<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Speed up GPS data update]]></title><description><![CDATA[<p dir="auto">Hi all,</p>
<p dir="auto">I would like to know if it is posdsible to get 10Hz refresh rate of the data with the GPS module stackable ?</p>
<p dir="auto">By default it is only 1Hz.</p>
<p dir="auto">Thanks.</p>
]]></description><link>https://community.m5stack.com/topic/1728/speed-up-gps-data-update</link><generator>RSS for Node</generator><lastBuildDate>Wed, 29 Apr 2026 22:37:10 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/1728.rss" rel="self" type="application/rss+xml"/><pubDate>Thu, 27 Feb 2020 18:03:45 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Speed up GPS data update on Mon, 10 Jul 2023 12:15:58 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/ekalfwons" aria-label="Profile: ekalfwons">@<bdi>ekalfwons</bdi></a> : Hi, I'm struggeling now at the same point. Do you have a solution after that time now?<br />
Cheers,<br />
Olaf</p>
]]></description><link>https://community.m5stack.com/post/21538</link><guid isPermaLink="true">https://community.m5stack.com/post/21538</guid><dc:creator><![CDATA[osioli]]></dc:creator><pubDate>Mon, 10 Jul 2023 12:15:58 GMT</pubDate></item><item><title><![CDATA[Reply to Speed up GPS data update on Tue, 21 Apr 2020 17:40:24 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/m5stack" aria-label="Profile: m5stack">@<bdi>m5stack</bdi></a> It would be good if there was some documentation explaining how to use the M5Stack to do the transparent transmission.  Could that be added to the GPS Module product page, or linked from it?  Right now there's a link to the software but no indication how one would use it with the GPS module.</p>
]]></description><link>https://community.m5stack.com/post/8297</link><guid isPermaLink="true">https://community.m5stack.com/post/8297</guid><dc:creator><![CDATA[ekalfwonS]]></dc:creator><pubDate>Tue, 21 Apr 2020 17:40:24 GMT</pubDate></item><item><title><![CDATA[Reply to Speed up GPS data update on Tue, 21 Apr 2020 10:00:37 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/ekalfwons" aria-label="Profile: ekalfwons">@<bdi>ekalfwons</bdi></a> you could connect to the M5Core then stack the GPS module(Need to configure transparent transmission) or just connect to the GPS module by USB to TTL convertor.</p>
]]></description><link>https://community.m5stack.com/post/8284</link><guid isPermaLink="true">https://community.m5stack.com/post/8284</guid><dc:creator><![CDATA[m5stack]]></dc:creator><pubDate>Tue, 21 Apr 2020 10:00:37 GMT</pubDate></item><item><title><![CDATA[Reply to Speed up GPS data update on Tue, 21 Apr 2020 04:27:32 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/m5stack" aria-label="Profile: m5stack">@<bdi>m5stack</bdi></a> can you be more specific?  What software are you referring to?  The Windows software linked to on the GPS module page (<a href="https://www.u-blox.com/en/product/u-center-windows" target="_blank" rel="noopener noreferrer nofollow ugc">https://www.u-blox.com/en/product/u-center-windows</a>)?  Can that software talk to the GPS to update it through the USB connection to the M5Stack while it's connected?</p>
]]></description><link>https://community.m5stack.com/post/8279</link><guid isPermaLink="true">https://community.m5stack.com/post/8279</guid><dc:creator><![CDATA[ekalfwonS]]></dc:creator><pubDate>Tue, 21 Apr 2020 04:27:32 GMT</pubDate></item><item><title><![CDATA[Reply to Speed up GPS data update on Tue, 21 Apr 2020 09:54:55 GMT]]></title><description><![CDATA[<p dir="auto">you can use this software to setup .    you can google able to find the refer tutorial.</p>
<p dir="auto">software link: <a href="https://www.u-blox.com/en/product/u-center" target="_blank" rel="noopener noreferrer nofollow ugc">https://www.u-blox.com/en/product/u-center</a></p>
]]></description><link>https://community.m5stack.com/post/7612</link><guid isPermaLink="true">https://community.m5stack.com/post/7612</guid><dc:creator><![CDATA[m5stack]]></dc:creator><pubDate>Tue, 21 Apr 2020 09:54:55 GMT</pubDate></item></channel></rss>
