<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[M5StickC - can&#x27;t find serial port on Mac Mojave]]></title><description><![CDATA[<p dir="auto">Hi, I've installed the silabs driver and uninstalled and reinstalled and restarted my computer so many times in between. When I run the system report on mac, it shows up as a USB device, but when I list the devices in command line, or when I try to select the port in arduino, it doesn't show up. Is there a way to fix this issue and to get the port to consistently show up without restarting every time?</p>
<p dir="auto">Thank you!</p>
]]></description><link>https://community.m5stack.com/topic/1995/m5stickc-can-t-find-serial-port-on-mac-mojave</link><generator>RSS for Node</generator><lastBuildDate>Sun, 03 May 2026 14:57:45 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/1995.rss" rel="self" type="application/rss+xml"/><pubDate>Thu, 28 May 2020 17:11:05 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to M5StickC - can&#x27;t find serial port on Mac Mojave on Thu, 04 Jun 2020 09:22:19 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/csam" aria-label="Profile: csam">@<bdi>csam</bdi></a> ok..could you try again use this firmware upgrade tool:</p>
<p dir="auto"><a href="https://community.m5stack.com/topic/1591/m5stickc-and-atom-on-macos-catalina-can-t-upload-programs-solution">https://community.m5stack.com/topic/1591/m5stickc-and-atom-on-macos-catalina-can-t-upload-programs-solution</a></p>
]]></description><link>https://community.m5stack.com/post/8900</link><guid isPermaLink="true">https://community.m5stack.com/post/8900</guid><dc:creator><![CDATA[m5stack]]></dc:creator><pubDate>Thu, 04 Jun 2020 09:22:19 GMT</pubDate></item><item><title><![CDATA[Reply to M5StickC - can&#x27;t find serial port on Mac Mojave on Fri, 29 May 2020 21:04:59 GMT]]></title><description><![CDATA[<p dir="auto">Thank you! I tried it out, but it didn't work - the port still isn't showing up as an option to connect to. Are there any other suggestions?</p>
]]></description><link>https://community.m5stack.com/post/8869</link><guid isPermaLink="true">https://community.m5stack.com/post/8869</guid><dc:creator><![CDATA[csam]]></dc:creator><pubDate>Fri, 29 May 2020 21:04:59 GMT</pubDate></item><item><title><![CDATA[Reply to M5StickC - can&#x27;t find serial port on Mac Mojave on Fri, 29 May 2020 09:45:00 GMT]]></title><description><![CDATA[<p dir="auto">you could try to install a FTDI driver.</p>
<p dir="auto"><a href="https://www.ftdichip.com/Drivers/VCP.htm" target="_blank" rel="noopener noreferrer nofollow ugc">https://www.ftdichip.com/Drivers/VCP.htm</a></p>
]]></description><link>https://community.m5stack.com/post/8860</link><guid isPermaLink="true">https://community.m5stack.com/post/8860</guid><dc:creator><![CDATA[m5stack]]></dc:creator><pubDate>Fri, 29 May 2020 09:45:00 GMT</pubDate></item></channel></rss>
