<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Ui Flow i2c scanner (Solved)]]></title><description><![CDATA[<p dir="auto">Hi</p>
<p dir="auto">I’m looking for an example on how to make an i2c scanner in Ui Flow.<br />
I have played with it all night, but have not been able to make it work.<br />
Does anybody have an example they are willing to share?<br />
I know there are several i2c scanners made for other compilers out there, but I would like to be able to do it in Ui Flow.</p>
<p dir="auto">Best regards<br />
Christian</p>
]]></description><link>https://community.m5stack.com/topic/1818/ui-flow-i2c-scanner-solved</link><generator>RSS for Node</generator><lastBuildDate>Wed, 29 Apr 2026 19:11:48 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/1818.rss" rel="self" type="application/rss+xml"/><pubDate>Sun, 05 Apr 2020 08:21:41 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Ui Flow i2c scanner (Solved) on Sun, 05 Apr 2020 15:08:16 GMT]]></title><description><![CDATA[<p dir="auto">Solved it, it returns the result in Dec, and not in Hex, don't know if there is a way to convert DEC to HEX</p>
<p dir="auto"><img src="/assets/uploads/files/1586098055975-i2c-scanner-simple.png" alt="0_1586098053769_I2C Scanner simple.png" class=" img-fluid img-markdown" /></p>
]]></description><link>https://community.m5stack.com/post/8023</link><guid isPermaLink="true">https://community.m5stack.com/post/8023</guid><dc:creator><![CDATA[ChristianH]]></dc:creator><pubDate>Sun, 05 Apr 2020 15:08:16 GMT</pubDate></item></channel></rss>
