<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[fixed background image]]></title><description><![CDATA[<p dir="auto">Is there a method to fix a background image?  I load an image (320x240).  I have a circle on the screen that moves with angular movement of the m5Stack, but the circle erases the background image where ever it moves across it.  I have tried changing the layer level - this does not work.  I have also tried refreshing the screen, but this causes a horrible flickering.  Any ideas?</p>
<p dir="auto">Thank you!</p>
]]></description><link>https://community.m5stack.com/topic/1719/fixed-background-image</link><generator>RSS for Node</generator><lastBuildDate>Wed, 29 Apr 2026 04:59:40 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/1719.rss" rel="self" type="application/rss+xml"/><pubDate>Fri, 21 Feb 2020 21:36:57 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to fixed background image on Sat, 29 Feb 2020 04:39:50 GMT]]></title><description><![CDATA[<p dir="auto"><a href="https://github.com/sysdl132/tetris" target="_blank" rel="noopener noreferrer nofollow ugc"><img src="/assets/uploads/files/1582950983695-8433b3b0-3224-43f6-84f9-0a9a5c2e6030-image.png" alt="0_1582950984019_8433b3b0-3224-43f6-84f9-0a9a5c2e6030-image.png" class=" img-fluid img-markdown" /> </a><br />
it can display images without eraseing.<br />
(click OK)</p>
]]></description><link>https://community.m5stack.com/post/7619</link><guid isPermaLink="true">https://community.m5stack.com/post/7619</guid><dc:creator><![CDATA[sysdl132]]></dc:creator><pubDate>Sat, 29 Feb 2020 04:39:50 GMT</pubDate></item><item><title><![CDATA[Reply to fixed background image on Sun, 23 Feb 2020 12:11:05 GMT]]></title><description><![CDATA[<p dir="auto">Unfortunately I think this is unresolvable if you are using blockly. I believe the circle needs to be a sprite in order to avoid this issue, You could check out this out if you are trying to make a game <a href="https://www.hackster.io/deshipu/stage-a-tile-and-sprite-engine-e9e655" target="_blank" rel="noopener noreferrer nofollow ugc">https://www.hackster.io/deshipu/stage-a-tile-and-sprite-engine-e9e655</a></p>
]]></description><link>https://community.m5stack.com/post/7542</link><guid isPermaLink="true">https://community.m5stack.com/post/7542</guid><dc:creator><![CDATA[lukasmaximus]]></dc:creator><pubDate>Sun, 23 Feb 2020 12:11:05 GMT</pubDate></item></channel></rss>
