<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[[Solved] https request ends in error 12: &quot;ENOMEM&quot;]]></title><description><![CDATA[<p dir="auto">Hi folks</p>
<p dir="auto">Is there a possibility to make <strong>https request</strong>, instead of http request?<br />
Nowadays there is nearly no web site out there that allows http.<br />
Everything is https. I would like to get info from an api that provides weather data.</p>
<p dir="auto">Or is the received data simply to large? I get an error: <strong>12 ENOMEM</strong>.<br />
The received data is about 8k</p>
<p dir="auto">Thanks for help :-)</p>
<p dir="auto">Best regards<br />
Thomas</p>
<p dir="auto"><strong>ADDED "SOLUTION":</strong><br />
It works just if I upload the program to the device, but not in RUN-mode :-(</p>
<p dir="auto"><strong>Does anyone have a better solution?</strong></p>
]]></description><link>https://community.m5stack.com/topic/1760/solved-https-request-ends-in-error-12-enomem</link><generator>RSS for Node</generator><lastBuildDate>Wed, 29 Apr 2026 02:45:55 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/1760.rss" rel="self" type="application/rss+xml"/><pubDate>Sat, 14 Mar 2020 09:44:11 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to [Solved] https request ends in error 12: &quot;ENOMEM&quot; on Mon, 11 May 2020 19:40:49 GMT]]></title><description><![CDATA[<p dir="auto">It works with Firmware V1.5.1 and above</p>
]]></description><link>https://community.m5stack.com/post/8632</link><guid isPermaLink="true">https://community.m5stack.com/post/8632</guid><dc:creator><![CDATA[M5StickFreakler]]></dc:creator><pubDate>Mon, 11 May 2020 19:40:49 GMT</pubDate></item><item><title><![CDATA[Reply to [Solved] https request ends in error 12: &quot;ENOMEM&quot; on Sat, 28 Mar 2020 12:39:06 GMT]]></title><description><![CDATA[<p dir="auto">I can see the same with FW 1.4.5.1 and USB mode. If I use web mode it works. The request itself is HTTPS but tiny.</p>
<p dir="auto">This might be related: <a href="https://github.com/m5stack/UiFlow-Bug-Report/issues/34" target="_blank" rel="noopener noreferrer nofollow ugc">https://github.com/m5stack/UiFlow-Bug-Report/issues/34</a></p>
]]></description><link>https://community.m5stack.com/post/7943</link><guid isPermaLink="true">https://community.m5stack.com/post/7943</guid><dc:creator><![CDATA[joscha]]></dc:creator><pubDate>Sat, 28 Mar 2020 12:39:06 GMT</pubDate></item></channel></rss>
