<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[M5StickV Firmware_v5.1.2]]></title><description><![CDATA[<p dir="auto">M5StickV Firmware_v5.1.2 Upgrade time : 2020.05.01</p>
<p dir="auto">log:</p>
<li>Optimize picture display</li>
<p dir="auto">Firmwae file Download links:</p>
<p dir="auto"><a href="https://m5stack.oss-cn-shenzhen.aliyuncs.com/resource/docs/M5StickV_Firmware_v5.1.2.kfpkg" target="_blank" rel="noopener noreferrer nofollow ugc">https://m5stack.oss-cn-shenzhen.aliyuncs.com/resource/docs/M5StickV_Firmware_v5.1.2.kfpkg</a></p>
<p dir="auto">Easyloader Download links (For Windows):</p>
<p dir="auto"><a href="https://m5stack.oss-cn-shenzhen.aliyuncs.com/EasyLoader/Windows/CORE/EasyLoader_M5StickV_v5.1.2.exe" target="_blank" rel="noopener noreferrer nofollow ugc">https://m5stack.oss-cn-shenzhen.aliyuncs.com/EasyLoader/Windows/CORE/EasyLoader_M5StickV_v5.1.2.exe</a></p>
]]></description><link>https://community.m5stack.com/topic/1918/m5stickv-firmware_v5-1-2</link><generator>RSS for Node</generator><lastBuildDate>Wed, 29 Apr 2026 08:44:05 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/1918.rss" rel="self" type="application/rss+xml"/><pubDate>Fri, 01 May 2020 12:15:08 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to M5StickV Firmware_v5.1.2 on Mon, 25 May 2020 22:03:21 GMT]]></title><description><![CDATA[<p dir="auto">I'm trying to do this update on windows:</p>
<pre><code>&gt;EasyLoader_M5StickV_v5.1.2.exe
<p dir="auto">But I get a window like this, while the S in a box flashes on the display:</p>
<pre><code>[32m[1m[INFO][0m COM Port Selected Manually:  COM7 [0m
[32m[1m[INFO][0m Default baudrate is 115200 , later it may be changed to the value you set. [0m
[32m[1m[INFO][0m Trying to Enter the ISP Mode... [0m
._._._._._._._._._._._._._._._._._._._._
<p dir="auto">And then eventually "Failed" in the popup. I only get the one baudrate in the dialog, so I can't try to go slower. Any ideas on how I can make this go?</p>
]]></description><link>https://community.m5stack.com/post/8827</link><guid isPermaLink="true">https://community.m5stack.com/post/8827</guid><dc:creator><![CDATA[dclaar]]></dc:creator><pubDate>Mon, 25 May 2020 22:03:21 GMT</pubDate></item><item><title><![CDATA[Reply to M5StickV Firmware_v5.1.2 on Wed, 06 May 2020 13:15:27 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/m5stack" aria-label="Profile: m5stack">@<bdi>m5stack</bdi></a> yes, and I'm running your v-training program when having this problem...</p>
]]></description><link>https://community.m5stack.com/post/8527</link><guid isPermaLink="true">https://community.m5stack.com/post/8527</guid><dc:creator><![CDATA[kalon33]]></dc:creator><pubDate>Wed, 06 May 2020 13:15:27 GMT</pubDate></item><item><title><![CDATA[Reply to M5StickV Firmware_v5.1.2 on Wed, 06 May 2020 11:47:58 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/kalon33" aria-label="Profile: kalon33">@<bdi>kalon33</bdi></a> did you inserted SD card? the poweroff function need running in the boot program. if not it will disable. more information pls refer this link: <a href="https://forum.m5stack.com/topic/1403/m5stickv-firmware_1017-upgrade" target="_blank" rel="noopener noreferrer nofollow ugc">https://forum.m5stack.com/topic/1403/m5stickv-firmware_1017-upgrade</a></p>
]]></description><link>https://community.m5stack.com/post/8526</link><guid isPermaLink="true">https://community.m5stack.com/post/8526</guid><dc:creator><![CDATA[m5stack]]></dc:creator><pubDate>Wed, 06 May 2020 11:47:58 GMT</pubDate></item><item><title><![CDATA[Reply to M5StickV Firmware_v5.1.2 on Wed, 06 May 2020 09:35:04 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/ajb2k3" aria-label="Profile: ajb2k3">@<bdi>ajb2k3</bdi></a> No, it doesn't. So I have no way to power it off other than waiting for the battery to drain...</p>
]]></description><link>https://community.m5stack.com/post/8525</link><guid isPermaLink="true">https://community.m5stack.com/post/8525</guid><dc:creator><![CDATA[kalon33]]></dc:creator><pubDate>Wed, 06 May 2020 09:35:04 GMT</pubDate></item><item><title><![CDATA[Reply to M5StickV Firmware_v5.1.2 on Wed, 06 May 2020 09:09:03 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/kalon33" aria-label="Profile: kalon33">@<bdi>kalon33</bdi></a> does it power off if you double press?</p>
]]></description><link>https://community.m5stack.com/post/8524</link><guid isPermaLink="true">https://community.m5stack.com/post/8524</guid><dc:creator><![CDATA[ajb2k3]]></dc:creator><pubDate>Wed, 06 May 2020 09:09:03 GMT</pubDate></item><item><title><![CDATA[Reply to M5StickV Firmware_v5.1.2 on Wed, 06 May 2020 08:33:17 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/m5stack" aria-label="Profile: m5stack">@<bdi>m5stack</bdi></a> I just updated my m5stickV from 4.0 version (factory version). Unfortunately, it won't power off anymore using long press on power button, only reset. Please fix.</p>
]]></description><link>https://community.m5stack.com/post/8523</link><guid isPermaLink="true">https://community.m5stack.com/post/8523</guid><dc:creator><![CDATA[kalon33]]></dc:creator><pubDate>Wed, 06 May 2020 08:33:17 GMT</pubDate></item></channel></rss>
