<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Integrate into a &quot;dock&quot; or bench?]]></title><description><![CDATA[<p dir="auto">Hi, I just learned of the m5 stack system and am excited because it seems I won't need to build and program the UI like I have for prior projects. Just a couple buttons can add days to a prototype!</p>
<p dir="auto">I envision a testing bench with a core, face, and joystick module.</p>
<li>Is it possible to also add the USB module with core and face?</li>
<li>Does it go above the face and below the core?</li>
<li>USB module also has general IO pins? (I may interface with a stepper motor driver, etc)</li>
<p dir="auto">This bench it would affix to, I will create and it will hold the face and supply power, too. I have built test benches with <a href="https://hackaday.io/project/3755-throttle-position-sensor-test-bench" target="_blank" rel="noopener noreferrer nofollow ugc">chipKIT</a> and <a href="https://www.facebook.com/cacycleworks/photos/a.10156239639106366/10156339666461366/?type=3&amp;theater" target="_blank" rel="noopener noreferrer nofollow ugc">ESP32</a> and wish I have used m5 Stack, which looks like will be my favorite going forward.</p>
<p dir="auto">Thanks!<br />
Chris</p>
]]></description><link>https://community.m5stack.com/topic/1724/integrate-into-a-dock-or-bench</link><generator>RSS for Node</generator><lastBuildDate>Tue, 28 Apr 2026 22:34:09 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/1724.rss" rel="self" type="application/rss+xml"/><pubDate>Tue, 25 Feb 2020 22:37:49 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Integrate into a &quot;dock&quot; or bench? on Thu, 27 Feb 2020 01:49:25 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/technerdchris" aria-label="Profile: technerdchris">@<bdi>technerdchris</bdi></a> yes , USB module go on top of the FACES and under the Core , then stack they together</p>
]]></description><link>https://community.m5stack.com/post/7583</link><guid isPermaLink="true">https://community.m5stack.com/post/7583</guid><dc:creator><![CDATA[m5stack]]></dc:creator><pubDate>Thu, 27 Feb 2020 01:49:25 GMT</pubDate></item><item><title><![CDATA[Reply to Integrate into a &quot;dock&quot; or bench? on Wed, 26 Feb 2020 16:43:19 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/m5stack" aria-label="Profile: m5stack">@<bdi>m5stack</bdi></a> does the USB module go on top of the FACES and under the Core?</p>
<p dir="auto">Yes, I would use an intermediate driver for the stepper itself and use the MCU + USB module to send signals. I mostly assume MCU pins do not do any work beyond to send/receive signals. ESP project above uses 3.3V relay to switch 12VDC. The chipKIT project referenced above uses Sparkfun Easy Driver product. Another application with a more hefty stepper uses "Rugger Circuits" designed Rugged Motor Driver shield.</p>
<p dir="auto">Thanks,<br />
Chris</p>
]]></description><link>https://community.m5stack.com/post/7580</link><guid isPermaLink="true">https://community.m5stack.com/post/7580</guid><dc:creator><![CDATA[technerdchris]]></dc:creator><pubDate>Wed, 26 Feb 2020 16:43:19 GMT</pubDate></item><item><title><![CDATA[Reply to Integrate into a &quot;dock&quot; or bench? on Wed, 26 Feb 2020 07:32:17 GMT]]></title><description><![CDATA[<p dir="auto">Yes. You can stack "FACES Bottom + FACSE joystick panel + USB module + Core". The USB module has many IO pins. You can use them to program high or low digital signals. But you are not sure if it has the ability to drive a stepper motor. You can refer to its data sheet for this.</p>
<p dir="auto">USB Module MAX3421E- datasheet link: <a href="https://m5stack.oss-cn-shenzhen.aliyuncs.com/resource/docs/datasheet/module/MAX3421E_en.pdf" target="_blank" rel="noopener noreferrer nofollow ugc">https://m5stack.oss-cn-shenzhen.aliyuncs.com/resource/docs/datasheet/module/MAX3421E_en.pdf</a></p>
]]></description><link>https://community.m5stack.com/post/7575</link><guid isPermaLink="true">https://community.m5stack.com/post/7575</guid><dc:creator><![CDATA[m5stack]]></dc:creator><pubDate>Wed, 26 Feb 2020 07:32:17 GMT</pubDate></item></channel></rss>
