<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[I2C error when GOPlus servo + Grove Ultrasonic sensor]]></title><description><![CDATA[<p dir="auto">Hi<br />
i try to use servo connected to GOPlus module and UtraSonic sensor  SR 04.</p>
<p dir="auto">The SR04 with the classical 4 pins (trig and echo) works well alone (pin 21 and 22 )<br />
When a servo is connected : it doesn't work anymore : i2Cbus error 110 (detail : File <a href="http://I2c-bus.py" target="_blank" rel="noopener noreferrer nofollow ugc">I2c-bus.py</a> line 41 in write_U8 OSError 110.</p>
<p dir="auto">I thought first it was a problem with SR04 connexion on pin 21 and 22.<br />
So i wanted to try the grove US sensor. But i  didn't find a unit block.<br />
(see <a href="https://forum.m5stack.com/topic/1907/uiflow-and-unit-grove-ultrasonic-distance-sensor" target="_blank" rel="noopener noreferrer nofollow ugc">https://forum.m5stack.com/topic/1907/uiflow-and-unit-grove-ultrasonic-distance-sensor</a>)</p>
<p dir="auto">But i ve found this morning :<br />
The I2C Error 110 occurs when Grove US sensor is connected on Port A and the servo stopped.<br />
There is no similar error when Grove US sensor is connecter to port PB1 on GOPLUS module</p>
<p dir="auto">Why ?</p>
]]></description><link>https://community.m5stack.com/topic/1917/i2c-error-when-goplus-servo-grove-ultrasonic-sensor</link><generator>RSS for Node</generator><lastBuildDate>Wed, 29 Apr 2026 12:22:20 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/1917.rss" rel="self" type="application/rss+xml"/><pubDate>Fri, 01 May 2020 10:53:34 GMT</pubDate><ttl>60</ttl></channel></rss>
