<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[How to make M5StickC go into light sleep?]]></title><description><![CDATA[<p dir="auto">Battery runs out fast with current drain at about 50mAh if Get VBus Current is accurate. Looking to make it last longer with regular sleep intervals. How can this be done either in Python or UiFlow?</p>
]]></description><link>https://community.m5stack.com/topic/1953/how-to-make-m5stickc-go-into-light-sleep</link><generator>RSS for Node</generator><lastBuildDate>Tue, 28 Apr 2026 23:10:02 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/1953.rss" rel="self" type="application/rss+xml"/><pubDate>Wed, 13 May 2020 07:21:14 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to How to make M5StickC go into light sleep? on Wed, 13 May 2020 10:27:42 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/m5stack" aria-label="Profile: m5stack">@<bdi>m5stack</bdi></a> Did a quick machine.deepsleep(10000) test and it seems to work! Will add more code to see how this extends battery life.</p>
<p dir="auto">Thanks!</p>
]]></description><link>https://community.m5stack.com/post/8654</link><guid isPermaLink="true">https://community.m5stack.com/post/8654</guid><dc:creator><![CDATA[jhfoo]]></dc:creator><pubDate>Wed, 13 May 2020 10:27:42 GMT</pubDate></item><item><title><![CDATA[Reply to How to make M5StickC go into light sleep? on Wed, 13 May 2020 09:43:07 GMT]]></title><description><![CDATA[<p dir="auto">This API in the official mainline is provided.   but currently UIFlow has not integrated this API. so if you want the use this function , you  could  use official mpy firmware.  you could refer this docs</p>
<p dir="auto"><a href="http://docs.micropython.org/en/latest/esp32/quickref.html#deep-sleep-mode" target="_blank" rel="noopener noreferrer nofollow ugc">http://docs.micropython.org/en/latest/esp32/quickref.html#deep-sleep-mode</a></p>
]]></description><link>https://community.m5stack.com/post/8653</link><guid isPermaLink="true">https://community.m5stack.com/post/8653</guid><dc:creator><![CDATA[m5stack]]></dc:creator><pubDate>Wed, 13 May 2020 09:43:07 GMT</pubDate></item><item><title><![CDATA[Reply to How to make M5StickC go into light sleep? on Wed, 13 May 2020 09:24:39 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/m5stack" aria-label="Profile: m5stack">@<bdi>m5stack</bdi></a> can you confirm there is no python module/ library today that support this?</p>
]]></description><link>https://community.m5stack.com/post/8651</link><guid isPermaLink="true">https://community.m5stack.com/post/8651</guid><dc:creator><![CDATA[jhfoo]]></dc:creator><pubDate>Wed, 13 May 2020 09:24:39 GMT</pubDate></item><item><title><![CDATA[Reply to How to make M5StickC go into light sleep? on Wed, 13 May 2020 08:41:50 GMT]]></title><description><![CDATA[<p dir="auto">UIFlow does not currently provide this feature.</p>
]]></description><link>https://community.m5stack.com/post/8650</link><guid isPermaLink="true">https://community.m5stack.com/post/8650</guid><dc:creator><![CDATA[m5stack]]></dc:creator><pubDate>Wed, 13 May 2020 08:41:50 GMT</pubDate></item></channel></rss>
