<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[How to record audio from the internal microphone then play it through the speaker?]]></title><description><![CDATA[<p dir="auto">Is there an example on how to record audio on the M5Stack using the internal microphone? I could only find a microphone example for the M5StickC: <a href="https://github.com/m5stack/M5StickC/blob/master/examples/Basics/Micophone/Micophone.ino" target="_blank" rel="noopener noreferrer nofollow ugc">https://github.com/m5stack/M5StickC/blob/master/examples/Basics/Micophone/Micophone.ino</a></p>
<p dir="auto">But I don't even know what it does as there are no comments in that file.</p>
<p dir="auto">I've tried replacing <strong>#include &lt;M5StickC.h&gt;</strong> with <strong>#include &lt;M5Stack.h&gt;</strong> and flash it, but then it didn't do anyhting besides showing the text <strong>mic test</strong> on the display.</p>
]]></description><link>https://community.m5stack.com/topic/1863/how-to-record-audio-from-the-internal-microphone-then-play-it-through-the-speaker</link><generator>RSS for Node</generator><lastBuildDate>Wed, 29 Apr 2026 01:00:13 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/1863.rss" rel="self" type="application/rss+xml"/><pubDate>Sun, 19 Apr 2020 12:02:10 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to How to record audio from the internal microphone then play it through the speaker? on Fri, 17 Jul 2020 10:06:34 GMT]]></title><description><![CDATA[<p dir="auto">The easiest way to extract the sound from a video is to use our audio converter.<br />
Open the audio converter.<br />
Click "Open files".<br />
In the resulting window select the file you wish to extract the sound from. ...<br />
While the sound is being extracted, choose the format in which you want to convert the sound.</p>
]]></description><link>https://community.m5stack.com/post/9352</link><guid isPermaLink="true">https://community.m5stack.com/post/9352</guid><dc:creator><![CDATA[Lewis-H]]></dc:creator><pubDate>Fri, 17 Jul 2020 10:06:34 GMT</pubDate></item><item><title><![CDATA[Reply to How to record audio from the internal microphone then play it through the speaker? on Fri, 10 Jul 2020 09:29:41 GMT]]></title><description><![CDATA[<p dir="auto">It's a little late, but there's a M5stack Plus module now that includes a battery (400 or 500 mAh, the official page can't make up its mind), a rotary encoder and a microphone. Still adds a bit of bulk, but if that other little microphone didn't work out it might be worth it. I think the rotary encoder will be a great addition to a watch as you get extra controls (rotation and I think the little wheel can be pressed and used as another button) and using the wheel to set the time and alarms is probably faster and more enjoyable then using buttons.</p>
<p dir="auto">Btw from what I've read and heard the speaker audio isn't amazing, because the DAC on an ESP32 just isn't as high res as a good audio Dac. Fine for some alarms and stuff and probably even usable as a memo recorder, but not something you'd use for music.</p>
]]></description><link>https://community.m5stack.com/post/9293</link><guid isPermaLink="true">https://community.m5stack.com/post/9293</guid><dc:creator><![CDATA[OttovanZanten]]></dc:creator><pubDate>Fri, 10 Jul 2020 09:29:41 GMT</pubDate></item><item><title><![CDATA[Reply to How to record audio from the internal microphone then play it through the speaker? on Mon, 20 Apr 2020 22:04:27 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/somedude" aria-label="Profile: somedude">@<bdi>somedude</bdi></a><br />
The M5GO/Fire Battery Bottom has got a microphone + a MAX4466  built in. According the schematics it is connected to GPIO 34 of the M5Stack core.</p>
]]></description><link>https://community.m5stack.com/post/8274</link><guid isPermaLink="true">https://community.m5stack.com/post/8274</guid><dc:creator><![CDATA[crami25]]></dc:creator><pubDate>Mon, 20 Apr 2020 22:04:27 GMT</pubDate></item><item><title><![CDATA[Reply to How to record audio from the internal microphone then play it through the speaker? on Mon, 20 Apr 2020 20:14:40 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/somedude" aria-label="Profile: somedude">@<bdi>somedude</bdi></a> said in <a href="/post/8268">How to record audio from the internal microphone then play it through the speaker?</a>:</p>
<p dir="auto">Thanks, but that's too big and I'm not sure if it's compatible with the watch kit.<br />
I think I'm gonna try to get it to work with a MAX4466 or SPM1423. <a href="http://community.m5stack.com/topic/1864/adding-a-microphone-to-the-core-watch-kit/" target="_blank" rel="noopener noreferrer nofollow ugc">http://community.m5stack.com/topic/1864/adding-a-microphone-to-the-core-watch-kit/</a></p>
<p dir="auto">Sorry, completly forgot about that!</p>
]]></description><link>https://community.m5stack.com/post/8271</link><guid isPermaLink="true">https://community.m5stack.com/post/8271</guid><dc:creator><![CDATA[ajb2k3]]></dc:creator><pubDate>Mon, 20 Apr 2020 20:14:40 GMT</pubDate></item><item><title><![CDATA[Reply to How to record audio from the internal microphone then play it through the speaker? on Mon, 20 Apr 2020 16:12:06 GMT]]></title><description><![CDATA[<p dir="auto">Thanks, but that's too big and I'm not sure if it's compatible with the watch kit.<br />
]]></description><link>https://community.m5stack.com/post/8268</link><guid isPermaLink="true">https://community.m5stack.com/post/8268</guid><dc:creator><![CDATA[somedude]]></dc:creator><pubDate>Mon, 20 Apr 2020 16:12:06 GMT</pubDate></item><item><title><![CDATA[Reply to How to record audio from the internal microphone then play it through the speaker? on Mon, 20 Apr 2020 09:21:56 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/somedude" aria-label="Profile: somedude">@<bdi>somedude</bdi></a> said in <a href="/post/8228">How to record audio from the internal microphone then play it through the speaker?</a>:</p>
<p dir="auto">I think I just realized that the M5Stack doesn't have a built-in microphone.</p>
<p dir="auto">Yes, the M5Stack cores do not have microphones.</p>
<p dir="auto">You need one of these <a href="https://m5stack.com/collections/m5-base/products/node-module?ref=pfpqkvphmgr&amp;variant=16804787978330" target="_blank" rel="noopener noreferrer nofollow ugc">https://m5stack.com/collections/m5-base/products/node-module?ref=pfpqkvphmgr&amp;variant=16804787978330</a></p>
]]></description><link>https://community.m5stack.com/post/8248</link><guid isPermaLink="true">https://community.m5stack.com/post/8248</guid><dc:creator><![CDATA[ajb2k3]]></dc:creator><pubDate>Mon, 20 Apr 2020 09:21:56 GMT</pubDate></item><item><title><![CDATA[Reply to How to record audio from the internal microphone then play it through the speaker? on Sun, 19 Apr 2020 16:49:14 GMT]]></title><description><![CDATA[<p dir="auto">I think I just realized that the M5Stack doesn't have a built-in microphone.</p>
]]></description><link>https://community.m5stack.com/post/8228</link><guid isPermaLink="true">https://community.m5stack.com/post/8228</guid><dc:creator><![CDATA[somedude]]></dc:creator><pubDate>Sun, 19 Apr 2020 16:49:14 GMT</pubDate></item></channel></rss>
