<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[BALA - reverse direction]]></title><description><![CDATA[<p dir="auto">There is a bug in the BALA algorithm. In flow, when I use the "balance loop" command (inside a loop), the accelerometer data controls the motors in the opposite direction, thus it cannot balance, it falls always.</p>
]]></description><link>https://community.m5stack.com/topic/1735/bala-reverse-direction</link><generator>RSS for Node</generator><lastBuildDate>Sat, 02 May 2026 07:43:41 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/1735.rss" rel="self" type="application/rss+xml"/><pubDate>Sun, 01 Mar 2020 19:37:17 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to BALA - reverse direction on Mon, 02 Mar 2020 08:06:53 GMT]]></title><description><![CDATA[<p dir="auto">if your device was build-in MPU6886.   it use the ''balance loop" will be reverse direction.    so , maybe you can use the Arduino Example</p>
<p dir="auto">Github LInk:<br />
<a href="https://github.com/m5stack/M5Stack/tree/master/examples/Modules/Bala" target="_blank" rel="noopener noreferrer nofollow ugc">https://github.com/m5stack/M5Stack/tree/master/examples/Modules/Bala</a></p>
]]></description><link>https://community.m5stack.com/post/7643</link><guid isPermaLink="true">https://community.m5stack.com/post/7643</guid><dc:creator><![CDATA[m5stack]]></dc:creator><pubDate>Mon, 02 Mar 2020 08:06:53 GMT</pubDate></item></channel></rss>
