<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[IIOT-Dual Switch datasheet]]></title><description><![CDATA[<p dir="auto">Hey guys! Currently Im working on smart home/office project. I need to control the light with two way switch method. I need to know where is NO, NC, and COM on PCB. Is there any documentation / datasheet that I can get from internet? If yes please share.</p>
<p dir="auto">P/s: If you guys have any idea or any other method regarding to this please advice and share.<img src="/assets/uploads/files/1590659532281-e2923087-07f9-4ed9-9e82-14f001a995b5-resized.jpeg" alt="0_1590659528815_E2923087-07F9-4ED9-9E82-14F001A995B5.jpeg" class=" img-fluid img-markdown" /></p>
]]></description><link>https://community.m5stack.com/topic/1994/iiot-dual-switch-datasheet</link><generator>RSS for Node</generator><lastBuildDate>Sun, 03 May 2026 00:16:41 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/1994.rss" rel="self" type="application/rss+xml"/><pubDate>Thu, 28 May 2020 09:52:19 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to IIOT-Dual Switch datasheet on Mon, 28 Dec 2020 09:48:10 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/m5stack" aria-label="Profile: m5stack">@<bdi>m5stack</bdi></a> I will use this module too, and need more informations. Can you provide schematic for this circuit? what relay do you use?</p>
]]></description><link>https://community.m5stack.com/post/11400</link><guid isPermaLink="true">https://community.m5stack.com/post/11400</guid><dc:creator><![CDATA[Leo05]]></dc:creator><pubDate>Mon, 28 Dec 2020 09:48:10 GMT</pubDate></item><item><title><![CDATA[Reply to IIOT-Dual Switch datasheet on Fri, 29 May 2020 09:54:27 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/ahmadhafiz321" aria-label="Profile: ahmadhafiz321">@<bdi>ahmadhafiz321</bdi></a> actually. this relay module, we did not lead out the NC pin. Therefore, you cannot solder the NC circuit through the PCB.</p>
]]></description><link>https://community.m5stack.com/post/8861</link><guid isPermaLink="true">https://community.m5stack.com/post/8861</guid><dc:creator><![CDATA[m5stack]]></dc:creator><pubDate>Fri, 29 May 2020 09:54:27 GMT</pubDate></item><item><title><![CDATA[Reply to IIOT-Dual Switch datasheet on Fri, 29 May 2020 01:31:24 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/m5stack" aria-label="Profile: m5stack">@<bdi>m5stack</bdi></a> yes i know how it works, but i need to know where is NC and COM at PCB. So that, i can connect with physical switch and make it two-way switch. That’s why i need a datasheet for relay PCB.</p>
]]></description><link>https://community.m5stack.com/post/8856</link><guid isPermaLink="true">https://community.m5stack.com/post/8856</guid><dc:creator><![CDATA[ahmadhafiz321]]></dc:creator><pubDate>Fri, 29 May 2020 01:31:24 GMT</pubDate></item><item><title><![CDATA[Reply to IIOT-Dual Switch datasheet on Thu, 28 May 2020 11:14:37 GMT]]></title><description><![CDATA[<p dir="auto">A1 --&gt; A2 .   B1--&gt;B2  all is NO. when you control the G15 and G12 change to digtal high level. they will be close.</p>
]]></description><link>https://community.m5stack.com/post/8850</link><guid isPermaLink="true">https://community.m5stack.com/post/8850</guid><dc:creator><![CDATA[m5stack]]></dc:creator><pubDate>Thu, 28 May 2020 11:14:37 GMT</pubDate></item></channel></rss>
