<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Input voltage and powering StickC]]></title><description><![CDATA[<p dir="auto">I have a project to control a linear actuator with a StickC and a SEEED 2 relay board.  I want to add a set of reed switches to provide feedback to my code when the window the actuator is controlling is fully open or closed.  Can I wire the reed switches directly to the StickC or do I need resistors/voltage dividers?<br />
Additionally I would like to power the StickC from the 12VDC power supply.  I have some BEC circuits but they only lower the voltage to 5vdc.  Can these be used with the StickC?  Do I connect to the BATT, 5VDC or 3.3?</p>
]]></description><link>https://community.m5stack.com/topic/1739/input-voltage-and-powering-stickc</link><generator>RSS for Node</generator><lastBuildDate>Wed, 29 Apr 2026 09:42:15 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/1739.rss" rel="self" type="application/rss+xml"/><pubDate>Tue, 03 Mar 2020 05:13:19 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Input voltage and powering StickC on Tue, 03 Mar 2020 17:26:13 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/clocey" aria-label="Profile: clocey">@<bdi>clocey</bdi></a> 5V to 5&lt;-  (pin 8) and gnd to gnd (pin1)</p>
]]></description><link>https://community.m5stack.com/post/7664</link><guid isPermaLink="true">https://community.m5stack.com/post/7664</guid><dc:creator><![CDATA[ajb2k3]]></dc:creator><pubDate>Tue, 03 Mar 2020 17:26:13 GMT</pubDate></item><item><title><![CDATA[Reply to Input voltage and powering StickC on Tue, 03 Mar 2020 13:44:19 GMT]]></title><description><![CDATA[<p dir="auto">5v input to the 5v port or the BATT port?</p>
]]></description><link>https://community.m5stack.com/post/7660</link><guid isPermaLink="true">https://community.m5stack.com/post/7660</guid><dc:creator><![CDATA[clocey]]></dc:creator><pubDate>Tue, 03 Mar 2020 13:44:19 GMT</pubDate></item><item><title><![CDATA[Reply to Input voltage and powering StickC on Tue, 03 Mar 2020 07:43:20 GMT]]></title><description><![CDATA[<p dir="auto">in the M5Stick head extension pin has 5V input , you can supply 5V power to there.</p>
]]></description><link>https://community.m5stack.com/post/7658</link><guid isPermaLink="true">https://community.m5stack.com/post/7658</guid><dc:creator><![CDATA[m5stack]]></dc:creator><pubDate>Tue, 03 Mar 2020 07:43:20 GMT</pubDate></item></channel></rss>
