO camera? on Sun, 23 Feb 2020 17:03:39 GMT]]></title><description><![CDATA[<p dir="auto">Do you perhaps have the pinout for the camera connector then so I can check for myself?</p>
<p dir="auto">Thanks.</p>
]]></description><link>https://community.m5stack.com/post/7552</link><guid isPermaLink="true">https://community.m5stack.com/post/7552</guid><dc:creator><![CDATA[Net-time]]></dc:creator><pubDate>Sun, 23 Feb 2020 17:03:39 GMT</pubDate></item><item><title><![CDATA[Reply to M5 camera board and TTGO camera? on Sun, 23 Feb 2020 12:18:30 GMT]]></title><description><![CDATA[<p dir="auto">Since TTGO is not an M5Stack product we cannot provide support for it I'm afraid</p>
]]></description><link>https://community.m5stack.com/post/7545</link><guid isPermaLink="true">https://community.m5stack.com/post/7545</guid><dc:creator><![CDATA[lukasmaximus]]></dc:creator><pubDate>Sun, 23 Feb 2020 12:18:30 GMT</pubDate></item></channel></rss>
