<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[M5 Stack CGM Monitoring for Nightscout data from Dexcom]]></title><description><![CDATA[<p dir="auto">Re: <a href="/topic/870/call-for-articles-with-your-product-on-m5stack">Call for articles with your product on M5Stack!!</a></p>
<p dir="auto">Hi I'm Chris, I'm not a programmer but I work in Tech. I'm the father of a 16 year old Type 1 Diabetic. So I wanted a simple way to display his Blood Sugar with a dedicated device. The M5Stack fit this purpose perfectly.</p>
<p dir="auto">So thanks to the help from my friends in a bunch of different tech companies, VMWare, Google, Microsoft, Oracle to name a few…</p>
<p dir="auto">I created the M5 Scout. Here are my design goals:</p>
<li>Reuse as much of someone else's good tech so that I don’t have to rebuild it, <a href="https://github.com/nightscout/cgm-remote-monitor" target="_blank" rel="noopener noreferrer nofollow ugc">https://github.com/nightscout/cgm-remote-monitor</a></li>
<li>Leverage the most basic programing so I don’t have to learn to code <a href="https://flow.m5stack.com/" target="_blank" rel="noopener noreferrer nofollow ugc">https://flow.m5stack.com/</a></li>
<li>Have the ability to user a cheap product that can display Blood Glucose data all the time (M5Stack)</li>
<p dir="auto">PS. Also I might build a version 2.0 with blinking Lights, alarms, different Wifis,  electric shocks for when his numbers are out of whack… (I just got my M5fire kit this morning)</p>
<p dir="auto">For now, the buttons beep and you can make the screen brighter or dimmer (for nighttime use)<br />
On screen you can continuously see:</p>
<li>
<p dir="auto">BG level (Green when in range red when out of range)</p>
</li>
<li>
<p dir="auto">Difference with the last BG level</p>
</li>
<li>
<p dir="auto">Time since last update was received (for example if the Dexcom CGM is far from Phone)</p>
</li>
<li>
<p dir="auto">The Trend Arrow</p>
</li>
<li>
<p dir="auto">Screen brightness (but we could remove that…)</p>
</li>
<p dir="auto">All you need is an M5 Stack device</p>
<p dir="auto">So here is the link to the code on Git Hub:<br />
<a href="https://github.com/ctillier-vmware/BLocklyCGMforM5Stack" target="_blank" rel="noopener noreferrer nofollow ugc">https://github.com/ctillier-vmware/BLocklyCGMforM5Stack</a></p>
<p dir="auto">Here is the link to the Youtube video I made to explain the process:<br />
<a href="https://youtu.be/SqZU-1NvGRs" target="_blank" rel="noopener noreferrer nofollow ugc">https://youtu.be/SqZU-1NvGRs</a>!</p>
]]></description><link>https://community.m5stack.com/topic/1962/m5-stack-cgm-monitoring-for-nightscout-data-from-dexcom</link><generator>RSS for Node</generator><lastBuildDate>Wed, 29 Apr 2026 03:37:48 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/1962.rss" rel="self" type="application/rss+xml"/><pubDate>Sat, 16 May 2020 22:15:30 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to M5 Stack CGM Monitoring for Nightscout data from Dexcom on Sun, 19 Jul 2020 05:52:20 GMT]]></title><description><![CDATA[<p dir="auto">Hi ,</p>
<p dir="auto">I used your application before I discovered the M5stack. It was on a fb page for diabetes and nightscout and a fb member was so kind to burn It and  adjust the parameters for me.</p>
<p dir="auto">It is an excellent application, thank you !</p>
<p dir="auto">And now I am discovering  myself the m5stack...what an incredible device and There are realy endless possibilities...</p>
<p dir="auto">Maybe Considering things or features to add In future :</p>
<li>dark screen and not displaying the value until a button is pressed... need full darkness to sleep</li>
<li>a feed with mqtt to connect to alexa and be able to ask the bg level to alexa When m5stack is on (i used it with <a href="http://Smartnest.cz" target="_blank" rel="noopener noreferrer nofollow ugc">Smartnest.cz</a> to connect my ENV hat and am able to ask alexa the temperature of poolwater )</li>
<p dir="auto">Good work anyway and thank you a lot !!!</p>
]]></description><link>https://community.m5stack.com/post/9376</link><guid isPermaLink="true">https://community.m5stack.com/post/9376</guid><dc:creator><![CDATA[Chx]]></dc:creator><pubDate>Sun, 19 Jul 2020 05:52:20 GMT</pubDate></item><item><title><![CDATA[Reply to M5 Stack CGM Monitoring for Nightscout data from Dexcom on Fri, 03 Jul 2020 16:36:51 GMT]]></title><description><![CDATA[<p dir="auto">You may want to check out this project already doing this, its great and I use it.</p>
<p dir="auto"><a href="https://github.com/mlukasek/M5_NightscoutMon#the-syntax-of-m5nsini-configuration-file" target="_blank" rel="noopener noreferrer nofollow ugc">https://github.com/mlukasek/M5_NightscoutMon#the-syntax-of-m5nsini-configuration-file</a></p>
]]></description><link>https://community.m5stack.com/post/9234</link><guid isPermaLink="true">https://community.m5stack.com/post/9234</guid><dc:creator><![CDATA[Chorotega]]></dc:creator><pubDate>Fri, 03 Jul 2020 16:36:51 GMT</pubDate></item><item><title><![CDATA[Reply to M5 Stack CGM Monitoring for Nightscout data from Dexcom on Thu, 21 May 2020 03:11:33 GMT]]></title><description><![CDATA[<p dir="auto">Awesome and very practical project, look forward to hearing more about this</p>
]]></description><link>https://community.m5stack.com/post/8753</link><guid isPermaLink="true">https://community.m5stack.com/post/8753</guid><dc:creator><![CDATA[lukasmaximus]]></dc:creator><pubDate>Thu, 21 May 2020 03:11:33 GMT</pubDate></item><item><title><![CDATA[Reply to M5 Stack CGM Monitoring for Nightscout data from Dexcom on Sun, 17 May 2020 20:50:39 GMT]]></title><description><![CDATA[<p dir="auto">I just came across your post as I was trying to learn more about the M5Stack platform for <a href="https://github.com/ecc1/gnarl" target="_blank" rel="noopener noreferrer nofollow ugc">my own diabetes-related project.</a></p>
<p dir="auto">The radio used in LoRa module can be used to communicate directly with Medtronic pumps, so I'm working on using it for a full rig (closed-loop artificial pancreas), as well as a RileyLink alternative. It depends on exactly which radio pins are connected, so I don't know whether the M5Stack will work yet, but I'm hopeful.</p>
]]></description><link>https://community.m5stack.com/post/8713</link><guid isPermaLink="true">https://community.m5stack.com/post/8713</guid><dc:creator><![CDATA[ecc]]></dc:creator><pubDate>Sun, 17 May 2020 20:50:39 GMT</pubDate></item></channel></rss>
