<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Stepper Modul GRBL Version]]></title><description><![CDATA[<p dir="auto">Hello,<br />
I have the stepper module and want to change the GRBL setting so I ask which GRBL version is 0.8, 0.9 or 1.0 installed on the module ?</p>
]]></description><link>https://community.m5stack.com/topic/1839/stepper-modul-grbl-version</link><generator>RSS for Node</generator><lastBuildDate>Wed, 29 Apr 2026 03:41:57 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/1839.rss" rel="self" type="application/rss+xml"/><pubDate>Fri, 10 Apr 2020 21:09:25 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Stepper Modul GRBL Version on Sat, 11 Apr 2020 07:06:42 GMT]]></title><description><![CDATA[<p dir="auto">I cant be 100% over this but it looks to be stock old firmware.<br />
I broke mine this week so been researching how to build a new one using updated firmware and TMC2209 drivers.</p>
]]></description><link>https://community.m5stack.com/post/8113</link><guid isPermaLink="true">https://community.m5stack.com/post/8113</guid><dc:creator><![CDATA[ajb2k3]]></dc:creator><pubDate>Sat, 11 Apr 2020 07:06:42 GMT</pubDate></item><item><title><![CDATA[Reply to Stepper Modul GRBL Version on Sat, 11 Apr 2020 01:29:03 GMT]]></title><description><![CDATA[<p dir="auto">It should be possible to flash newer firmware to the module via the pins on the side. I'm not sure if any tweaks are required to use the latest firmware with the stack though</p>
]]></description><link>https://community.m5stack.com/post/8108</link><guid isPermaLink="true">https://community.m5stack.com/post/8108</guid><dc:creator><![CDATA[lukasmaximus]]></dc:creator><pubDate>Sat, 11 Apr 2020 01:29:03 GMT</pubDate></item><item><title><![CDATA[Reply to Stepper Modul GRBL Version on Fri, 10 Apr 2020 23:23:36 GMT]]></title><description><![CDATA[<p dir="auto">this is an old version :-(<br />
For example, X-STEP per mm is $0 and not $100</p>
<p dir="auto">$0  =     X-STEP per mm	<br />
$1  =     Y-STEP per mm	<br />
$2    =     Z-STEP per mm</p>
]]></description><link>https://community.m5stack.com/post/8107</link><guid isPermaLink="true">https://community.m5stack.com/post/8107</guid><dc:creator><![CDATA[plusulli]]></dc:creator><pubDate>Fri, 10 Apr 2020 23:23:36 GMT</pubDate></item><item><title><![CDATA[Reply to Stepper Modul GRBL Version on Fri, 10 Apr 2020 21:25:19 GMT]]></title><description><![CDATA[<p dir="auto">If I read it correctly. Is the mega328 on the module stepper flashed with version 0.8c<br />
Source of the information is on Github<br />
If you follow the link below and look at line 28.<br />
<a href="https://github.com/m5stack/stepmotor_module/blob/master/Firmware%20for%20stepmotor%20module/GRBL-Arduino-Library/settings.h" target="_blank" rel="noopener noreferrer nofollow ugc">https://github.com/m5stack/stepmotor_module/blob/master/Firmware for stepmotor module/GRBL-Arduino-Library/settings.h</a></p>
]]></description><link>https://community.m5stack.com/post/8106</link><guid isPermaLink="true">https://community.m5stack.com/post/8106</guid><dc:creator><![CDATA[Pepsi]]></dc:creator><pubDate>Fri, 10 Apr 2020 21:25:19 GMT</pubDate></item></channel></rss>
