<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[ATOM Matrix leds blink very shortly at random (solved by workaround)]]></title><description><![CDATA[<p dir="auto">Hi there everone,</p>
<p dir="auto">I have a ATOM matrix. I program it using the Arduino IDE.</p>
<p dir="auto">I created a program that makes a webserver out of the ATOM. This all works fine.<br />
When I call a special URL the screen changes to a color with the following code:</p>
<p dir="auto">void showGreen(){<br />
M5.dis.clear();<br />
for(int i=0;i&lt;=24;i++){<br />
M5.dis.drawpix(i, 0xff0000);<br />
}<br />
color="Green";<br />
<p dir="auto">However, when I run the program, the screen is indeed changed to green, BUT the screen keeps flashing every second or so where the color changes for just a split-second and then changes to the correct color.</p>
<p dir="auto">Anyone has any idea what can be causing this?</p>
<p dir="auto">Hope to hear from you soon,<br />
Geert</p>
]]></description><link>https://community.m5stack.com/topic/1922/atom-matrix-leds-blink-very-shortly-at-random-solved-by-workaround</link><generator>RSS for Node</generator><lastBuildDate>Wed, 29 Apr 2026 19:36:36 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/1922.rss" rel="self" type="application/rss+xml"/><pubDate>Sat, 02 May 2020 10:32:04 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to ATOM Matrix leds blink very shortly at random (solved by workaround) on Sun, 03 May 2020 17:50:04 GMT]]></title><description><![CDATA[<p dir="auto">Hi <a class="plugin-mentions-user plugin-mentions-a" href="/user/robalstona" aria-label="Profile: robalstona">@<bdi>robalstona</bdi></a> , <a class="plugin-mentions-user plugin-mentions-a" href="/user/lukasmaximus" aria-label="Profile: lukasmaximus">@<bdi>lukasmaximus</bdi></a> and <a class="plugin-mentions-user plugin-mentions-a" href="/user/hague" aria-label="Profile: hague">@<bdi>hague</bdi></a> ,</p>
<p dir="auto">First of all, thanks for your very quick response!  I found out what seems to be the problem;</p>
<p dir="auto">I was using the M5Atom.h to control the leds, and somewhere in the M5.Update() the flickering sometimes occurred. The problem was indeed solved using the fastled library.  The device works exactly as I was hoping now.</p>
<p dir="auto">For this I needed to remove M5Atom.h, because indeed some functions and variables overlap.</p>
<p dir="auto">Thanks again for pointing me in the right direction.</p>
<p dir="auto">Greetings from a very happy Geert :-)</p>
]]></description><link>https://community.m5stack.com/post/8499</link><guid isPermaLink="true">https://community.m5stack.com/post/8499</guid><dc:creator><![CDATA[kosternet]]></dc:creator><pubDate>Sun, 03 May 2020 17:50:04 GMT</pubDate></item><item><title><![CDATA[Reply to ATOM Matrix leds blink very shortly at random (solved by workaround) on Sun, 03 May 2020 12:53:40 GMT]]></title><description><![CDATA[<p dir="auto">Hi,<br />
I also never saw any flickering, but I used the M5.dis.displaybuff() method with predefined patterns.<br />
You can check the code here: <a href="https://github.com/electricidea/M5ATOM/tree/master/Tilt-Game" target="_blank" rel="noopener noreferrer nofollow ugc">https://github.com/electricidea/M5ATOM/tree/master/Tilt-Game</a></p>
<p dir="auto">Hope that helps.<br />
Hans-Günther</p>
]]></description><link>https://community.m5stack.com/post/8491</link><guid isPermaLink="true">https://community.m5stack.com/post/8491</guid><dc:creator><![CDATA[hague]]></dc:creator><pubDate>Sun, 03 May 2020 12:53:40 GMT</pubDate></item><item><title><![CDATA[Reply to ATOM Matrix leds blink very shortly at random (solved by workaround) on Sun, 03 May 2020 07:47:50 GMT]]></title><description><![CDATA[<p dir="auto">You can also  use the fastled library to control the LEDs, I didn't notice any flashing when I used it</p>
]]></description><link>https://community.m5stack.com/post/8488</link><guid isPermaLink="true">https://community.m5stack.com/post/8488</guid><dc:creator><![CDATA[lukasmaximus]]></dc:creator><pubDate>Sun, 03 May 2020 07:47:50 GMT</pubDate></item><item><title><![CDATA[Reply to ATOM Matrix leds blink very shortly at random (solved by workaround) on Sat, 02 May 2020 11:07:33 GMT]]></title><description><![CDATA[<p dir="auto">I also noticed a short blinking screen when using the cleaning function, or when showing previously set pixels.  If the screen flashes to you every second, it means that somewhere in the program the content of the matrix is ​​updated.  Look for a function called <strong>m5.dis.show()</strong> or similar somewhere in the code.  Maybe you don't need to refresh the matrix all the time, but you only need to change the color once.  I am coding in the micropyton but the names and functionality of the functions overlap with those of arduino.  I also noticed that during continuous animation random pixels can flash in red or blue.</p>
]]></description><link>https://community.m5stack.com/post/8482</link><guid isPermaLink="true">https://community.m5stack.com/post/8482</guid><dc:creator><![CDATA[robalstona]]></dc:creator><pubDate>Sat, 02 May 2020 11:07:33 GMT</pubDate></item></channel></rss>
