<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[The external DC input voltage for BaseX module]]></title><description><![CDATA[<p dir="auto">I have purchased one Base X and been playing with this module. According to the documentation, for motor stability, it is suggested to use an external DC power source with the voltage from 9 to 12 V. In the same documentation there is a picture that says "External input 9~12V DC (5V for servos, 9V for motors)". I want to make sure that if I plug a DC adapter with the voltage 9-12 V then the internal circuit of Base X will drop (regulate) the input voltage to 9V in the motor ports and to 5 V in the servo ports? I worry that a high input voltage will damage the Lego motors or the servo motors.</p>
]]></description><link>https://community.m5stack.com/topic/1903/the-external-dc-input-voltage-for-basex-module</link><generator>RSS for Node</generator><lastBuildDate>Wed, 29 Apr 2026 15:46:01 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/1903.rss" rel="self" type="application/rss+xml"/><pubDate>Mon, 27 Apr 2020 00:34:30 GMT</pubDate><ttl>60</ttl></channel></rss>
