<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Issue with Port C (UART) of M5Stack Fire (Finger unit OK but GPS No Good)]]></title><description><![CDATA[<p dir="auto">I am aware that there is an issue related to the UART port (Port C) of M5Stack Fire. However, using the UIFlow (1.4.5) I managed to connect and program the Finger unit normally. However, with the GPS unit, I failed to make it work. I do not understand why for the core works with the Finger unit but not with the GPS (same Port C).</p>
]]></description><link>https://community.m5stack.com/topic/1798/issue-with-port-c-uart-of-m5stack-fire-finger-unit-ok-but-gps-no-good</link><generator>RSS for Node</generator><lastBuildDate>Tue, 28 Apr 2026 17:48:42 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/1798.rss" rel="self" type="application/rss+xml"/><pubDate>Fri, 27 Mar 2020 08:48:45 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Issue with Port C (UART) of M5Stack Fire (Finger unit OK but GPS No Good) on Wed, 19 Nov 2025 06:55:49 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/liemph" aria-label="Profile: liemph">@<bdi>liemph</bdi></a></p>
<p dir="auto">Fire Has PSRAM ..  use Port C PIN ..<br />
so it can't use Port C .</p>
<hr />
<p dir="auto">Fire 는PSRAM 이 있어요 그것이 C 포트에 GPIO를 사용합니다.<br />
그래서 C 포트를 사용할수가 없답니다.</p>
<p dir="auto">이 내용은 챗봇이 무척 많이 알려준 내용입니다..</p>
]]></description><link>https://community.m5stack.com/post/30209</link><guid isPermaLink="true">https://community.m5stack.com/post/30209</guid><dc:creator><![CDATA[nongjung-dns]]></dc:creator><pubDate>Wed, 19 Nov 2025 06:55:49 GMT</pubDate></item><item><title><![CDATA[Reply to Issue with Port C (UART) of M5Stack Fire (Finger unit OK but GPS No Good) on Wed, 06 May 2020 17:16:08 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/liemph" aria-label="Profile: liemph">@<bdi>liemph</bdi></a><br />
Same problem here :-(</p>
<p dir="auto"><a href="https://forum.m5stack.com/topic/1930/gps-unit-at6558" target="_blank" rel="noopener noreferrer nofollow ugc">https://forum.m5stack.com/topic/1930/gps-unit-at6558</a></p>
]]></description><link>https://community.m5stack.com/post/8530</link><guid isPermaLink="true">https://community.m5stack.com/post/8530</guid><dc:creator><![CDATA[M5StickFreakler]]></dc:creator><pubDate>Wed, 06 May 2020 17:16:08 GMT</pubDate></item><item><title><![CDATA[Reply to Issue with Port C (UART) of M5Stack Fire (Finger unit OK but GPS No Good) on Mon, 30 Mar 2020 08:19:12 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/ajb2k3" aria-label="Profile: ajb2k3">@<bdi>ajb2k3</bdi></a> said in <a href="/post/7945">Issue with Port C (UART) of M5Stack Fire (Finger unit OK but GPS No Good)</a>:</p>
<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/liemph" aria-label="Profile: liemph">@<bdi>liemph</bdi></a> Try connecting the m5stack to a pc and opening a terminal connecting to the M5Stack.<br />
the terminal may show more information.</p>
<p dir="auto">I took the log file by using teraterm serial monitor program. I did not see any valuable information for debugging.  This is the results:<br />
ets Jun  8 2016 00:22:57</p>
<p dir="auto">rst:0x1 (POWERON_RESET),boot:0x17 (SPI_FAST_FLASH_BOOT)<br />
mode:DIO, clock div:1<br />
load:0x3fff0018,len:4<br />
load:0x3fff001c,len:6272<br />
ho 0 tail 12 room 4<br />
load:0x40078000,len:9848<br />
load:0x40080400,len:6504<br />
entry 0x4008072c<br />
I (32) boot: ESP-IDF v3.3-beta1-696-gc4c54ce07 2nd stage bootloader<br />
I (32) boot: compile time 19:36:27<br />
I (32) boot: Enabling RNG early entropy source...<br />
I (38) boot: SPI Speed      : 80MHz<br />
I (42) boot: SPI Mode       : DIO<br />
I (46) boot: SPI Flash Size : 16MB<br />
I (50) boot: Partition Table:<br />
I (54) boot: ## Label            Usage          Type ST Offset   Length<br />
I (61) boot:  0 nvs              WiFi data        01 02 00009000 00006000<br />
I (69) boot:  1 phy_init         RF data          01 01 0000f000 00001000<br />
I (76) boot:  2 factory          factory app      00 00 00010000 001f0000<br />
I (83) boot:  3 internalfs       Unknown data     01 81 00200000 001ff000<br />
I (91) boot: End of partition table<br />
I (95) esp_image: segment 0: paddr=0x00010020 vaddr=0x3f400020 size=0xe970c (956172) map<br />
I (379) esp_image: segment 1: paddr=0x000f9734 vaddr=0x3ffbdb60 size=0x034dc ( 13532) load<br />
I (383) esp_image: segment 2: paddr=0x000fcc18 vaddr=0x40080000 size=0x00400 (  1024) load<br />
I (386) esp_image: segment 3: paddr=0x000fd020 vaddr=0x40080400 size=0x02ff0 ( 12272) load<br />
I (398) esp_image: segment 4: paddr=0x00100018 vaddr=0x400d0018 size=0xdbea8 (900776) map<br />
I (662) esp_image: segment 5: paddr=0x001dbec8 vaddr=0x400833f0 size=0x12bf8 ( 76792) load<br />
I (688) esp_image: segment 6: paddr=0x001eeac8 vaddr=0x400c0000 size=0x00064 (   100) load<br />
I (688) esp_image: segment 7: paddr=0x001eeb34 vaddr=0x50000000 size=0x00808 (  2056) load<br />
I (708) boot: Loaded app from partition at offset 0x10000<br />
I (709) boot: Disabling RNG early entropy source...<br />
I (709) cpu_start: Pro cpu up.<br />
I (713) cpu_start: Application information:<br />
I (717) cpu_start: Compile time:     Mar 13 2020 19:36:49<br />
I (724) cpu_start: ELF file SHA256:  0000000000000000...<br />
I (730) cpu_start: ESP-IDF:          v3.3-beta1-696-gc4c54ce07<br />
I (736) cpu_start: Starting app cpu, entry point is 0x400836e4<br />
I (0) cpu_start: App cpu up.<br />
I (746) heap_init: Initializing. RAM available for dynamic allocation:<br />
I (753) heap_init: At 3FFAE6E0 len 0000F480 (61 KiB): DRAM<br />
I (759) heap_init: At 3FFCB2C8 len 00014D38 (83 KiB): DRAM<br />
I (766) heap_init: At 3FFE0440 len 00003AE0 (14 KiB): D/IRAM<br />
I (772) heap_init: At 3FFE4350 len 0001BCB0 (111 KiB): D/IRAM<br />
I (778) heap_init: At 40095FE8 len 0000A018 (40 KiB): IRAM<br />
I (785) cpu_start: Pro cpu start user code<br />
I (131) cpu_start: Starting scheduler on PRO CPU.<br />
I (0) cpu_start: Starting scheduler on APP CPU.</p>
<h2>Internal FS (FatFS): Mounted on partition 'internalfs' [size: 2093056; Flash address: 0x200000]</h2>
<h2>Filesystem size: 2031616 B<br />
Used: 1605632 B<br />
Free: 425984 B</h2>
<p dir="auto">I (359) [TFTSPI]: attached display device, speed=8000000<br />
I (359) [TFTSPI]: bus uses native pins: false<br />
W (534) sdspi_host: spi bus changed (1 -&gt; 2)<br />
E (577) sdmmc_sd: sdmmc_init_spi_crc: sdmmc_send_cmd_crc_on_off returned 0x106<br />
[ M5 ] init sd card Fail<br />
[ M5 ] node id:&lt;deleted&gt;, api key:&lt;deleted&gt;<br />
I (2018) uart: ALREADY NULL</p>
<p dir="auto">Please note that I deleted the node id and api key.</p>
]]></description><link>https://community.m5stack.com/post/7961</link><guid isPermaLink="true">https://community.m5stack.com/post/7961</guid><dc:creator><![CDATA[liemph]]></dc:creator><pubDate>Mon, 30 Mar 2020 08:19:12 GMT</pubDate></item><item><title><![CDATA[Reply to Issue with Port C (UART) of M5Stack Fire (Finger unit OK but GPS No Good) on Sat, 28 Mar 2020 16:30:49 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/liemph" aria-label="Profile: liemph">@<bdi>liemph</bdi></a> Try connecting the m5stack to a pc and opening a terminal connecting to the M5Stack.<br />
]]></description><link>https://community.m5stack.com/post/7945</link><guid isPermaLink="true">https://community.m5stack.com/post/7945</guid><dc:creator><![CDATA[ajb2k3]]></dc:creator><pubDate>Sat, 28 Mar 2020 16:30:49 GMT</pubDate></item><item><title><![CDATA[Reply to Issue with Port C (UART) of M5Stack Fire (Finger unit OK but GPS No Good) on Fri, 27 Mar 2020 21:39:11 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/ajb2k3" aria-label="Profile: ajb2k3">@<bdi>ajb2k3</bdi></a> said in <a href="/post/7936">Issue with Port C (UART) of M5Stack Fire (Finger unit OK but GPS No Good)</a>:</p>
<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/liemph" aria-label="Profile: liemph">@<bdi>liemph</bdi></a> do you get an error message or just no response?</p>
<p dir="auto">Your question alerted me. I used the GPS example provided by M5 for UiFlow. The LCD showed that the Time is 00:00:00, no data in Lattitude and Longitude, the Quality showed NO Signal. I tested it at home (inside my house). So is it possible that I have to look for a better place to get a stronger signal? However other devices using GPS work well inside my house.</p>
]]></description><link>https://community.m5stack.com/post/7937</link><guid isPermaLink="true">https://community.m5stack.com/post/7937</guid><dc:creator><![CDATA[liemph]]></dc:creator><pubDate>Fri, 27 Mar 2020 21:39:11 GMT</pubDate></item><item><title><![CDATA[Reply to Issue with Port C (UART) of M5Stack Fire (Finger unit OK but GPS No Good) on Fri, 27 Mar 2020 18:59:40 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/liemph" aria-label="Profile: liemph">@<bdi>liemph</bdi></a> do you get an error message or just no response?</p>
]]></description><link>https://community.m5stack.com/post/7936</link><guid isPermaLink="true">https://community.m5stack.com/post/7936</guid><dc:creator><![CDATA[ajb2k3]]></dc:creator><pubDate>Fri, 27 Mar 2020 18:59:40 GMT</pubDate></item></channel></rss>
