<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Use of double core in M5stack]]></title><description><![CDATA[<p dir="auto">I tested n program for ESP32 designed for Arduino ( Esp32/Esp32_dobleNucleo/Esp32_dobleNucleo.ino), and modified it to test in my  M5stack. But even though it is checked and loaded correctly. At the start of the job the M5stack is reset every 10", cyclicly. Someone can help me. The code is :</p>
<p dir="auto">#include"M5Stack.h"<br />
bool bandera = true;</p>
<p dir="auto">TaskHandle_t Tarea1;</p>
<p dir="auto">void loop_tarea1(void * pvParameters)<br />
{<br />
m5.lcd.setCursor(0,70);<br />
m5.Lcd.print("tarea1()");<br />
m5.Lcd.print(xPortGetCoreID());<br />
while (1)<br />
{   M5.Lcd.drawRect(150, 120, 122, 110, YELLOW);<br />
delay(1000);<br />
M5.Lcd.drawRect(150, 120, 122, 110, BLUE);<br />
delay(1000); }<br />
}<br />
void setup(){<br />
M5.begin();  // inicio del M5s LCD<br />
m5.Lcd.setTextSize(2);<br />
m5.lcd.setCursor(0,10);<br />
m5.lcd.print("SETUP =");<br />
xTaskCreatePinnedToCore(loop_tarea1, "Tarea1", 10000,  NULL,  0, &amp;Tarea1,0);<br />
}<br />
void loop()<br />
{  if(bandera)  {<br />
m5.lcd.setCursor(0,30);<br />
m5.Lcd.print("Loop()=");<br />
bandera = false; }</p>
<p dir="auto">M5.Lcd.drawRect(20,120, 122, 110, BLUE);<br />
delay(400);<br />
M5.Lcd.drawRect(20, 120, 122, 110, YELLOW);<br />
delay(400);<br />
]]></description><link>https://community.m5stack.com/topic/1960/use-of-double-core-in-m5stack</link><generator>RSS for Node</generator><lastBuildDate>Fri, 01 May 2026 07:13:41 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/1960.rss" rel="self" type="application/rss+xml"/><pubDate>Fri, 15 May 2020 17:38:36 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Use of double core in M5stack on Mon, 18 May 2020 16:29:44 GMT]]></title><description><![CDATA[<p dir="auto">Some set of parameters, and already work the two loops without interference.</p>
<p dir="auto">#include"M5Stack.h"</p>
<p dir="auto">int mensaje=0;<br />
int mensaje1;<br />
QueueHandle_t queue_1;<br />
void loop_tarea1(void * pvParameters);</p>
<p dir="auto">void setup(){<br />
M5.begin();  // inicio del M5s<br />
queue_1 = xQueueCreate(1, sizeof(int));<br />
if( queue_1 == 0 )<br />
{<br />
m5.Lcd.print("no creada la lista");}<br />
xTaskCreatePinnedToCore(loop_tarea1, "Tarea1",1500,  NULL, 1, NULL,0);<br />
{<br />
for( ;; ) {<br />
if (xQueueReceive(queue_1, &amp;mensaje1, ( TickType_t ) 10) ) {<br />
m5.Lcd.setTextSize(5);<br />
m5.Lcd.setCursor(150,0);<br />
m5.Lcd.print(mensaje1);}<br />
}<br />
{  mensaje=0;<br />
if (Serial.available()){<br />
mensaje=Serial.read();<br />
xQueueSendToFront(queue_1,  &amp;mensaje, ( TickType_t ) 10); }<br />
delay(10);<br />
]]></description><link>https://community.m5stack.com/post/8718</link><guid isPermaLink="true">https://community.m5stack.com/post/8718</guid><dc:creator><![CDATA[Matorra]]></dc:creator><pubDate>Mon, 18 May 2020 16:29:44 GMT</pubDate></item><item><title><![CDATA[Reply to Use of double core in M5stack on Sun, 17 May 2020 16:12:27 GMT]]></title><description><![CDATA[<p dir="auto">I keep studying how to share data between the two loops, I have located the FreeRtos manuals and they are very complex for my level. I have written this code, but with the same result ,when sending data the M5stack will reboot . I'd appreciate some help.</p>
<p dir="auto">int mensaje;<br />
int mensaje1;<br />
queue_1 = xQueueCreate(4, sizeof(int));<br />
{<br />
xTaskCreatePinnedToCore(loop_tarea1, "Tarea1", 500,  NULL, 2, NULL,0);<br />
{<br />
for( ;; ) {<br />
if (xQueueReceive(queue_1, &amp;mensaje1, portMAX_DELAY) == pdPASS) {<br />
}<br />
{  mensaje=0;<br />
Serial.print(mensaje);<br />
delay(100);<br />
xQueueSend(queue_1, &amp;mensaje, portMAX_DELAY); }<br />
]]></description><link>https://community.m5stack.com/post/8712</link><guid isPermaLink="true">https://community.m5stack.com/post/8712</guid><dc:creator><![CDATA[Matorra]]></dc:creator><pubDate>Sun, 17 May 2020 16:12:27 GMT</pubDate></item><item><title><![CDATA[Reply to Use of double core in M5stack on Fri, 15 May 2020 19:10:52 GMT]]></title><description><![CDATA[<p dir="auto">I understood the problem, there is a conflict when using the same resource the LCD. I introduced a delay in the second loop and matched the flashing times and it works correctly. But now my question is, how to use resources or variables with the two LOOPs simultaneously?.<br />
…….<br />
{ delay(250);<br />
m5.lcd.setCursor(0,70)<br />
m5.Lcd.print("tarea1()")<br />
……..;</p>
]]></description><link>https://community.m5stack.com/post/8704</link><guid isPermaLink="true">https://community.m5stack.com/post/8704</guid><dc:creator><![CDATA[Matorra]]></dc:creator><pubDate>Fri, 15 May 2020 19:10:52 GMT</pubDate></item></channel></rss>
