<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[M5stick power issues when disconnected]]></title><description><![CDATA[<p dir="auto">My M5stickC was working perfectly, but now (in Bluetooth communication) when I disconnect it from from the PC it turns off. How can I see if there are problems with the battery and how can I solve it? Thank you</p>
]]></description><link>https://community.m5stack.com/topic/1959/m5stick-power-issues-when-disconnected</link><generator>RSS for Node</generator><lastBuildDate>Thu, 30 Apr 2026 15:16:58 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/1959.rss" rel="self" type="application/rss+xml"/><pubDate>Fri, 15 May 2020 14:32:49 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to M5stick power issues when disconnected on Mon, 01 Jun 2020 04:28:55 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/giulio" aria-label="Profile: giulio">@<bdi>giulio</bdi></a> can you describe the problem? Does the stick fail immediately when you disconnect? If not, can you check battery voltage and flow?</p>
]]></description><link>https://community.m5stack.com/post/8885</link><guid isPermaLink="true">https://community.m5stack.com/post/8885</guid><dc:creator><![CDATA[Devilstower]]></dc:creator><pubDate>Mon, 01 Jun 2020 04:28:55 GMT</pubDate></item></channel></rss>
