<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[M5Stack display shows everything negative or inverted]]></title><description><![CDATA[<p dir="auto">The display of my M5Stack (black) shows everything inverted or negative. Unfortunately the display remembers this setting. Also de-energizing, battery off and no USB, showed no change.<br />
In the data sheet of the ILI9342 I found a point that gives me hope: "8.2.15. Display Inversion OFF (20h)".<br />
Unfortunately I don't know how to call this command. I am using the Arduino IDE.<br />
Can someone give me an example of the transfer of commands to the M5Stack?</p>
]]></description><link>https://community.m5stack.com/topic/1736/m5stack-display-shows-everything-negative-or-inverted</link><generator>RSS for Node</generator><lastBuildDate>Sat, 02 May 2026 04:37:33 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/1736.rss" rel="self" type="application/rss+xml"/><pubDate>Sun, 01 Mar 2020 20:36:44 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to M5Stack display shows everything negative or inverted on Mon, 02 Mar 2020 09:24:44 GMT]]></title><description><![CDATA[<p dir="auto">I'm flabbergasted. It really worked. The colors are okay now.<br />
Thanks!</p>
]]></description><link>https://community.m5stack.com/post/7646</link><guid isPermaLink="true">https://community.m5stack.com/post/7646</guid><dc:creator><![CDATA[HansIm]]></dc:creator><pubDate>Mon, 02 Mar 2020 09:24:44 GMT</pubDate></item><item><title><![CDATA[Reply to M5Stack display shows everything negative or inverted on Mon, 02 Mar 2020 08:02:23 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/hansim" aria-label="Profile: hansim">@<bdi>hansim</bdi></a> pls upgrade the M5Stack lib to laster version . will fix this problem</p>
]]></description><link>https://community.m5stack.com/post/7642</link><guid isPermaLink="true">https://community.m5stack.com/post/7642</guid><dc:creator><![CDATA[m5stack]]></dc:creator><pubDate>Mon, 02 Mar 2020 08:02:23 GMT</pubDate></item></channel></rss>
