<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[PowerC I2C and power switch]]></title><description><![CDATA[<p dir="auto">Re: <a href="/topic/1643/powerc">PowerC</a><br />
Just got one of these to use with an I2C device needing more power.  PowerC hat came with the power switch broken in pieces.  Did not realize the hat  blocks access to the 8 pin header. Anyone know the pinout on the 4 pin connector marked Port A which I understand is an I2C output, no datasheet found ?  Anyone have one that has a working  power switch or workaround?</p>
]]></description><link>https://community.m5stack.com/topic/1901/powerc-i2c-and-power-switch</link><generator>RSS for Node</generator><lastBuildDate>Sat, 02 May 2026 13:01:34 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/1901.rss" rel="self" type="application/rss+xml"/><pubDate>Sun, 26 Apr 2020 16:20:13 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to PowerC I2C and power switch on Mon, 27 Apr 2020 08:43:44 GMT]]></title><description><![CDATA[<p dir="auto">There are quite a few pin outs for pin A as its a groove i2c port.<br />
From power button side<br />
White  - SCl<br />
Yellow - SDA<br />
Red - 5V<br />
Black - GND</p>
<p dir="auto">Please note that there are some cables with the white and yellow wires switched.</p>
]]></description><link>https://community.m5stack.com/post/8380</link><guid isPermaLink="true">https://community.m5stack.com/post/8380</guid><dc:creator><![CDATA[ajb2k3]]></dc:creator><pubDate>Mon, 27 Apr 2020 08:43:44 GMT</pubDate></item></channel></rss>
