<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Charging external batteries type 18650 from usb , M5stack]]></title><description><![CDATA[<p dir="auto">I want to do a project based on the M5stack and would like to inform myself if it is possible to recharge an external battery of type 18650 , 3000 mA/h , with the usb from the M5stack. I see   in the documentation that is possible  to 2.1 A ,  but I want to be sure .<br />
<img src="/assets/uploads/files/1585591490431-captura.png" alt="0_1585591487884_Captura.PNG" class=" img-fluid img-markdown" /></p>
]]></description><link>https://community.m5stack.com/topic/1805/charging-external-batteries-type-18650-from-usb-m5stack</link><generator>RSS for Node</generator><lastBuildDate>Fri, 01 May 2026 01:07:35 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/1805.rss" rel="self" type="application/rss+xml"/><pubDate>Mon, 30 Mar 2020 18:10:21 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Charging external batteries type 18650 from usb , M5stack on Fri, 03 Apr 2020 17:21:07 GMT]]></title><description><![CDATA[<p dir="auto">Thank you very much for your answers help me understand this hardware.<br />
Yes, that's my question. Use M5stack regulator to power the M5Stack and not from charger .<br />
In this case and, it is a last question about this, there will be no problems with the USB input if it is powered by an external battery. In some other case I have had problems connecting the USB, because both 5v sometimes are not exactly  and that small difference produced power noises by connecting the USB, and sometimes reestorting the unit.</p>
<p dir="auto">Best regards</p>
]]></description><link>https://community.m5stack.com/post/8008</link><guid isPermaLink="true">https://community.m5stack.com/post/8008</guid><dc:creator><![CDATA[Matorra]]></dc:creator><pubDate>Fri, 03 Apr 2020 17:21:07 GMT</pubDate></item><item><title><![CDATA[Reply to Charging external batteries type 18650 from usb , M5stack on Fri, 03 Apr 2020 06:32:13 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/matorra" aria-label="Profile: matorra">@<bdi>matorra</bdi></a> I don't understand why you need to output 3.3V voltage. On the M5Core, it is powered by 5V.</p>
]]></description><link>https://community.m5stack.com/post/8000</link><guid isPermaLink="true">https://community.m5stack.com/post/8000</guid><dc:creator><![CDATA[m5stack]]></dc:creator><pubDate>Fri, 03 Apr 2020 06:32:13 GMT</pubDate></item><item><title><![CDATA[Reply to Charging external batteries type 18650 from usb , M5stack on Thu, 02 Apr 2020 18:28:44 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/m5stack" aria-label="Profile: m5stack">@<bdi>m5stack</bdi></a> said in <a href="/post/7975">Charging external batteries type 18650 from usb , M5stack</a>:</p>
<p dir="auto">PowerC<br />
Thank you for your feedback, ajb2k3 and m5stack.<br />
The Power C is small for the actual project , it is probably better to use standard hardware for charging and only connect the 3.3v voltage on the M5stack. An example like the one I attach photo. But now I think, the output voltage I should use is the 3.3 v and not the 5v. That's it correct?<br />
<img src="/assets/uploads/files/1585852009153-captura.png" alt="0_1585852007603_Captura.PNG" class=" img-fluid img-markdown" /> image url)</p>
]]></description><link>https://community.m5stack.com/post/7994</link><guid isPermaLink="true">https://community.m5stack.com/post/7994</guid><dc:creator><![CDATA[Matorra]]></dc:creator><pubDate>Thu, 02 Apr 2020 18:28:44 GMT</pubDate></item><item><title><![CDATA[Reply to Charging external batteries type 18650 from usb , M5stack on Wed, 01 Apr 2020 06:13:03 GMT]]></title><description><![CDATA[<p dir="auto">We do not recommend you use the M5Stack Core to charge the 18650, it does not have battery protection. You can charge it with our PowerC product, which has a lithium battery protection circuit.</p>
]]></description><link>https://community.m5stack.com/post/7975</link><guid isPermaLink="true">https://community.m5stack.com/post/7975</guid><dc:creator><![CDATA[m5stack]]></dc:creator><pubDate>Wed, 01 Apr 2020 06:13:03 GMT</pubDate></item><item><title><![CDATA[Reply to Charging external batteries type 18650 from usb , M5stack on Tue, 31 Mar 2020 06:59:22 GMT]]></title><description><![CDATA[<p dir="auto">it should be possible if the battery is connected to the internal battery pins on the main pcb but it is untested.<br />
hmn, I should look into it for one of my projects as that would save some extra hardware.</p>
]]></description><link>https://community.m5stack.com/post/7970</link><guid isPermaLink="true">https://community.m5stack.com/post/7970</guid><dc:creator><![CDATA[ajb2k3]]></dc:creator><pubDate>Tue, 31 Mar 2020 06:59:22 GMT</pubDate></item></channel></rss>
