<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Is it normal to lose UIFlow program after shutdown&#x2F;battery discharge?]]></title><description><![CDATA[<p dir="auto">Hey guys I'm new a M5Stick-C user, just recently got mine. I've tried both Arduino scripts and UIFlow. From what I could see is that the Arduino scripts are compiled and flashed on the board while the UIFlow only lasts while the battery is full and the device is not shut down. As soon as the device turns back on I get welcomed with the starting screen where the API Key is shown.<br />
Any way to make the UIFlow program stick even after a restart?</p>
]]></description><link>https://community.m5stack.com/topic/1740/is-it-normal-to-lose-uiflow-program-after-shutdown-battery-discharge</link><generator>RSS for Node</generator><lastBuildDate>Sun, 03 May 2026 23:31:06 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/1740.rss" rel="self" type="application/rss+xml"/><pubDate>Tue, 03 Mar 2020 16:36:08 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Is it normal to lose UIFlow program after shutdown&#x2F;battery discharge? on Tue, 03 Mar 2020 18:13:48 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/ajb2k3" aria-label="Profile: ajb2k3">@<bdi>ajb2k3</bdi></a> that worked, thanks</p>
]]></description><link>https://community.m5stack.com/post/7665</link><guid isPermaLink="true">https://community.m5stack.com/post/7665</guid><dc:creator><![CDATA[synapse]]></dc:creator><pubDate>Tue, 03 Mar 2020 18:13:48 GMT</pubDate></item><item><title><![CDATA[Reply to Is it normal to lose UIFlow program after shutdown&#x2F;battery discharge? on Tue, 03 Mar 2020 17:24:22 GMT]]></title><description><![CDATA[<p dir="auto">If you uploaded using the blue arrow then it will lose the program after a reset.<br />
to make code stick, you have to use the Download button which can be found by clicking the button with the 3 horizontal lines.</p>
]]></description><link>https://community.m5stack.com/post/7663</link><guid isPermaLink="true">https://community.m5stack.com/post/7663</guid><dc:creator><![CDATA[ajb2k3]]></dc:creator><pubDate>Tue, 03 Mar 2020 17:24:22 GMT</pubDate></item></channel></rss>
