<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Swollen M5Stack Battery.]]></title><description><![CDATA[<p dir="auto">Hello,<br />
On one of my M5Stack devices the battery in the bottom module is swollen. That worries me!<br />
I have used the M5Stack with the additional battery module. Then both batteries are connected in parallel, right?<br />
Can that be the cause? Has anyone ever observed this when using the extra battery module?<br />
<img src="https://i.imgur.com/F4kYPJ7.jpg" alt="alt text" class=" img-fluid img-markdown" /></p>
]]></description><link>https://community.m5stack.com/topic/1924/swollen-m5stack-battery</link><generator>RSS for Node</generator><lastBuildDate>Wed, 29 Apr 2026 12:22:29 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/1924.rss" rel="self" type="application/rss+xml"/><pubDate>Sun, 03 May 2020 13:18:06 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Swollen M5Stack Battery. on Tue, 26 May 2020 23:36:44 GMT]]></title><description><![CDATA[<p dir="auto">LiPo batteries are pretty dangerous if they are deformed. I suggest you to keep it away from house.<br />
This happens to them due damage, overheat, overcharge and other usage with impropriate conditions.</p>
]]></description><link>https://community.m5stack.com/post/8835</link><guid isPermaLink="true">https://community.m5stack.com/post/8835</guid><dc:creator><![CDATA[Thrasher]]></dc:creator><pubDate>Tue, 26 May 2020 23:36:44 GMT</pubDate></item><item><title><![CDATA[Reply to Swollen M5Stack Battery. on Mon, 25 May 2020 10:00:00 GMT]]></title><description><![CDATA[<p dir="auto">where did you buy it ? the best solution is contact the store. after order confirm we will help you solve it.</p>
]]></description><link>https://community.m5stack.com/post/8823</link><guid isPermaLink="true">https://community.m5stack.com/post/8823</guid><dc:creator><![CDATA[m5stack]]></dc:creator><pubDate>Mon, 25 May 2020 10:00:00 GMT</pubDate></item><item><title><![CDATA[Reply to Swollen M5Stack Battery. on Sat, 23 May 2020 21:51:30 GMT]]></title><description><![CDATA[<p dir="auto">I have the very same issue with one of my m5stacks. The battery is so swollen that I cannot plug the keypad.</p>
<p dir="auto"><a href="https://i.imgur.com/CmhRGtm.jpg" target="_blank" rel="noopener noreferrer nofollow ugc">https://i.imgur.com/CmhRGtm.jpg</a><br />
<a href="https://i.imgur.com/v4oDisv.jpg" target="_blank" rel="noopener noreferrer nofollow ugc">https://i.imgur.com/v4oDisv.jpg</a></p>
<p dir="auto">Did you contact support as suggested? What's the best way to fix this? Thanks in advance</p>
]]></description><link>https://community.m5stack.com/post/8808</link><guid isPermaLink="true">https://community.m5stack.com/post/8808</guid><dc:creator><![CDATA[k3m]]></dc:creator><pubDate>Sat, 23 May 2020 21:51:30 GMT</pubDate></item><item><title><![CDATA[Reply to Swollen M5Stack Battery. on Tue, 05 May 2020 11:27:12 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/hague" aria-label="Profile: hague">@<bdi>hague</bdi></a> contact M5Stack support and see if the can help you. I recall in the past they had issues with one of their battery vendors.</p>
]]></description><link>https://community.m5stack.com/post/8516</link><guid isPermaLink="true">https://community.m5stack.com/post/8516</guid><dc:creator><![CDATA[world101]]></dc:creator><pubDate>Tue, 05 May 2020 11:27:12 GMT</pubDate></item><item><title><![CDATA[Reply to Swollen M5Stack Battery. on Mon, 04 May 2020 08:31:27 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/hague" aria-label="Profile: hague">@<bdi>hague</bdi></a> There was a warning about using the module like this but this is the first time I have seen a battery go bad.<br />
You need to immediately put that in a strong metal tin incase it ruptures.</p>
]]></description><link>https://community.m5stack.com/post/8506</link><guid isPermaLink="true">https://community.m5stack.com/post/8506</guid><dc:creator><![CDATA[ajb2k3]]></dc:creator><pubDate>Mon, 04 May 2020 08:31:27 GMT</pubDate></item></channel></rss>
