<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[UI flow - connexion problem usb port]]></title><description><![CDATA[<p dir="auto">Hello<br />
I just start with M5stick-C and i have some problem<br />
I have installed m5burner and it works fine</p>
<p dir="auto">I tried Ui flow and impossible to connect to the m5stack-c..</p>
<p dir="auto">When I connected to the pc on windows 10, it s seen as  usb serial port (com3)..<br />
I use this port in ui flow and impossible to connect...</p>
<p dir="auto">Any idea ?</p>
<p dir="auto">Thanks for you helo</p>
]]></description><link>https://community.m5stack.com/topic/1940/ui-flow-connexion-problem-usb-port</link><generator>RSS for Node</generator><lastBuildDate>Sat, 02 May 2026 17:50:14 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/1940.rss" rel="self" type="application/rss+xml"/><pubDate>Sat, 09 May 2020 07:53:30 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to UI flow - connexion problem usb port on Sat, 09 May 2020 18:33:46 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/bww1340" aria-label="Profile: bww1340">@<bdi>bww1340</bdi></a> Repost this one in the official updates forum under the 1.5.1 (or which ever version you are struggling with.)</p>
]]></description><link>https://community.m5stack.com/post/8598</link><guid isPermaLink="true">https://community.m5stack.com/post/8598</guid><dc:creator><![CDATA[ajb2k3]]></dc:creator><pubDate>Sat, 09 May 2020 18:33:46 GMT</pubDate></item><item><title><![CDATA[Reply to UI flow - connexion problem usb port on Sat, 09 May 2020 16:53:15 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/ajb2k3" aria-label="Profile: ajb2k3">@<bdi>ajb2k3</bdi></a> ![<img src="/assets/uploads/files/1589043184055-m45.jpg" alt="0_1589043180620_m45.JPG" class=" img-fluid img-markdown" /><br />
i get this error message</p>
]]></description><link>https://community.m5stack.com/post/8596</link><guid isPermaLink="true">https://community.m5stack.com/post/8596</guid><dc:creator><![CDATA[bww1340]]></dc:creator><pubDate>Sat, 09 May 2020 16:53:15 GMT</pubDate></item><item><title><![CDATA[Reply to UI flow - connexion problem usb port on Sat, 09 May 2020 15:52:59 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/bww1340" aria-label="Profile: bww1340">@<bdi>bww1340</bdi></a> The download button in the setting menu is not working?</p>
]]></description><link>https://community.m5stack.com/post/8595</link><guid isPermaLink="true">https://community.m5stack.com/post/8595</guid><dc:creator><![CDATA[ajb2k3]]></dc:creator><pubDate>Sat, 09 May 2020 15:52:59 GMT</pubDate></item><item><title><![CDATA[Reply to UI flow - connexion problem usb port on Sat, 09 May 2020 15:08:32 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/ajb2k3" aria-label="Profile: ajb2k3">@<bdi>ajb2k3</bdi></a> Thanks for you message. Indeed, I didn't configure correctly. now is it connected !</p>
<p dir="auto">I can run a program but it is not possible to download the code in the stick</p>
]]></description><link>https://community.m5stack.com/post/8594</link><guid isPermaLink="true">https://community.m5stack.com/post/8594</guid><dc:creator><![CDATA[bww1340]]></dc:creator><pubDate>Sat, 09 May 2020 15:08:32 GMT</pubDate></item><item><title><![CDATA[Reply to UI flow - connexion problem usb port on Sat, 09 May 2020 12:34:26 GMT]]></title><description><![CDATA[<p dir="auto">Is the stick set to USB mode?<br />
If its in wifi mode, the com port will still be present, you just won't be able to program it locally.</p>
<p dir="auto">as soon as you switch the stick on, you need to press one of the buttons to go into the setting and change it from wifi to USB mode.</p>
]]></description><link>https://community.m5stack.com/post/8590</link><guid isPermaLink="true">https://community.m5stack.com/post/8590</guid><dc:creator><![CDATA[ajb2k3]]></dc:creator><pubDate>Sat, 09 May 2020 12:34:26 GMT</pubDate></item></channel></rss>
