<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[BMC_SBUS M5Stack porting]]></title><description><![CDATA[<p dir="auto">Hi all<br />
I'm trying to port an Arduino Mega sketch, using BMC_SBUS, to M5Stack!!<br />
<a href="https://github.com/boldstelvis/BMC_SBUS" target="_blank" rel="noopener noreferrer nofollow ugc">https://github.com/boldstelvis/BMC_SBUS</a> ... /README.md<br />
to use this: <a href="https://www.kinowheels.com/" target="_blank" rel="noopener noreferrer nofollow ugc">https://www.kinowheels.com/</a><br />
with this: <a href="https://forum.dji.com/thread-167232-1-1.html" target="_blank" rel="noopener noreferrer nofollow ugc">https://forum.dji.com/thread-167232-1-1.html</a><br />
this is the connections: <a href="https://forum11.djicdn.com/data/attachm" target="_blank" rel="noopener noreferrer nofollow ugc">https://forum11.djicdn.com/data/attachm</a> ... htjjsl.png</p>
<p dir="auto">this is the Arduino Mega sketch connected to the ronin D-bus (it works!! I can move the ronin X and Y axis):</p>
<pre><code>#define BAUDRATE 100000  // oder  100000 115200
#define SERIALPORT Serial  // - uncomment this line if using an arduino based board with more than one HW serial port
class BMC_SBUS
  public:
    uint8_t sbusData[25];
    int16_t servos[18];
    void begin(void);
    void Servo(uint8_t ch, int16_t position);
    void Send(void);
    void Update(void);
  private:
    uint8_t byte_in_sbus;
    uint8_t bit_in_sbus;
    uint8_t ch;
    uint8_t bit_in_servo;
void BMC_SBUS::begin()
  //intialise private data arrays
  //sbus_data is formatted for correct serial output
  //note that the actual 11bit sbus data for each channel is embedded across multiple data bytes in a very stange order
  //byte 1 and bytes 24 and 25 should be left as is
  //the first is a start byte, the last is a stop byte and the second last holds various flags
  //servos is the internal per channel position and is more straightforward - one int_16 per channel
  uint8_t loc_sbusData[25] = {0x0f,0x01,0x04,0x20,0x00,0xff,0x07,0x40,0x00,0x02,0x10,0x80,0x2c,0x64,0x21,0x0b,0x59,0x08,0x40,0x00,0x02,0x10,0x80,0x00,0x00};
  int16_t loc_servos[18]   = {1023,1023,1023,1023,1023,1023,1023,1023,1023,1023,1023,1023,1023,1023,1023,1023,0,0};
  //setup serial port to transmit at 100k baud and use 1 parity and 2 stop bits
  SERIALPORT.begin(BAUDRATE, SERIAL_8E2);
  //setup public data arrays
  memcpy(sbusData,loc_sbusData,25);
  memcpy(servos,loc_servos,18);
void BMC_SBUS::Servo(uint8_t ch, int16_t position)
  //set servo position on single channel
  if ((ch&gt;0)&amp;&amp;(ch&lt;=16))
    constrain (position, 0, 2048); //keep within min/max values
    servos[ch-1] = position; //expects a non zero starting index to the channel
void BMC_SBUS::Send(void)
  //send data over serial port
  SERIALPORT.write(sbusData, 25); //according to docs for Serial we can send the array along as is without a loop
void BMC_SBUS::Update(void)
  //update positions for all servo channels within the SBUS data frame
  //ignores digital servos and any failsafe mode stuff that was originally written
  //clear out existing sbus data for all channel data bytes
  //ignores first and last bytes in the array (start and stop bytes)
  //mapping loop relies on initial 0 values - do not omit this step!
  uint8_t i;
  for (i=1; i&lt;24; i++)
    sbusData[i] = 0;
  //reset counters
  ch = 0;
  bit_in_servo = 0;
  byte_in_sbus = 1;
  bit_in_sbus = 0;
  //format sbus data - maps sevo data array to sbus data array 1bit at a time
  //correctly deals with the little endian byte order in the process
  for (i=0; i&lt;176; i++) //16channels*11bits = 176bits
    if (servos[ch] &amp; (1&lt;&lt;bit_in_servo)) //bitwise AND to check if the correct servo databit is set to 1
      sbusData[byte_in_sbus] |= (1&lt;&lt;bit_in_sbus); //bitwise OR sets the correct sbus databit if true
    //increment bit counters
    bit_in_sbus++;
    bit_in_servo++;
    //if end of sbus byte reset sbus bit counter and increment sbus byte counter
    if (bit_in_sbus == 8)
      bit_in_sbus = 0;
      byte_in_sbus++;
    // if we have reached bit 11 in the servo data increment channel index and reset servo bit counter
    if (bit_in_servo == 11)
      bit_in_servo = 0;
      ch++;
//Declare BMC_SBUS Object
BMC_SBUS mySBUS;
// Sbus delay value
const int sbusWAIT = 7;      //frame timing delay in msecs
// Declare sbus control channels
int panChannel = 1;
int tiltChannel = 2;
int rollChannel = 4;
// Declare Kinowheels Stuff
int XA_SIG=0, XB_SIG=1, YA_SIG=0, YB_SIG=1, pulsesX, pulsesY;
// Declare Stuff for calculating Speed
int xStampEnd=0, yStampEnd=0, timeStampEnd=0, xPassed, yPassed, timePassed, sendX=1023, sendY=1023;
  // Serial.begin(100000); überflüssig, weil in MC_SBUS enthalten
  // Start  KinoWheels Stuff
  attachInterrupt(0, XA_RISE, RISING); // Pin 2
  attachInterrupt(1, XB_RISE, RISING); // Pin 3
  attachInterrupt(4, YA_RISE, RISING); // Pin 19
  attachInterrupt(5, YB_RISE, RISING); // Pin 18
   // Start BMC_SBUS object
  mySBUS.begin();
  for (int i=0; i&lt;1; i++){        //SBUS needs data every 7 Milliseconds. I repeat it three times for some time to pass for calculating speeds.
  mySBUS.Servo(tiltChannel,sendY);
  mySBUS.Servo(panChannel,sendX);
  // Update SBUS object and send data
  mySBUS.Update();
  mySBUS.Send();
  delay(sbusWAIT);
 timePassed = millis() - timeStampEnd;
 xPassed = xStampEnd - pulsesX;
 yPassed = pulsesY - yStampEnd;
 sendX = 1023 + 100* xPassed / timePassed;
 sendY = 1023 + 100* yPassed / timePassed;
for (int i=0; i&lt;1; i++){          //Maybe this one is not needed. Will find it out later
  mySBUS.Update();
  mySBUS.Send();
  delay(sbusWAIT);
 xStampEnd = pulsesX;
 yStampEnd = pulsesY;
 timeStampEnd = millis();
//Rotary Encoder Stuff by KinoWheels
void XA_RISE(){
 detachInterrupt(0);
 //delay(1);
 XA_SIG=1;
 if(XB_SIG==0)
 pulsesX++;//moving forward
 if(XB_SIG==1)
 pulsesX--;//moving reverse
 attachInterrupt(0, XA_FALL, FALLING);
void XA_FALL(){
  detachInterrupt(0);
  //delay(1);
 XA_SIG=0;
 if(XB_SIG==1)
 if(XB_SIG==0)
void XB_RISE(){
 detachInterrupt(1);
 //delay(1);
 XB_SIG=1;
 if(XA_SIG==1)
 if(XA_SIG==0)
 attachInterrupt(1, XB_FALL, FALLING);
void XB_FALL(){
 detachInterrupt(1);
 //delay(1);
 XB_SIG=0;
 if(XA_SIG==0)
 if(XA_SIG==1)
void YA_RISE(){
 detachInterrupt(4);
 //delay(1);
 YA_SIG=1;
 if(YB_SIG==0)
 pulsesY++;//moving forward
 if(YB_SIG==1)
 pulsesY--;//moving reverse
 attachInterrupt(4, YA_FALL, FALLING);
void YA_FALL(){
  detachInterrupt(4);
  //delay(1);
 YA_SIG=0;
 if(YB_SIG==1)
 if(YB_SIG==0)
void YB_RISE(){
 detachInterrupt(5);
 //delay(1);
 YB_SIG=1;
 if(YA_SIG==1)
 if(YA_SIG==0)
 attachInterrupt(5, YB_FALL, FALLING);
void YB_FALL(){
 detachInterrupt(5);
 //delay(1);
 YB_SIG=0;
 if(YA_SIG==0)
 if(YA_SIG==1)
<p dir="auto">How can I port to M5Stack?</p>
<p dir="auto">this in what I done ... but I have not Y axe control....<br />
M5Stack----------ronin D-bus<br />
grd-------------------grd<br />
5V--------------------5V<br />
TXD2(G17)------data</p>
#include &lt;ESP32Encoder.h&gt;
ESP32Encoder encoderX;
ESP32Encoder encoderY;
#define SERIALPORT Serial2  // - uncomment this line if using an arduino based board with more than one HW serial port
class BMC_SBUS
  public:
    int16_t servos[18];
    void begin(void);
    void Send(void);
    void Update(void);
  private:
    uint8_t ch;
  uint8_t loc_sbusData[25] = {0x0f, 0x01, 0x04, 0x20, 0x00, 0xff, 0x07, 0x40, 0x00, 0x02, 0x10, 0x80, 0x2c, 0x64, 0x21, 0x0b, 0x59, 0x08, 0x40, 0x00, 0x02, 0x10, 0x80, 0x00, 0x00};
  int16_t loc_servos[18]   = {1023, 1023, 1023, 1023, 1023, 1023, 1023, 1023, 1023, 1023, 1023, 1023, 1023, 1023, 1023, 1023, 0, 0};
  memcpy(sbusData, loc_sbusData, 25);
  memcpy(servos, loc_servos, 18);
  if ((ch &gt; 0) &amp;&amp; (ch &lt;= 16))
    servos[ch - 1] = position; //expects a non zero starting index to the channel
  uint8_t i;
  for (i = 1; i &lt; 24; i++)
    sbusData[i] = 0;
  //reset counters
  ch = 0;
  bit_in_servo = 0;
  byte_in_sbus = 1;
  bit_in_sbus = 0;
  for (i = 0; i &lt; 176; i++) //16channels*11bits = 176bits
    if (servos[ch] &amp; (1 &lt;&lt; bit_in_servo)) //bitwise AND to check if the correct servo databit is set to 1
      sbusData[byte_in_sbus] |= (1 &lt;&lt; bit_in_sbus); //bitwise OR sets the correct sbus databit if true
    bit_in_sbus++;
    bit_in_servo++;
      bit_in_sbus = 0;
      byte_in_sbus++;
      bit_in_servo = 0;
      ch++;
BMC_SBUS mySBUS;
// Sbus delay value
int panChannel = 1;
float pulsesX, pulsesY;
int xStampEnd = 0;
int yStampEnd = 0;
int timeStampEnd = 0;
int xPassed;
int yPassed;
int timePassed;
int sendX;// ??????
int sendY;// ??????
// Declare Poti Values
int potiX = 100;
int potiY = 100;
bool PANTILTtoggle = 0;
  M5.begin();
  // clear the encoder's raw count and set the tracked count to zero
  encoderX.clearCount();
  encoderY.clearCount();
  // Attache pins for use as encoder pins
  encoderX.attachHalfQuad(2, 3);
  encoderY.attachHalfQuad(36, 35);
  M5.update();
  sendX = 1023;
  sendY = 1023;
  mySBUS.begin();
  pulsesX = encoderX.getCount();
  pulsesY = encoderY.getCount();
  for (int i = 0; i &lt; 1; i++) {   //SBUS needs data every 7 Milliseconds. I repeat it three times for some time to pass for calculating speeds.
    mySBUS.Servo(tiltChannel, sendY);
    mySBUS.Servo(panChannel, sendX);
    mySBUS.Update();
    mySBUS.Send();
    delay(sbusWAIT);
  M5.update();
    sendX = 1023 + 100 * xPassed / timePassed;
    sendY = 1023 + 100 * yPassed / timePassed;
  if (sendX &gt; 2047) {
    sendX = 2047;
  if (sendX &lt; 0) {
    sendX = 0;
  if (sendY &gt; 2047) {
    sendY = 2047;
  if (sendY &lt; 0) {
    sendY = 0;
  for (int i = 0; i &lt; 1; i++) {     //Maybe this one is not needed. Will find it out later
    mySBUS.Update();
    mySBUS.Send();
    delay(sbusWAIT);
  M5.update();
<p dir="auto">the strange thing is that the information about X axe, go to the machine connected at G17 (TXD2), but not the Y one..<br />
I'm using an inverter on the TX-----RX line...for (d-bus/s-bus)</p>
<p dir="auto">tnks a lot</p>
]]></description><link>https://community.m5stack.com/topic/1835/bmc_sbus-m5stack-porting</link><generator>RSS for Node</generator><lastBuildDate>Wed, 29 Apr 2026 03:45:55 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/1835.rss" rel="self" type="application/rss+xml"/><pubDate>Thu, 09 Apr 2020 19:44:51 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to BMC_SBUS M5Stack porting on Fri, 17 Jul 2020 10:16:09 GMT]]></title><description><![CDATA[<p dir="auto">codice arduino mega stabilizzatore</p>
<p dir="auto">#define BAUDRATE 100000  // oder  100000 115200<br />
//#define BAUDRATE 115200  // oder  100000 115200<br />
#define SERIALPORT Serial  // - uncomment this line if using an arduino based board with more than one HW serial port</p>
<p dir="auto">class BMC_SBUS<br />
{<br />
public:<br />
uint8_t sbusData[25];<br />
int16_t servos[18];<br />
void begin(void);<br />
void Servo(uint8_t ch, int16_t position);<br />
void Send(void);<br />
void Update(void);</p>
<p dir="auto">private:<br />
uint8_t byte_in_sbus;<br />
uint8_t bit_in_sbus;<br />
uint8_t ch;<br />
uint8_t bit_in_servo;<br />
};</p>
<p dir="auto">void BMC_SBUS::begin()<br />
{<br />
//intialise private data arrays<br />
//sbus_data is formatted for correct serial output<br />
//note that the actual 11bit sbus data for each channel is embedded across multiple data bytes in a very stange order<br />
//byte 1 and bytes 24 and 25 should be left as is<br />
//the first is a start byte, the last is a stop byte and the second last holds various flags<br />
//servos is the internal per channel position and is more straightforward - one int_16 per channel</p>
<p dir="auto">uint8_t loc_sbusData[25] = {0x0f, 0x01, 0x04, 0x20, 0x00, 0xff, 0x07, 0x40, 0x00, 0x02, 0x10, 0x80, 0x2c, 0x64, 0x21, 0x0b, 0x59, 0x08, 0x40, 0x00, 0x02, 0x10, 0x80, 0x00, 0x00};<br />
int16_t loc_servos[18]   = {1023, 1023, 1023, 1023, 1023, 1023, 1023, 1023, 1023, 1023, 1023, 1023, 1023, 1023, 1023, 1023, 0, 0};</p>
<p dir="auto">//setup serial port to transmit at 100k baud and use 1 parity and 2 stop bits</p>
<p dir="auto">SERIALPORT.begin(BAUDRATE, SERIAL_8E2);</p>
<p dir="auto">//setup public data arrays</p>
<p dir="auto">memcpy(sbusData, loc_sbusData, 25);<br />
memcpy(servos, loc_servos, 18);<br />
<p dir="auto">void BMC_SBUS::Servo(uint8_t ch, int16_t position)<br />
{<br />
//set servo position on single channel</p>
<p dir="auto">if ((ch &gt; 0) &amp;&amp; (ch &lt;= 16))<br />
{<br />
constrain (position, 0, 2048); //keep within min/max values<br />
servos[ch - 1] = position; //expects a non zero starting index to the channel<br />
}<br />
<p dir="auto">void BMC_SBUS::Send(void)<br />
{<br />
//send data over serial port<br />
SERIALPORT.write(sbusData, 25); //according to docs for Serial we can send the array along as is without a loop<br />
<p dir="auto">void BMC_SBUS::Update(void)<br />
{<br />
//update positions for all servo channels within the SBUS data frame<br />
//ignores digital servos and any failsafe mode stuff that was originally written</p>
<p dir="auto">//clear out existing sbus data for all channel data bytes<br />
//ignores first and last bytes in the array (start and stop bytes)<br />
//mapping loop relies on initial 0 values - do not omit this step!</p>
<p dir="auto">uint8_t i;<br />
for (i = 1; i &lt; 24; i++)<br />
{<br />
sbusData[i] = 0;<br />
<p dir="auto">//reset counters</p>
<p dir="auto">ch = 0;<br />
bit_in_servo = 0;<br />
byte_in_sbus = 1;<br />
bit_in_sbus = 0;</p>
<p dir="auto">//format sbus data - maps sevo data array to sbus data array 1bit at a time<br />
//correctly deals with the little endian byte order in the process</p>
<p dir="auto">for (i = 0; i &lt; 176; i++) //16channels*11bits = 176bits<br />
{<br />
if (servos[ch] &amp; (1 &lt;&lt; bit_in_servo)) //bitwise AND to check if the correct servo databit is set to 1<br />
{<br />
sbusData[byte_in_sbus] |= (1 &lt;&lt; bit_in_sbus); //bitwise OR sets the correct sbus databit if true<br />
<pre><code>//increment bit counters
bit_in_sbus++;
bit_in_servo++;
  bit_in_sbus = 0;
  byte_in_sbus++;
  bit_in_servo = 0;
  ch++;
<p dir="auto">}<br />
<p dir="auto">//Declare BMC_SBUS Object<br />
BMC_SBUS mySBUS;</p>
<p dir="auto">// Sbus delay value<br />
const int sbusWAIT = 7;      //frame timing delay in msecs</p>
<p dir="auto">// Declare sbus control channels<br />
int panChannel = 1;<br />
int tiltChannel = 2;<br />
int rollChannel = 4;</p>
<p dir="auto">// Declare Kinowheels Stuff<br />
int XA_SIG = 0, XB_SIG = 1, YA_SIG = 0, YB_SIG = 1, pulsesX, pulsesY;</p>
<p dir="auto">// Declare Stuff for calculating Speed<br />
int xStampEnd = 0, yStampEnd = 0, timeStampEnd = 0, xPassed, yPassed, timePassed, sendX = 1023, sendY = 1023;</p>
// Serial.begin(100000); überflüssig, weil in MC_SBUS enthalten</p>
<p dir="auto">// Start  KinoWheels Stuff<br />
attachInterrupt(0, XA_RISE, RISING); // Pin 2<br />
attachInterrupt(1, XB_RISE, RISING); // Pin 3<br />
attachInterrupt(4, YA_RISE, RISING); // Pin 19<br />
attachInterrupt(5, YB_RISE, RISING); // Pin 18</p>
<p dir="auto">// Start BMC_SBUS object<br />
mySBUS.begin();</p>
<p dir="auto">}</p>
<p dir="auto">void loop() {</p>
<p dir="auto">for (int i = 0; i &lt; 1; i++) {   //SBUS needs data every 7 Milliseconds. I repeat it three times for some time to pass for calculating speeds.</p>
<pre><code>mySBUS.Servo(tiltChannel, sendY);
mySBUS.Update();
mySBUS.Send();
delay(sbusWAIT);
<p dir="auto">}</p>
<p dir="auto">timePassed = millis() - timeStampEnd;<br />
xPassed = xStampEnd - pulsesX;<br />
yPassed = pulsesY - yStampEnd;</p>
<p dir="auto">sendX = 1023 + 100 * xPassed / timePassed;<br />
sendY = 1023 + 100 * yPassed / timePassed;</p>
<p dir="auto">for (int i = 0; i &lt; 1; i++) {     //Maybe this one is not needed. Will find it out later</p>
mySBUS.Update();
mySBUS.Send();
delay(sbusWAIT);
<p dir="auto">}</p>
<p dir="auto">xStampEnd = pulsesX;<br />
yStampEnd = pulsesY;<br />
timeStampEnd = millis();<br />
<p dir="auto">//Rotary Encoder Stuff by KinoWheels</p>
<p dir="auto">void XA_RISE() {<br />
detachInterrupt(0);<br />
//delay(1);<br />
XA_SIG = 1;</p>
<p dir="auto">if (XB_SIG == 0)<br />
pulsesX++;//moving forward<br />
if (XB_SIG == 1)<br />
pulsesX--;//moving reverse</p>
<p dir="auto">attachInterrupt(0, XA_FALL, FALLING);<br />
<p dir="auto">void XA_FALL() {<br />
//delay(1);<br />
XA_SIG = 0;</p>
<p dir="auto">if (XB_SIG == 1)<br />
<p dir="auto">attachInterrupt(0, XA_RISE, RISING);<br />
<p dir="auto">void XB_RISE() {<br />
detachInterrupt(1);<br />
//delay(1);<br />
XB_SIG = 1;</p>
<p dir="auto">if (XA_SIG == 1)<br />
if (XA_SIG == 0)<br />
<p dir="auto">attachInterrupt(1, XB_FALL, FALLING);<br />
<p dir="auto">void XB_FALL() {<br />
//delay(1);<br />
XB_SIG = 0;</p>
<p dir="auto">if (XA_SIG == 0)<br />
<p dir="auto">attachInterrupt(1, XB_RISE, RISING);<br />
<p dir="auto">void YA_RISE() {<br />
detachInterrupt(4);<br />
//delay(1);<br />
YA_SIG = 1;</p>
<p dir="auto">if (YB_SIG == 0)<br />
pulsesY++;//moving forward<br />
if (YB_SIG == 1)<br />
pulsesY--;//moving reverse</p>
<p dir="auto">attachInterrupt(4, YA_FALL, FALLING);<br />
<p dir="auto">void YA_FALL() {<br />
//delay(1);<br />
YA_SIG = 0;</p>
<p dir="auto">if (YB_SIG == 1)<br />
<p dir="auto">attachInterrupt(4, YA_RISE, RISING);<br />
<p dir="auto">void YB_RISE() {<br />
detachInterrupt(5);<br />
//delay(1);<br />
YB_SIG = 1;</p>
<p dir="auto">if (YA_SIG == 1)<br />
if (YA_SIG == 0)<br />
<p dir="auto">attachInterrupt(5, YB_FALL, FALLING);<br />
<p dir="auto">void YB_FALL() {<br />
//delay(1);<br />
YB_SIG = 0;</p>
<p dir="auto">if (YA_SIG == 0)<br />
<p dir="auto">attachInterrupt(5, YB_RISE, RISING);<br />
]]></description><link>https://community.m5stack.com/post/9354</link><guid isPermaLink="true">https://community.m5stack.com/post/9354</guid><dc:creator><![CDATA[Lewis-H]]></dc:creator><pubDate>Fri, 17 Jul 2020 10:16:09 GMT</pubDate></item></channel></rss>
