<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Collision Detection between Objects w&#x2F; Joystick Hat Control (Micropython)]]></title><description><![CDATA[<p dir="auto">I made a proof of concept for the M5Stick with Joystick hat. Using the joystick hat you can move a circle around the screen. Said circle has simple collision detection. Currently there is only one obstacle though. Adding more would be my next step.</p>
<p dir="auto">Also I included the ability to pause using button B. While paused you can even adjust the display brightness with the joystick.</p>
<pre><code>from m5stack import axp, btnA, btnB
from m5ui import M5Rect, M5Circle, setScreenColor
from uiflow import wait_ms
import time
import hat
# configure size of deadzone on joystick input
joyTolerance = 0.5
# configure display
intDisplayBrightness = 35
setScreenColor(0x111111)
axp.setLcdBrightness(intDisplayBrightness)
# configure cursor position and size
lstCursorCrd = [20, 5] # initial position
cursorRad = 4
circle0 = M5Circle(lstCursorCrd[0], lstCursorCrd[1], cursorRad, 0xFFFFFF, 0xFFFFFF)
# rectangular obstruction and hit box around it
obs = (29, 109, 20, 20)
rectangle0 = M5Rect(obs[0], obs[1], obs[2], obs[3], 0xFF5500, 0xFF5500)
rectLeadX = obs[0]
rectLeadY = obs[1]
rectEndX = obs[0] + obs[2]
rectEndY = obs[1] + obs[3]
# define joystick hat
joy0 = hat.get(hat.JOYSTICK)
#get center positions on joystick for calibration
joyX = joy0.InvertX
joyY = joy0.InvertY
# store booleans of invalid motion
boolXPlus = True
boolXMinus = True
boolYPlus = True
boolYMinus = True
# store timeouts to reduce collision flicker
yTimeoutDur = None
xTimeoutDur = None
yTimedout = False
xTimedout = False
#store current state for play/pause
play = True
while True:
    while play is True:
        # move cursor hitbox
        circLeadY = round(lstCursorCrd[0]) - cursorRad - 2
        circLeadX = round(lstCursorCrd[1]) - cursorRad - 2
        circEndY = round(lstCursorCrd[0]) + cursorRad + 2
        circEndX = round(lstCursorCrd[1]) + cursorRad + 2
        if not ((circEndY &gt; rectLeadY) and (circLeadY &lt; rectEndY) and (circLeadX &lt; rectEndX) and (circEndX &gt; rectLeadX)):
            # left
            if lstCursorCrd[0] &lt; 153 and (joy0.InvertY - joyY) &gt; (0 + joyTolerance) and yTimedout is False:
                lstCursorCrd[0] += abs((joy0.InvertY - joyY)/75)
            # right
            if lstCursorCrd[0] &gt; 5 and (joy0.InvertY - joyY) &lt; (0 - joyTolerance) and yTimedout is False:
                lstCursorCrd[0] -= abs((joy0.InvertY - joyY)/75)
            # down
            if lstCursorCrd[1] &gt; 4 and (joy0.InvertX - joyX) &gt; (0 + joyTolerance) and xTimedout is False:
                lstCursorCrd[1] -= abs((joy0.InvertX - joyX)/75)
            # up
            if lstCursorCrd[1] &lt; 75 and (joy0.InvertX - joyX) &lt; (0 - joyTolerance) and xTimedout is False:
                lstCursorCrd[1] += abs((joy0.InvertX - joyX)/75)
        #collision detection code
        elif circEndY &gt;= rectLeadY and circLeadY &lt; rectLeadY:
            # time out the cursor to prevent blink
            yTimeoutDur = time.ticks_ms()
            yTimedout = True
            # move cusor back
            lstCursorCrd[0] -= 1
        elif circLeadY &lt;= rectEndY and circEndY &gt; rectEndY:
            yTimedout = True
            # move cursor back
            lstCursorCrd[0] += 1
        elif circEndX &gt;= rectLeadX and circLeadX &lt; rectLeadX:
            xTimeoutDur = time.ticks_ms()
            xTimedout = True
            # move cursor back
            lstCursorCrd[1] -= 1
        elif circLeadX &lt;= rectEndX and circEndX &gt; rectEndX:
            xTimedout = True
            # move cursor back
            lstCursorCrd[1] += 1
        #render cursor in current position
        circle0.setPosition(y=round(lstCursorCrd[0]), x=round(lstCursorCrd[1]))
        # unpause cursor movement after set duration from collision
        if time.ticks_diff(time.ticks_ms(), yTimeoutDur) &gt; 200:
            yTimedout = False
        if time.ticks_diff(time.ticks_ms(), xTimeoutDur) &gt; 200:
            xTimedout = False
        # pause game with button
        if btnB.wasPressed():
            play = False
        rectangle0.show()
    # adjust display brightness while paused
    if (joy0.InvertX - joyX) &lt; (0 - joyTolerance) and intDisplayBrightness &lt; 100:
        intDisplayBrightness += 5
        wait_ms(100)
    if (joy0.InvertX - joyX) &gt; (0 + joyTolerance) and intDisplayBrightness &gt; 20:
        intDisplayBrightness -= 5
        wait_ms(100)
    # resume game
        play = True
]]></description><link>https://community.m5stack.com/topic/1949/collision-detection-between-objects-w-joystick-hat-control-micropython</link><generator>RSS for Node</generator><lastBuildDate>Wed, 29 Apr 2026 09:37:36 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/1949.rss" rel="self" type="application/rss+xml"/><pubDate>Mon, 11 May 2020 09:36:42 GMT</pubDate><ttl>60</ttl></channel></rss>
