<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Uniquely identifying a M5stack with a physical connection]]></title><description><![CDATA[<p dir="auto">I am working on a project where i would like to plug in an m5 stack to a physical connection (RJ45 or Serial), have some kind of config file that uniquely identifies that particular m5stack, and be able to report it back where it's been connected to.</p>
<p dir="auto">Imagine there are 20 M5Stacks in positions 1-20, i would basically like to be able to know exactly which M5stack is in which position. Is this possible?</p>
]]></description><link>https://community.m5stack.com/topic/1952/uniquely-identifying-a-m5stack-with-a-physical-connection</link><generator>RSS for Node</generator><lastBuildDate>Sun, 03 May 2026 06:25:36 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/1952.rss" rel="self" type="application/rss+xml"/><pubDate>Wed, 13 May 2020 05:45:40 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Uniquely identifying a M5stack with a physical connection on Wed, 13 May 2020 17:13:55 GMT]]></title><description><![CDATA[<p dir="auto">Thanks, but i should have mentioned the idea is that if i move one of the m5stacks around, connecting it into a different position 1-20 it would be able to report back its position.</p>
<p dir="auto">Modbus concept actually is realy close, but seems that when one of the devices is detached the others become undetectable.</p>
<p dir="auto">Anything else similar to this?</p>
<p dir="auto">At one point i considered using  a 2 layer switch with associationg each position with a port on the switch, but was wondering if there's a more cost effective method using serial.</p>
]]></description><link>https://community.m5stack.com/post/8668</link><guid isPermaLink="true">https://community.m5stack.com/post/8668</guid><dc:creator><![CDATA[sofortune]]></dc:creator><pubDate>Wed, 13 May 2020 17:13:55 GMT</pubDate></item><item><title><![CDATA[Reply to Uniquely identifying a M5stack with a physical connection on Wed, 13 May 2020 07:21:44 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sofortune" aria-label="Profile: sofortune">@<bdi>sofortune</bdi></a> multi serial device commuication , you could use “Modbus” function.</p>
<p dir="auto">in this page bottom, have UIFlow modbus use tutorial.<br />
<a href="https://docs.m5stack.com/#/en/uiflow/advanced?id=modbus-master" target="_blank" rel="noopener noreferrer nofollow ugc">https://docs.m5stack.com/#/en/uiflow/advanced?id=modbus-master</a></p>
]]></description><link>https://community.m5stack.com/post/8645</link><guid isPermaLink="true">https://community.m5stack.com/post/8645</guid><dc:creator><![CDATA[m5stack]]></dc:creator><pubDate>Wed, 13 May 2020 07:21:44 GMT</pubDate></item></channel></rss>
