<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[M5StickC, macOS and USB-C to USB-C cable]]></title><description><![CDATA[<p dir="auto">If I connect my M5StickC to my Mac using a USB-C hub that provides USB-A ports, everything works as expected.</p>
<p dir="auto">However, if I connect it directly to the MacBook Pro (running macOS Catalina and with the proper driver installed), the serial port is not even detected by the OS.</p>
<p dir="auto">Is that expected? Or is there a newer driver available? (I'm using version 2.4.2 downloaded <a href="https://www.ftdichip.com/Drivers/VCP.htm" target="_blank" rel="noopener noreferrer nofollow ugc">here</a>)</p>
]]></description><link>https://community.m5stack.com/topic/1830/m5stickc-macos-and-usb-c-to-usb-c-cable</link><generator>RSS for Node</generator><lastBuildDate>Wed, 29 Apr 2026 02:29:53 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/1830.rss" rel="self" type="application/rss+xml"/><pubDate>Wed, 08 Apr 2020 20:24:45 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to M5StickC, macOS and USB-C to USB-C cable on Fri, 10 Apr 2020 21:17:29 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/macsbug" aria-label="Profile: macsbug">@<bdi>macsbug</bdi></a> Thank you. I installed the update already, and it works (I no longer need to jump G0 to GND to flash). However, I still can't use a USB-C to USB-C cable directly, need to go through a USB-C hub.</p>
]]></description><link>https://community.m5stack.com/post/8105</link><guid isPermaLink="true">https://community.m5stack.com/post/8105</guid><dc:creator><![CDATA[pgb]]></dc:creator><pubDate>Fri, 10 Apr 2020 21:17:29 GMT</pubDate></item><item><title><![CDATA[Reply to M5StickC, macOS and USB-C to USB-C cable on Thu, 09 Apr 2020 13:49:34 GMT]]></title><description><![CDATA[<p dir="auto">The following information may be helpful.</p>
<li>
<p dir="auto">Cannot write to M5StickC on macOS Catalina :<br />
<a href="https://qiita.com/SamAkada/items/fa32d6072a832a10cd84" target="_blank" rel="noopener noreferrer nofollow ugc">https://qiita.com/SamAkada/items/fa32d6072a832a10cd84</a></p>
</li>
<li>
<p dir="auto">How to solve the problem that M5StickC can not be written with Arduino IDE of macOS Catalina :<br />
<a href="https://tech.fusic.co.jp/posts/2020-02-12-macos-catalina-m5stickc/" target="_blank" rel="noopener noreferrer nofollow ugc">https://tech.fusic.co.jp/posts/2020-02-12-macos-catalina-m5stickc/</a></p>
</li>
]]></description><link>https://community.m5stack.com/post/8081</link><guid isPermaLink="true">https://community.m5stack.com/post/8081</guid><dc:creator><![CDATA[macsbug]]></dc:creator><pubDate>Thu, 09 Apr 2020 13:49:34 GMT</pubDate></item><item><title><![CDATA[Reply to M5StickC, macOS and USB-C to USB-C cable on Thu, 09 Apr 2020 08:55:31 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/pgb" aria-label="Profile: pgb">@<bdi>pgb</bdi></a> said in <a href="/post/8065">M5StickC, macOS and USB-C to USB-C cable</a>:</p>
<p dir="auto">There looks to be ongoing internal issues with OSX Catalina. if you have it working through a hub then continue to use the hub.<br />
Unfortunately it looks like the issue is with Apple.</p>
]]></description><link>https://community.m5stack.com/post/8073</link><guid isPermaLink="true">https://community.m5stack.com/post/8073</guid><dc:creator><![CDATA[ajb2k3]]></dc:creator><pubDate>Thu, 09 Apr 2020 08:55:31 GMT</pubDate></item></channel></rss>
