<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[UIFlow Desktop can&#x27;t connect to M5Stick]]></title><description><![CDATA[<p dir="auto">When i  try to connect UIFlow Desktop (on Debian Linux) via USB to my M5Stick always this message appears:</p>
<p dir="auto"><code> Upload code failed, maybe your device is offline check it and retry</code></p>
<p dir="auto">and the statusbar shows<br />
<code>/dev/ttyUSB0[ Disconnected ] </code></p>
<p dir="auto">But the FirmwareBurner works well. Also i can use a serial connection (like  <code>screen /dev/ttyUSB0 115200 </code>) to communicate successfull with my M5Stick (Micropython-REPL). So drivers are not the problem. I also tried this as root - same behavior..<br />
Only the UIFlow connections to the USB isnt working.</p>
<p dir="auto">Of course I could use UIFlow online. In our school environment no internet connection is possible.</p>
<p dir="auto">Thanks for your support</p>
]]></description><link>https://community.m5stack.com/topic/1955/uiflow-desktop-can-t-connect-to-m5stick</link><generator>RSS for Node</generator><lastBuildDate>Sat, 02 May 2026 17:50:12 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/1955.rss" rel="self" type="application/rss+xml"/><pubDate>Wed, 13 May 2020 12:06:12 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to UIFlow Desktop can&#x27;t connect to M5Stick on Thu, 14 May 2020 05:34:58 GMT]]></title><description><![CDATA[<p dir="auto">Check out this video I did a while back on using M5Stack devices on linux <a href="https://www.youtube.com/watch?v=ZZdTl0400uM" target="_blank" rel="noopener noreferrer nofollow ugc">https://www.youtube.com/watch?v=ZZdTl0400uM</a> you need to make sure to add the device to the dialout group, I can't remember the exact line of code but it's in the video if you watch it</p>
]]></description><link>https://community.m5stack.com/post/8677</link><guid isPermaLink="true">https://community.m5stack.com/post/8677</guid><dc:creator><![CDATA[lukasmaximus]]></dc:creator><pubDate>Thu, 14 May 2020 05:34:58 GMT</pubDate></item><item><title><![CDATA[Reply to UIFlow Desktop can&#x27;t connect to M5Stick on Wed, 13 May 2020 12:14:41 GMT]]></title><description><![CDATA[<p dir="auto">M5Stick?  M5StickC? which product are you used ? UIFlow Desktop IDE  don't support M5Stick.   if you are using M5StickC, you should setup it the USB mode then , it can connect to the IDE.</p>
<p dir="auto">tutorial :</p>
<p dir="auto"><a href="https://docs.m5stack.com/#/en/quick_start/m5stickc/m5stickc_quick_start_with_uiflow" target="_blank" rel="noopener noreferrer nofollow ugc">https://docs.m5stack.com/#/en/quick_start/m5stickc/m5stickc_quick_start_with_uiflow</a></p>
]]></description><link>https://community.m5stack.com/post/8663</link><guid isPermaLink="true">https://community.m5stack.com/post/8663</guid><dc:creator><![CDATA[m5stack]]></dc:creator><pubDate>Wed, 13 May 2020 12:14:41 GMT</pubDate></item></channel></rss>
