<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[M5StickC + 18650C (HAT external battery) BAT pin]]></title><description><![CDATA[<p dir="auto">Does anyone know where the BAT pin on the HAT connector goes? I see what I think is the internal battery voltage on it. So when I use the 18650C accessory the 18650 is connected in parallel with the internal battery? Is that correct?</p>
<p dir="auto">Thanks!</p>
]]></description><link>https://community.m5stack.com/topic/1825/m5stickc-18650c-hat-external-battery-bat-pin</link><generator>RSS for Node</generator><lastBuildDate>Wed, 29 Apr 2026 02:46:31 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/1825.rss" rel="self" type="application/rss+xml"/><pubDate>Mon, 06 Apr 2020 22:54:19 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to M5StickC + 18650C (HAT external battery) BAT pin on Tue, 07 Apr 2020 03:49:01 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/m5stack" aria-label="Profile: m5stack">@<bdi>m5stack</bdi></a> This means that when the Stick is plug to the 18650C accessory, the 18650C accessory will not charge the internal battery?</p>
]]></description><link>https://community.m5stack.com/post/8045</link><guid isPermaLink="true">https://community.m5stack.com/post/8045</guid><dc:creator><![CDATA[liemph]]></dc:creator><pubDate>Tue, 07 Apr 2020 03:49:01 GMT</pubDate></item><item><title><![CDATA[Reply to M5StickC + 18650C (HAT external battery) BAT pin on Tue, 07 Apr 2020 01:20:47 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/liamharrison3" aria-label="Profile: liamharrison3">@<bdi>liamharrison3</bdi></a> yes. the 18650 is connected in parallel with the M5StickC internal battery.</p>
]]></description><link>https://community.m5stack.com/post/8039</link><guid isPermaLink="true">https://community.m5stack.com/post/8039</guid><dc:creator><![CDATA[m5stack]]></dc:creator><pubDate>Tue, 07 Apr 2020 01:20:47 GMT</pubDate></item></channel></rss>
