<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Basic Dev Kit connection via USB-C to USB-C cable]]></title><description><![CDATA[<p dir="auto">I'm using a MacBook Pro 15" from 2018 which has only USB-C ports so I was delighted to see M5Stack using USB-C connections as well. Nonetheless my <a href="https://www.amazon.de/dp/B07VCPC8X1/ref=psdc_1626220031_t2_B07TQYL1GY" target="_blank" rel="noopener noreferrer nofollow ugc">USB-C cable</a> does not work with it. And neither does a USB-C to A adapter.</p>
<p dir="auto">What does work Is the USB-C to B adapter connected to an Anker USB-A hub and then connect the USB-C to A cable from M5Stack to the Basic Dev Kit. Surely this must be easier to do right?</p>
]]></description><link>https://community.m5stack.com/topic/1810/basic-dev-kit-connection-via-usb-c-to-usb-c-cable</link><generator>RSS for Node</generator><lastBuildDate>Wed, 29 Apr 2026 02:29:33 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/1810.rss" rel="self" type="application/rss+xml"/><pubDate>Thu, 02 Apr 2020 10:32:46 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Basic Dev Kit connection via USB-C to USB-C cable on Mon, 06 Apr 2020 21:18:23 GMT]]></title><description><![CDATA[<p dir="auto">I can't make it work with a USB-C to USB-C cable either (running on a MacBook Pro 16' with Catalina). Using a USB-C to USB-A hub works....</p>
]]></description><link>https://community.m5stack.com/post/8037</link><guid isPermaLink="true">https://community.m5stack.com/post/8037</guid><dc:creator><![CDATA[pgb]]></dc:creator><pubDate>Mon, 06 Apr 2020 21:18:23 GMT</pubDate></item><item><title><![CDATA[Reply to Basic Dev Kit connection via USB-C to USB-C cable on Thu, 02 Apr 2020 10:46:23 GMT]]></title><description><![CDATA[<p dir="auto">Ok turning the cable 180º around it does work!<br />
In my case, the brand label up.</p>
<p dir="auto">So, now I'm curious what happened to the whole "it doesn't matter which way you plug your cable in" thing from USB-C here.</p>
]]></description><link>https://community.m5stack.com/post/7988</link><guid isPermaLink="true">https://community.m5stack.com/post/7988</guid><dc:creator><![CDATA[Kleurbleur]]></dc:creator><pubDate>Thu, 02 Apr 2020 10:46:23 GMT</pubDate></item></channel></rss>
