<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[UIFlow 1.5.3]]></title><description><![CDATA[<p dir="auto">Ver 1.5.3. time : 2020.05.29<br />
UpdateLog：</p>
<p dir="auto">web:</p>
<li>Add Echo STT.</li>
<li>Add some blocks.3</li>
<li>Add StickC support in beta version.4: Fixed bugs.</li>
<p dir="auto">firmware:</p>
<li>Fixed: imu data error</li>
<li>Fixed: UI Background color error</li>
<li>Fixed: Button maximum recursive error</li>
<li>Fixed: DAC waveform not support error</li>
<li>update: PWM add set hold us method</li>
<li>Add: StickC device support</li>
<li>Add: unicode support (core 24px, StickC 16px)</li>
<li>Add: Echo STT support</li>
<p dir="auto"><img src="https://m5stack.oss-cn-shenzhen.aliyuncs.com/image/Updates_log/UIFlow1.5.3.jpg" alt="Echo STT" class=" img-fluid img-markdown" /></p>
]]></description><link>https://community.m5stack.com/topic/2000/uiflow-1-5-3</link><generator>RSS for Node</generator><lastBuildDate>Wed, 29 Apr 2026 00:33:31 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/2000.rss" rel="self" type="application/rss+xml"/><pubDate>Fri, 29 May 2020 12:32:52 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to UIFlow 1.5.3 on Mon, 15 Jun 2020 10:29:54 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/m5stack" aria-label="Profile: m5stack">@<bdi>m5stack</bdi></a> By GA I mean Generally Available. As in out of beta, ready for production use.</p>
]]></description><link>https://community.m5stack.com/post/9011</link><guid isPermaLink="true">https://community.m5stack.com/post/9011</guid><dc:creator><![CDATA[jhfoo]]></dc:creator><pubDate>Mon, 15 Jun 2020 10:29:54 GMT</pubDate></item><item><title><![CDATA[Reply to UIFlow 1.5.3 on Mon, 15 Jun 2020 09:27:04 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/jhfoo" aria-label="Profile: jhfoo">@<bdi>jhfoo</bdi></a> GA? your mean "google assistant"?  for the time being,  we don't have plan to connect it.</p>
]]></description><link>https://community.m5stack.com/post/9007</link><guid isPermaLink="true">https://community.m5stack.com/post/9007</guid><dc:creator><![CDATA[m5stack]]></dc:creator><pubDate>Mon, 15 Jun 2020 09:27:04 GMT</pubDate></item><item><title><![CDATA[Reply to UIFlow 1.5.3 on Sat, 13 Jun 2020 04:03:24 GMT]]></title><description><![CDATA[<p dir="auto">Echo support! Exciting! When is it GA?</p>
]]></description><link>https://community.m5stack.com/post/8979</link><guid isPermaLink="true">https://community.m5stack.com/post/8979</guid><dc:creator><![CDATA[jhfoo]]></dc:creator><pubDate>Sat, 13 Jun 2020 04:03:24 GMT</pubDate></item><item><title><![CDATA[Reply to UIFlow 1.5.3 on Tue, 02 Jun 2020 13:04:25 GMT]]></title><description><![CDATA[<p dir="auto">Thank you</p>
]]></description><link>https://community.m5stack.com/post/8889</link><guid isPermaLink="true">https://community.m5stack.com/post/8889</guid><dc:creator><![CDATA[Jan_Osch]]></dc:creator><pubDate>Tue, 02 Jun 2020 13:04:25 GMT</pubDate></item><item><title><![CDATA[Reply to UIFlow 1.5.3 on Mon, 01 Jun 2020 02:33:15 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/jan_osch" aria-label="Profile: jan_osch">@<bdi>jan_osch</bdi></a></p>
<p dir="auto">SD card function has been added, pls try to refresh the page.</p>
<p dir="auto">our engineer said. for the time being , UIFlow firmware base mpy 1.11</p>
<p dir="auto">the Echo Speech use tutorial pls wait. we will update the product docs as soon as possible.</p>
]]></description><link>https://community.m5stack.com/post/8883</link><guid isPermaLink="true">https://community.m5stack.com/post/8883</guid><dc:creator><![CDATA[m5stack]]></dc:creator><pubDate>Mon, 01 Jun 2020 02:33:15 GMT</pubDate></item><item><title><![CDATA[Reply to UIFlow 1.5.3 on Sat, 30 May 2020 21:56:20 GMT]]></title><description><![CDATA[<p dir="auto">Great to get the update to 1.5.3.</p>
<p dir="auto">Two questions:</p>
<li>When will SD cards be supported in UIFlow 1.5.X for the M5Core?</li>
<li>Where do I  get an Echo Speech token?</li>
<p dir="auto">And: isn`t UI this Flow based on micropython 1.12<br />
M5Burner 2.1.0 states "Base micropython v1.11" for UIFlow 1.5.3</p>
<p dir="auto">Thanks</p>
]]></description><link>https://community.m5stack.com/post/8876</link><guid isPermaLink="true">https://community.m5stack.com/post/8876</guid><dc:creator><![CDATA[Jan_Osch]]></dc:creator><pubDate>Sat, 30 May 2020 21:56:20 GMT</pubDate></item></channel></rss>
