<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[flash m5stack fisheyes camera ov2640]]></title><description><![CDATA[<p dir="auto">Hello,</p>
<p dir="auto">I am a beginner and I want to flash my camera :<br />
I try with ESP-IDF but i have an error with my Windows10.<br />
It'll be to simple with Arduino.<br />
I just want to connect this cam to supervisor.<br />
Now, I can't use it. Cant you help me please</p>
<p dir="auto">Thank you</p>
]]></description><link>https://community.m5stack.com/topic/1855/flash-m5stack-fisheyes-camera-ov2640</link><generator>RSS for Node</generator><lastBuildDate>Wed, 29 Apr 2026 19:11:55 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/1855.rss" rel="self" type="application/rss+xml"/><pubDate>Thu, 16 Apr 2020 18:47:04 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to flash m5stack fisheyes camera ov2640 on Sun, 19 Apr 2020 12:23:27 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sheepdog" aria-label="Profile: sheepdog">@<bdi>sheepdog</bdi></a> said in <a href="/post/8220">flash m5stack fisheyes camera ov2640</a>:</p>
<p dir="auto">Which esp-idf version did you use? You can get the Version with: $ git describe</p>
<p dir="auto">In the begining with esp-idf v4.2<br />
And with esp-idf 3.3 realease<br />
can't finish "build"</p>
<p dir="auto">Adding ESP-IDF tools to PATH...<br />
Not using an unsupported version of tool xtensa-esp32-elf found in PATH: esp-2020r1-8.2.0.<br />
Not using an unsupported version of tool cmake found in PATH: 3.16.4.<br />
Not using an unsupported version of tool openocd-esp32 found in PATH: v0.10.0-esp32-20200406.<br />
Not using an unsupported version of tool ninja found in PATH: 1.10.0.<br />
C:\Users\oxyrace.espressif\tools\xtensa-esp32-elf\1.22.0-80-g6c4433a5-5.2.0\xtensa-esp32-elf\bin<br />
C:\Users\oxyrace.espressif\tools\esp32ulp-elf\2.28.51.20170517\esp32ulp-elf-binutils\bin<br />
C:\Users\oxyrace.espressif\tools\cmake\3.13.4\bin<br />
C:\Users\oxyrace.espressif\tools\openocd-esp32\v0.10.0-esp32-20190313\openocd-esp32\bin<br />
C:\Users\oxyrace.espressif\tools\mconf\v4.6.0.0-idf-20190628<br />
C:\Users\oxyrace.espressif\tools\ninja\1.9.0<br />
C:\Users\oxyrace.espressif\tools\idf-exe\1.0.1<br />
C:\Users\oxyrace.espressif\tools\ccache\3.7<br />
C:\Users\oxyrace.espressif\python_env\idf3.3_py3.8_env\Scripts</p>
<p dir="auto">[836/837] Linking CXX executable camera.elf<br />
FAILED: camera.elf<br />
cmd.exe /C "cd . &amp;&amp; C:\Users\oxyrace.espressif\tools\xtensa-esp32-elf\1.22.0-80-g6c4433a5-5.2.0\xtensa-esp32-elf\bin\xtensa-esp32-elf-g++.exe  -mlongcalls  -nostdlib @CMakeFiles\camera.elf.rsp  -o camera.elf  &amp;&amp; cd ."<br />
esp-idf/main/libmain.a(main.c.obj):(.literal.app_main+0x18): undefined reference to <code>led_brightness' esp-idf/main/libmain.a(main.c.obj): In function </code>app_main':<br />
D:\ESP32\esp-idf\examples\m5stack\wifi\wifi_sta\build/../main/main.c:89: undefined reference to `led_brightness'<br />
collect2.exe: error: ld returned 1 exit status<br />
ninja: build stopped: subcommand failed.<br />
ninja failed with exit code 1</p>
]]></description><link>https://community.m5stack.com/post/8226</link><guid isPermaLink="true">https://community.m5stack.com/post/8226</guid><dc:creator><![CDATA[Tchill73]]></dc:creator><pubDate>Sun, 19 Apr 2020 12:23:27 GMT</pubDate></item><item><title><![CDATA[Reply to flash m5stack fisheyes camera ov2640 on Sun, 19 Apr 2020 04:56:25 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/tchill73" aria-label="Profile: Tchill73">@<bdi>Tchill73</bdi></a>  Which esp-idf version did you use? You can get the Version with: $ git describe</p>
]]></description><link>https://community.m5stack.com/post/8220</link><guid isPermaLink="true">https://community.m5stack.com/post/8220</guid><dc:creator><![CDATA[sheepDog]]></dc:creator><pubDate>Sun, 19 Apr 2020 04:56:25 GMT</pubDate></item><item><title><![CDATA[Reply to flash m5stack fisheyes camera ov2640 on Sat, 18 Apr 2020 16:05:50 GMT]]></title><description><![CDATA[<p dir="auto">Can you post your folder Sdkconfig please<br />
maybe , there is an incorrect parameter.</p>
]]></description><link>https://community.m5stack.com/post/8217</link><guid isPermaLink="true">https://community.m5stack.com/post/8217</guid><dc:creator><![CDATA[Tchill73]]></dc:creator><pubDate>Sat, 18 Apr 2020 16:05:50 GMT</pubDate></item><item><title><![CDATA[Reply to flash m5stack fisheyes camera ov2640 on Sat, 18 Apr 2020 16:00:10 GMT]]></title><description><![CDATA[<p dir="auto">Hello, tank you for your reply.</p>
<p dir="auto">I tried with the firmeware for the camera F but it does not work.<br />
M5camera V1.0.0<br />
error :<br />
17:37:46.943 -&gt; [0;31mE (90518) task_wdt: Task watchdog got triggered. The following tasks did not reset the watchdog in time:[0m<br />
17:37:46.943 -&gt; [0;31mE (90518) task_wdt:  - IDLE0 (CPU 0)[0m<br />
17:37:46.943 -&gt; [0;31mE (90518) task_wdt: Tasks currently running:[0m<br />
17:37:46.943 -&gt; [0;31mE (90518) task_wdt: CPU 0: main[0m<br />
17:37:46.943 -&gt; [0;31mE (90518) task_wdt: CPU 1: IDLE1[0m</p>
<p dir="auto">I try with ESP-IDF (Windows 10)<br />
5stack-cam-psram-master\m5stack-cam-psram-master\wifi\wifi_sta\firmware\Camera F<br />
I am sure there is not much missing</p>
<p dir="auto">The error is :</p>
<p dir="auto">'FAILED: esp-idf/main/CMakeFiles/__idf_main.dir/main.c.obj<br />
ccache C:.espressif\tools\xtensa-esp32-elf\esp-2020r1-8.2.0\xtensa-esp32-elf\bin\xtensa-esp32-elf-gcc.exe -DHAVE_CONFIG_H -DMBEDTLS_CONFIG_FILE="mbedtls/esp_config.h" -DUNITY_INCLUDE_CONFIG_H -DWITH_POSIX -Iconfig -I../main -I../../../../components/newlib/platform_include -I../../../../components/freertos/include -I../../../../components/freertos/xtensa/include -I../../../../components/heap/include -I../../../../components/log/include -I../../../../components/lwip/include/apps -I../../../../components/lwip/include/apps/sntp -I../../../../components/lwip/lwip/src/include -I../../../../components/lwip/port/esp32/include -I../../../../components/lwip/port/esp32/include/arch -I../../../../components/soc/src/esp32/. -I../../../../components/soc/src/esp32/include -I../../../../components/soc/include -I../../../../components/esp_rom/include -I../../../../components/esp_common/include -I../../../../components/esp_system/include -I../../../../components/xtensa/include -I../../../../components/xtensa/esp32/include -I../../../../components/esp32/include -I../../../../components/driver/include -I../../../../components/driver/esp32/include -I../../../../components/esp_ringbuf/include -I../../../../components/efuse/include -I../../../../components/efuse/esp32/include -I../../../../components/espcoredump/include -I../../../../components/esp_timer/include -I../../../../components/soc/soc/esp32/. -I../../../../components/soc/soc/esp32/include -I../../../../components/soc/soc/esp32/../include -I../../../../components/vfs/include -I../../../../components/esp_wifi/include -I../../../../components/esp_wifi/esp32/include -I../../../../components/esp_event/include -I../../../../components/esp_netif/include -I../../../../components/esp_eth/include -I../../../../components/tcpip_adapter/include -I../../../../components/app_trace/include -I../../../../components/mbedtls/port/include -I../../../../components/mbedtls/mbedtls/include -I../../../../components/mbedtls/esp_crt_bundle/include -I../../../../components/bootloader_support/include -I../../../../components/app_update/include -I../../../../components/spi_flash/include -I../../../../components/wpa_supplicant/include -I../../../../components/wpa_supplicant/port/include -I../../../../components/wpa_supplicant/include/esp_supplicant -I../../../../components/nvs_flash/include -I../../../../components/pthread/include -I../../../../components/perfmon/include -I../../../../components/asio/asio/asio/include -I../../../../components/asio/port/include -I../../../../components/cbor/port/include -I../../../../components/coap/port/include -I../../../../components/coap/port/include/coap -I../../../../components/coap/libcoap/include -I../../../../components/coap/libcoap/include/coap2 -I../../../../components/console -I../../../../components/nghttp/port/include -I../../../../components/nghttp/nghttp2/lib/includes -I../../../../components/esp-tls -I../../../../components/esp_adc_cal/include -I../../../../components/esp_gdbstub/include -I../../../../components/tcp_transport/include -I../../../../components/esp_http_client/include -I../../../../components/esp_http_server/include -I../../../../components/esp_https_ota/include -I../../../../components/protobuf-c/protobuf-c -I../../../../components/protocomm/include/common -I../../../../components/protocomm/include/security -I../../../../components/protocomm/include/transports -I../../../../components/mdns/include -I../../../../components/esp_local_ctrl/include -I../../../../components/sdmmc/include -I../../../../components/esp_serial_slave_link/include -I../../../../components/esp_websocket_client/include -I../../../../components/expat/expat/expat/lib -I../../../../components/expat/port/include -I../../../../components/wear_levelling/include -I../../../../components/fatfs/diskio -I../../../../components/fatfs/vfs -I../../../../components/fatfs/src -I../../../../components/freemodbus/common/include -I../../../../components/idf_test/include -I../../../../components/idf_test/include/esp32 -I../../../../components/jsmn/include -I../../../../components/json/cJSON -I../../../../components/libsodium/libsodium/src/libsodium/include -I../../../../components/libsodium/port_include -I../../../../components/mqtt/esp-mqtt/include -I../../../../components/openssl/include -I../../../../components/spiffs/include -I../../../../components/ulp/include -I../../../../components/unity/include -I../../../../components/unity/unity/src -I../../../../components/wifi_provisioning/include -I../components/esp32-camera/driver/include -I../components/esp32-camera/conversions/include -mlongcalls -Wno-frame-address   -ffunction-sections -fdata-sections -fstrict-volatile-bitfields -Wall -Werror=all -Wno-error=unused-function -Wno-error=unused-but-set-variable -Wno-error=unused-variable -Wno-error=deprecated-declarations -Wextra -Wno-unused-parameter -Wno-sign-compare -ggdb -Og -std=gnu99 -Wno-old-style-declaration -D_GNU_SOURCE -DIDF_VER="v4.2-dev-1126-gd85d3d969" -DESP_PLATFORM -MD -MT esp-idf/main/CMakeFiles/__idf_main.dir/main.c.obj -MF esp-idf\main\CMakeFiles__idf_main.dir\main.c.obj.d -o esp-idf/main/CMakeFiles/__idf_main.dir/main.c.obj   -c ../main/main.c<br />
In file included from ../main/main.c:15:<br />
../../../../components/esp_event/include/esp_event_loop.h:2:2: warning: #warning "esp_event_loop.h is deprecated, please include esp_event.h instead" [-Wcpp]<br />
#warning "esp_event_loop.h is deprecated, please include esp_event.h instead"<br />
^~~~~~~<br />
In file included from ../main/main.c:9:<br />
../main/main.c: In function 'event_handler':<br />
../main/main.c:238:47: warning: passing argument 1 of 'ip4addr_ntoa' from incompatible pointer type [-Wincompatible-pointer-types]<br />
ESP_LOGI(TAG, "got ip:%s", ip4addr_ntoa(&amp;event-&gt;event_info.got_ip.ip_info.ip));<br />
^~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~<br />
../../../../components/log/include/esp_log.h:329:137: note: in definition of macro 'ESP_LOG_LEVEL'<br />
if (level==ESP_LOG_ERROR )          { esp_log_write(ESP_LOG_ERROR,      tag, LOG_FORMAT(E, format), esp_log_timestamp(), tag, ##<strong>VA_ARGS</strong>); } <br />
^~~~~~~~~~~<br />
../../../../components/log/include/esp_log.h:296:38: note: in expansion of macro 'ESP_LOG_LEVEL_LOCAL'<br />
#define ESP_LOGI( tag, format, ... ) ESP_LOG_LEVEL_LOCAL(ESP_LOG_INFO,    tag, format, ##<strong>VA_ARGS</strong>)<br />
^~~~~~~~~~~~~~~~~~~<br />
../main/main.c:238:7: note: in expansion of macro 'ESP_LOGI'<br />
^~~~~~~~<br />
In file included from ../../../../components/lwip/lwip/src/include/lwip/ip_addr.h:43,<br />
from ../../../../components/tcpip_adapter/include/tcpip_adapter_types.h:18,<br />
from ../../../../components/tcpip_adapter/include/tcpip_adapter.h:24,<br />
from ../../../../components/esp_netif/include/esp_netif.h:35,<br />
from ../../../../components/esp_event/include/esp_event_legacy.h:22,<br />
from ../../../../components/esp_event/include/esp_event.h:26,<br />
from ../../../../components/esp_wifi/include/esp_wifi.h:64,<br />
from ../main/main.c:11:<br />
../../../../components/lwip/lwip/src/include/lwip/ip4_addr.h:207:7: note: expected 'const ip4_addr_t *' {aka 'const struct ip4_addr *'} but argument is of type 'esp_ip4_addr_t *' {aka 'struct esp_ip4_addr *'}<br />
char *ip4addr_ntoa(const ip4_addr_t *addr);<br />
^~~~~~~~~~~~<br />
../../../../components/log/include/esp_log.h:330:137: note: in definition of macro 'ESP_LOG_LEVEL'<br />
else if (level==ESP_LOG_WARN )      { esp_log_write(ESP_LOG_WARN,       tag, LOG_FORMAT(W, format), esp_log_timestamp(), tag, ##<strong>VA_ARGS</strong>); } <br />
^~~~~~~~~~~<br />
^~~~~~~~<br />
^~~~~~~~~~~~<br />
../../../../components/log/include/esp_log.h:331:137: note: in definition of macro 'ESP_LOG_LEVEL'<br />
else if (level==ESP_LOG_DEBUG )     { esp_log_write(ESP_LOG_DEBUG,      tag, LOG_FORMAT(D, format), esp_log_timestamp(), tag, ##<strong>VA_ARGS</strong>); } <br />
^~~~~~~~~~~<br />
^~~~~~~~<br />
^~~~~~~~~~~~<br />
../../../../components/log/include/esp_log.h:332:137: note: in definition of macro 'ESP_LOG_LEVEL'<br />
else if (level==ESP_LOG_VERBOSE )   { esp_log_write(ESP_LOG_VERBOSE,    tag, LOG_FORMAT(V, format), esp_log_timestamp(), tag, ##<strong>VA_ARGS</strong>); } <br />
^~~~~~~~~~~<br />
^~~~~~~~<br />
^~~~~~~~~~~~<br />
../../../../components/log/include/esp_log.h:333:137: note: in definition of macro 'ESP_LOG_LEVEL'<br />
else                                { esp_log_write(ESP_LOG_INFO,       tag, LOG_FORMAT(I, format), esp_log_timestamp(), tag, ##<strong>VA_ARGS</strong>); } <br />
^~~~~~~~~~~<br />
^~~~~~~~<br />
^~~~~~~~~~~~<br />
../main/main.c:239:17: error: incompatible types when assigning to type 'ip4_addr_t' {aka 'struct ip4_addr'} from type 'esp_ip4_addr_t' {aka 'struct esp_ip4_addr'}<br />
s_ip_addr = event-&gt;event_info.got_ip.ip_info.ip;<br />
^<br />
../main/main.c: In function 'wifi_init_softap':<br />
../main/main.c:266:3: warning: 'tcpip_adapter_init' is deprecated [-Wdeprecated-declarations]<br />
tcpip_adapter_init();<br />
^~~~~~~~~~~~~~~~~~<br />
In file included from ../../../../components/esp_netif/include/esp_netif.h:35,<br />
../../../../components/tcpip_adapter/include/tcpip_adapter.h:34:6: note: declared here<br />
void tcpip_adapter_init(void)  <strong>attribute</strong> ((deprecated));<br />
../main/main.c:267:3: warning: 'esp_event_loop_init' is deprecated [-Wdeprecated-declarations]<br />
ESP_ERROR_CHECK(esp_event_loop_init(event_handler, NULL));<br />
^~~~~~~~~~~~~~~<br />
In file included from ../../../../components/esp_event/include/esp_event.h:26,<br />
../../../../components/esp_event/include/esp_event_legacy.h:227:11: note: declared here<br />
esp_err_t esp_event_loop_init(system_event_cb_t cb, void *ctx) <strong>attribute</strong> ((deprecated));<br />
[926/936] Building C object esp-idf/esp32-camera/CMakeFiles/__idf_esp32-camera.dir/driver/camera.c.obj<br />
In file included from ../components/esp32-camera/driver/camera.c:22:<br />
../../../../components/esp32/include/rom/lldesc.h:1:2: warning: #warning rom/lldesc.h is deprecated, please use esp32/rom/lldesc.h instead [-Wcpp]<br />
#warning rom/lldesc.h is deprecated, please use esp32/rom/lldesc.h instead<br />
^~~~~~~<br />
In file included from ../components/esp32-camera/driver/private_include/camera_common.h:6,<br />
from ../components/esp32-camera/driver/camera.c:35:<br />
^~~~~~~<br />
[927/936] Building CXX object esp-idf/esp32-camera/CMakeFiles/__idf_esp32-camera.dir/conversions/to_jpg.cpp.obj<br />
In file included from ../components/esp32-camera/conversions/to_jpg.cpp:16:<br />
../../../../components/esp32/include/esp_spiram.h:1:2: warning: #warning esp_spiram.h has been replaced by esp32/spiram.h, please include esp32/spiram.h instead [-Wcpp]<br />
#warning esp_spiram.h has been replaced by esp32/spiram.h, please include esp32/spiram.h instead'</p>
<p dir="auto">ninja: build stopped: subcommand failed.<br />
]]></description><link>https://community.m5stack.com/post/8216</link><guid isPermaLink="true">https://community.m5stack.com/post/8216</guid><dc:creator><![CDATA[Tchill73]]></dc:creator><pubDate>Sat, 18 Apr 2020 16:00:10 GMT</pubDate></item><item><title><![CDATA[Reply to flash m5stack fisheyes camera ov2640 on Fri, 17 Apr 2020 04:15:44 GMT]]></title><description><![CDATA[<p dir="auto">Hello <a class="plugin-mentions-user plugin-mentions-a" href="/user/tchill73" aria-label="Profile: Tchill73">@<bdi>Tchill73</bdi></a>, please post the Arduino error message. I used m5stack cam with ESP-IDF and it worked fine.</p>
]]></description><link>https://community.m5stack.com/post/8186</link><guid isPermaLink="true">https://community.m5stack.com/post/8186</guid><dc:creator><![CDATA[sheepDog]]></dc:creator><pubDate>Fri, 17 Apr 2020 04:15:44 GMT</pubDate></item><item><title><![CDATA[Reply to flash m5stack fisheyes camera ov2640 on Fri, 17 Apr 2020 03:54:42 GMT]]></title><description><![CDATA[<p dir="auto">Hey <a class="plugin-mentions-user plugin-mentions-a" href="/user/tchill73" aria-label="Profile: Tchill73">@<bdi>Tchill73</bdi></a> if you want to use the stock firmware you can use the m5burner tool <a href="https://m5stack.com/pages/download" target="_blank" rel="noopener noreferrer nofollow ugc">https://m5stack.com/pages/download</a> if you have your own firmware its better to use esptool</p>
]]></description><link>https://community.m5stack.com/post/8185</link><guid isPermaLink="true">https://community.m5stack.com/post/8185</guid><dc:creator><![CDATA[lukasmaximus]]></dc:creator><pubDate>Fri, 17 Apr 2020 03:54:42 GMT</pubDate></item></channel></rss>
