<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[How do I use L298N motor driver with M5StickC]]></title><description><![CDATA[<p dir="auto">Hi</p>
<p dir="auto">I think to control two DC motors using L298N motor driver I need at least 3 GPIO pins per motor.</p>
<p dir="auto">So is it possible to use L298N driver with M5StickC?</p>
]]></description><link>https://community.m5stack.com/topic/1981/how-do-i-use-l298n-motor-driver-with-m5stickc</link><generator>RSS for Node</generator><lastBuildDate>Wed, 29 Apr 2026 13:17:36 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/1981.rss" rel="self" type="application/rss+xml"/><pubDate>Fri, 22 May 2020 23:46:41 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to How do I use L298N motor driver with M5StickC on Mon, 25 May 2020 02:28:03 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/anuj01" aria-label="Profile: anuj01">@<bdi>anuj01</bdi></a> Another alternative is to use the  M5 official IO expander unit.<br />
<a href="https://m5stack.com/collections/m5-unit/products/official-extend-serial-i-o-unit" target="_blank" rel="noopener noreferrer nofollow ugc">https://m5stack.com/collections/m5-unit/products/official-extend-serial-i-o-unit</a><br />
M5StickC has an I2C grove port, and you can connect this unit to it. I have tested and it works. Good luck.</p>
]]></description><link>https://community.m5stack.com/post/8820</link><guid isPermaLink="true">https://community.m5stack.com/post/8820</guid><dc:creator><![CDATA[liemph]]></dc:creator><pubDate>Mon, 25 May 2020 02:28:03 GMT</pubDate></item><item><title><![CDATA[Reply to How do I use L298N motor driver with M5StickC on Sat, 23 May 2020 04:48:09 GMT]]></title><description><![CDATA[<p dir="auto">Yes and no. You would need more output pins, so you would need an I2C I/O pin expander. Like this: <a href="https://datasheets.maximintegrated.com/en/ds/MAX7328-MAX7329.pdf" target="_blank" rel="noopener noreferrer nofollow ugc">https://datasheets.maximintegrated.com/en/ds/MAX7328-MAX7329.pdf</a></p>
]]></description><link>https://community.m5stack.com/post/8797</link><guid isPermaLink="true">https://community.m5stack.com/post/8797</guid><dc:creator><![CDATA[RussNelson]]></dc:creator><pubDate>Sat, 23 May 2020 04:48:09 GMT</pubDate></item></channel></rss>
