<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[NCIR unit weird values]]></title><description><![CDATA[<p dir="auto">Hi guys!<br />
So I got a m5stack with a ncir unit. I am using uiflow to test and I am getting temperature values all over the place... I was supposed to get 4ºC+- on my fridge and it says is -10ºC !! Other measures are also not consistent....<br />
Is there any way to reset the ncir unit or something like that? Or is it possible that it is faulty? Do your units give consistent results?<br />
Thank you!</p>
]]></description><link>https://community.m5stack.com/topic/1838/ncir-unit-weird-values</link><generator>RSS for Node</generator><lastBuildDate>Tue, 28 Apr 2026 19:14:30 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/1838.rss" rel="self" type="application/rss+xml"/><pubDate>Fri, 10 Apr 2020 14:08:58 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to NCIR unit weird values on Tue, 17 Mar 2026 09:50:24 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/harrietteytlxv222" aria-label="Profile: harrietteytlxv222">@<bdi>harrietteytlxv222</bdi></a> did you read my post from Feb 12 (follow the link)? Do you use the appropriate emissivity value for your surface?</p>
]]></description><link>https://community.m5stack.com/post/30785</link><guid isPermaLink="true">https://community.m5stack.com/post/30785</guid><dc:creator><![CDATA[holofloh]]></dc:creator><pubDate>Tue, 17 Mar 2026 09:50:24 GMT</pubDate></item><item><title><![CDATA[Reply to NCIR unit weird values on Tue, 17 Mar 2026 01:23:49 GMT]]></title><description><![CDATA[<p dir="auto">Same problem with me :( Did you fix it?</p>
]]></description><link>https://community.m5stack.com/post/30783</link><guid isPermaLink="true">https://community.m5stack.com/post/30783</guid><dc:creator><![CDATA[harrietteytlxv222]]></dc:creator><pubDate>Tue, 17 Mar 2026 01:23:49 GMT</pubDate></item><item><title><![CDATA[Reply to NCIR unit weird values on Thu, 12 Feb 2026 12:42:05 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/gothicmaestro" aria-label="Profile: gothicmaestro">@<bdi>gothicmaestro</bdi></a><br />
see here: <a href="https://community.m5stack.com/topic/8081/emissivity-value-required">https://community.m5stack.com/topic/8081/emissivity-value-required</a></p>
]]></description><link>https://community.m5stack.com/post/30634</link><guid isPermaLink="true">https://community.m5stack.com/post/30634</guid><dc:creator><![CDATA[holofloh]]></dc:creator><pubDate>Thu, 12 Feb 2026 12:42:05 GMT</pubDate></item><item><title><![CDATA[Reply to NCIR unit weird values on Tue, 10 Feb 2026 20:42:23 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/tialm" aria-label="Profile: tialm">@<bdi>tialm</bdi></a> I also always have wrong temperature values</p>
]]></description><link>https://community.m5stack.com/post/30628</link><guid isPermaLink="true">https://community.m5stack.com/post/30628</guid><dc:creator><![CDATA[gothicmaestro]]></dc:creator><pubDate>Tue, 10 Feb 2026 20:42:23 GMT</pubDate></item></channel></rss>
